Старый 17.12.2018, 02:34   #1
immortal
immortal is on a distinguished road
По умолчанию script.bin для LQ123K1LG03
Разыскиваются параметры в script.bin для дисплея LQ123K1LG03
а именно параметры секций [lcd0_para] и [disp_init]
делал по ману на http://linux-sunxi.org но увидел только мерцание внизу экрана
immortal вне форума   Ответить с цитированием
Старый 17.12.2018, 12:40   #2
(vS)
Аватар для (vS)
Машина: '98 PRIUS NHW10
а можно более подробную ссылку?
маст{ер} c[лов]а и стил<ус>а
грандесла
Старый 17.12.2018, 18:00   #3
immortal
вот даташит https://www.beyondinfinite.com/lcd/L...Q123K1LG03.pdf
вроде по мануалу делал секции в script.bin вот мануал http://linux-sunxi.org/Fex_Guide#dis..._configuration
вот мой конфиг
Код:
[disp_init]
disp_init_enable = 1
disp_mode = 0
screen0_output_type = 1
screen0_output_mode = 4
screen1_output_type = 1
screen1_output_mode = 4
fb0_framebuffer_num = 2
fb0_format = 10
fb0_pixel_sequence = 0
fb0_scaler_mode_enable = 1
fb1_framebuffer_num = 2
fb1_format = 10
fb1_pixel_sequence = 0
fb1_scaler_mode_enable = 1
lcd0_bright = 197
lcd1_bright = 197
lcd0_screen_bright = 50
lcd0_screen_contrast = 50
lcd0_screen_saturation = 57
lcd0_screen_hue = 50
lcd1_screen_bright = 50
lcd1_screen_contrast = 50
lcd1_screen_saturation = 57
lcd1_screen_hue = 50
[lcd0_para]
lcd_used = 1
lcd_x = 1280
lcd_y = 480
lcd_dclk_freq = 53
lcd_pwm_not_used = 0
lcd_pwm_ch = 0
lcd_pwm_freq = 10000
lcd_pwm_pol = 0
lcd_if = 3
lcd_hbp = 408
lcd_ht = 1688
lcd_vbp = 95
lcd_vt = 1025
lcd_hv_if = 0
lcd_hv_smode = 0
lcd_hv_s888_if = 0
lcd_hv_syuv_if = 0
lcd_hv_vspw = 0
lcd_hv_hspw = 0
lcd_lvds_ch = 0
lcd_lvds_mode = 0
lcd_lvds_bitwidth = 0
lcd_lvds_io_cross = 0
lcd_cpu_if = 0
lcd_frm = 0
lcd_io_cfg0 = 268435456
lcd_gamma_correction_en = 0
lcd_gamma_tbl_0 = 0x0
lcd_gamma_tbl_1 = 0x10101
lcd_gamma_tbl_255 = 0xffffff
lcd_bl_en_used = 0
lcd_bl_en = port:PH07<1><0><default><1>
lcd_power_used = 1
lcd_power = port:PH08<1><0><default><1>
lcd_pwm_used = 1
lcd_pwm = port:PB02<2><0><default><default>
lcd_gpio_0 =
lcd_gpio_1 =
lcd_gpio_2 =
lcd_gpio_3 =
lcdd0 = port:PD00<2><0><default><default>
lcdd1 = port:PD01<2><0><default><default>
lcdd2 = port:PD02<2><0><default><default>
lcdd3 = port:PD03<2><0><default><default>
lcdd4 = port:PD04<2><0><default><default>
lcdd5 = port:PD05<2><0><default><default>
lcdd6 = port:PD06<2><0><default><default>
lcdd7 = port:PD07<2><0><default><default>
lcdd8 = port:PD08<2><0><default><default>
lcdd9 = port:PD09<2><0><default><default>
lcdd10 = port:PD10<2><0><default><default>
lcdd11 = port:PD11<2><0><default><default>
lcdd12 = port:PD12<2><0><default><default>
lcdd13 = port:PD13<2><0><default><default>
lcdd14 = port:PD14<2><0><default><default>
lcdd15 = port:PD15<2><0><default><default>
lcdd16 = port:PD16<2><0><default><default>
lcdd17 = port:PD17<2><0><default><default>
lcdd18 = port:PD18<2><0><default><default>
lcdd19 = port:PD19<2><0><default><default>
lcdd20 = port:PD20<2><0><default><default>
lcdd21 = port:PD21<2><0><default><default>
lcdd22 = port:PD22<2><0><default><default>
lcdd23 = port:PD23<2><0><default><default>
lcdclk = port:PH24<2><0><default><default>
lcdde = port:PH25<2><0><default><default>
lcdhsync = port:PH26<2><0><default><default>
lcdvsync = port:PH27<2><0><default><default>
Код:
uname -a
Linux cubieez 3.4.95 #5 SMP Sat Jul 5 23:01:41 CEST 2014 armv7l GNU/Linux
кубик второй, подключен к LVDS
Старый 17.12.2018, 21:50   #4
immortal
вот кстати по настройке LVDS для кубика http://linux-sunxi.org/Cubieboard/LVDS
что странно, расположение у кубика не как у CB1 или CB2 написано в этом мане.
Часовой пояс GMT +4, время: 19:30.
