Результаты опроса: Do you think to use it ?
yes 9 75.00%
no 3 25.00%
Голосовавшие: 12. Вы ещё не голосовали в этом опросе
Старый 23.01.2011, 18:24   #1
pierrotm777
Аватар для pierrotm777
Smile Gmail Notifier for iCarDs and Emailer
This plugin is a Gmail Notifier: :-)
You can read just the begin of each unread mail.
You can listen to you email.
You can to traduce your mail into the language that you want (you must to have my translator plugin )
PLEASE, read the readme.txt file for installation !
readme.txt file:
Код:
1-Add to your exectbl.ini file:
/***************************************  GMAIL CONTACTS  ****************************
"SELECTCONTACT","CLCLEAR;ALL||MENU;GMAILTO.skin||CLLOAD;$SKINPATH$Scripts\GmailNotifier\CONTACTS.txt;TRUE||UPDATE_PIC||SETLIST;1"
"CONTACTTO","SETVARBYCODE;GMAILTO;LISTTEXT||SETVAR;GMAILTO;$GMAILTO$||WAIT;0.5||EXIT"
"ONCLCLICK","UPDATE_PIC",GMAILTO.skin
"UPDATE_PIC","SETVARBYCODE;CONTACTTO;CLDESC||SETVAR;CONTACTTO;$CONTACTTO$.jpg",GMAILTO.skin
"UPPIC","UP||UPDATE_PIC",GMAILTO.skin
"DOWNPIC","DOWN||UPDATE_PIC",GMAILTO.skin
/*************************************  GMAIL NOTIFIER  ******************************
"GMAILNOTIFIER","Run;$skinpath$Scripts\GmailNotifier\pop_tray.exe"
/*************************************  GMAIL PROFILE  *******************************
"GMAILPROFILE","CLCLEAR;ALL||MENU;GMAILPROFILE.skin||CLLOAD;$SKINPATH$Scripts\GmailNotifier\profiles.txt;TRUE||UPDATE_PIC||SETLIST;9"
"LOADPROFILE","SETVARBYCODE;POPPROFILE;LISTTEXT||SETVAR;POPPROFILE;$POPPROFILE$||SENDMSG;GmailNotifier;LOADPROFILE||WAIT;0.5||EXIT"
"ONCLCLICK","UPDATE_PIC",GMAILPROFILE.skin
"UPDATE_PIC","SENDMSG;GmailNotifier;LOADPROFILE||SETVARBYCODE;POPLOGO;CLDESC||SETVAR;POPLOGO;$POPLOGO$.png",GMAILPROFILE.skin
"UPPIC","UP||UPDATE_PIC",GMAILPROFILE.skin
"DOWNPIC","DOWN||UPDATE_PIC",GMAILPROFILE.skin
and you can add into your ONSKINSTART line the GMAILNOTIFIER command !
"ONSKINSTART","CreateSecondMonitor||SetMonitorState||RUN;$skinpath$Scripts\iCarMainScript.exe||PlayStartSound||setvar;IsDrive;0||StartTimer;Main;1000||LoadPlugins||EVAL;START_FLAG;strcomp("$SkinIsLoad$";"1")||BYVAR;START_FLAG;CWDSETUP<<SKINRESTART||BYVAR;LoadScreenStatus;MAIN<<SaveStateStatusRun||SETVAR;SkinIsEnd;0||UnloadAllScreens||VisuMediaS||SetVarFromVar;current_dpl;current_dpl_$Media_s$||GMAILNOTIFIER"
2-Add to your skin.ini file:
gmailpath=C:\Gmail\
and
APP1_NAME=GmailNotifier
APP1_PATH=$skinpath$Scripts\GmailNotifier\pop_tray.exe
APP1_WINDOW_TITLE=GmailNotifier
APP1_PARAM=
APP1_SCRIPT=SENDMSG;GmailNotifier;GMAILSETTINGS
APP1_SCRIPT_PARAM=
APP1_LOAD=1
APP1_OVERLAY=0
APP1_SKIN=gmailinit
3-Copy the MenuIcons folder into your THEME
4-GmailNotifier can give you the number unread message for a pop mail or gmail or hotmail.
You can send a mail for a pop mail or gmail or hotmail.
For Gmail , you can also read your email.
With this new version, you can now create one new profile , list your profiles and choose a profile into the list.
For launch the list , just click on the ***_***.ini or use the SENDMSG;GmailNotifier;GMAILPROFILE command .
I hope that you will like this new version !
GmailNotifier v0.9.8a.zip for DS
History:
v0.9.8 20/6/2011
Little update. Now, on the 'Send email' screen, you can change the 'Mail To:' address by clicking on or by the contact list!
v0.9.7 19/6/2011
This new version accept all pop3 server and Hotmail, but it just check the number of unread mails
You can create a new profile or load an existing profile from a list
v0.9.e 8/2/2011
exectbl.ini update
v0.9.d 5/2/2011
you can launch a web gmail page into DS (Use the button 'Start Gmail In DS')
v0.9.c 5/2/2011
You can listen to your message if you have sapi 5.1 on
V0.9 26/1/2011
first release for DS
ID:	22601   Нажмите на изображение для увеличения
ID:	22602   Нажмите на изображение для увеличения
ID:	22603   Нажмите на изображение для увеличения
ID:	22604   Нажмите на изображение для увеличения
Последний раз редактировалось pierrotm777; 07.04.2012 в 13:02.
Старый 24.01.2011, 20:51   #2
pierrotm777
По умолчанию reserved
reserved
Старый 26.01.2011, 15:41   #3
Сообщение от pierrotm777 Посмотреть сообщение
You can to traduce your mail into the language that you want (you must to have my translator plugin ((as soon as possible))
You can run GmailNotifier by a click on the Gmail Indicator(but i have a conflict with another of mine plugin RRelevation), or create a button.
The screens are not full compatible with the DS design but run very well ! Sorry
If somebody want to adapt it it's with pleasure !
GmailNotifier.zip
History:
V0.9 26/1/2011
Этот плагин - Gmail Notifier: :-)
Вы можете прочитать только первые строки каждого непрочитанного письма.
Вы можете слушать вашу электронную почту. -(разберусь что это поправлю перевод)
Вы можете перевести ваши письма на любой язык, который вас интересует (Для этого надо установить плагин переводчика (( будет выложен позднее))
Вы можете управлять GmailNotifier нажав на Индикаторе Gmail (но пока есть конфликт с другим моим плагином RRelevation), или создайте кнопку.
Экраны не полностью совместимый с дизайном DS, но работают очень хорошо!
Если кто-то захочет поправить это, буду рад!
ПОЖАЛУЙСТА, читайте readme.txt файл для установки!
PS. Как только разберусь с плагином включу его в следующую версию скина
Старый 26.01.2011, 21:41   #4
AlexIz
Регион: 76
Машина: Шкода Yeti
Похоже, можно прослушать текст письма через синтезатор речи.
Старый 27.01.2011, 09:55   #5
pierrotm777
Smile
Yes, but i am not certain that run with DS , and i don't know why !I must to see that
Старый 04.02.2011, 23:23   #6
AlexIz
Регион: 76
Машина: Шкода Yeti
Ребята, переведите, пожалуйста, readme в инсталяшке. Почту хочется.
Старый 04.02.2011, 23:34   #7
Было немного некогда разбираться, но в следующей версии скина и этот плагин и переводчик будет прикручен к скину, там всё не так просто. С наскока у меня не получилось, надо немного подогнать.
Старый 05.02.2011, 01:10   #8
Diagnose
Аватар для Diagnose
Регион: 34
Машина: 2003\Toyota\Allion
Почта вещь, наверное, полезная и может сгодиться, но привязка к GMAIL думаю не всем подойдёт, у народа наверняка почтовый ящик находится на других серверах.
Toyota Allion
Старый 05.02.2011, 07:30   #9
= Nicki =
Машина: Honda Fit
ага, например корпоративный
Инструкция к iCar DS
iCarDS + Тестер ECU
Старый 05.02.2011, 09:36   #10
pierrotm777
Cool
Sorry , i don't understand
Часовой пояс GMT +4, время: 01:34.
