Вернуться   PCCar.ru - Ваш автомобильный компьютер > Новости и Объявления > Новости
Старый 13.03.2010, 01:42   #1
whitepanther
местный псих
Аватар для whitepanther
Регион: Финляндия
По умолчанию Вышла Cantrafuse 3.1.24.309
Дождались!
Наконец-то обновление! По форуму видно, что центрифугу-таки "напильником" немного доработали
Теперь можно старые добрые скины Aura и Onyx под 3.1 скачать.
Есть одна неприятная сторона:
ключи нужно по-новой генерить, т.к. опять изменен алгоритм защиты.
Теперь то, что в официальном сообщении с форума (ребят, времени нет вообще - может кто-нить на русский переведет?):
Centrafuse 3.1 Update
What's new in 3.1?
Centrafuse 3.1 includes many important bug fixes for our customer base as well as introduces a few new features from OEM projects. It is also the next big step towards giving complete control to the developer/skinner through advancements in our CML concept.
Important Licensing Changes
* We have improved the licensing to address Hardware IDs unnecessarily changing.
* Due to this unavoidable licensing change, everyone will need to upgrade to this version as soon as possible. Once this version is installed, a new license file will be needed immediately.
* All existing 3.0 license hardware profiles have been cleared, allowing every 3.0 license a clean slate to generate your new 3.1 license files.
* Existing 3.0 license files deployed will continue to work after the 3.1 release, but we advise you update to 3.1 as soon as possible.
Important Note Concerning 3rd Party Plugins and Skins
* All 3.0 3rd party plugins will need to be recompiled against the new cfplugin.dll. 3.0 plugins by default will not work with Centrafuse 3.1. 3.0 skins by default will also not work with Centrafuse 3.1.
Important Installation Notes
* Version 3.1 will effectively replace version 3.0. All download links have been updated to the 3.1 full installer. Maps need NOT be removed, or reinstalled.
* There is both a downloadable update patch AND a full installer for 3.1. The full installer is recommended however, the 3.1 patch update - link available below - will work fine in most cases. Both are available from your Account page or the Downloads page. You may run the full installer directly “on top” of your existing 3.0 configuration.
* You can keep your current settings when using the full installer. Just be sure to answer YES when prompted to keep to keep user settings. If you are using another skin than the “Clean” skin (the default), you must set this back to “Clean” before you apply the 3.1 update.
* If the update patch does not work, it may be because you have custom skins or plug-ins installed not yet compatible w/ 3.1. In this case, uninstall and manually clean the Centrafuse Auto directory in Program Files and run the full 3.1 installer. In this case, it is recommended you NOT keep your settings, however you can try.
MAJOR CHANGES IN 3.1
* BUG FIXES - Many bug fixes from the initial 3.0 release, see below for details.
* PLAYLIST BUILDER - Create your own custom playlists.
* IMPROVED VOICE RECOGNITION - Use voice recognition with near 100% accuracy now to load and play albums, artists, and genres.
* MULTI-USER PROFILE SUPPORT - Create multiple users and switch between them easily via user switching screen. Create unlimited unique users with different settings, music libraries, everything.
* NESTED MENU SUPPORT - Select "Nested Menu" as a button action for your main buttons, and create entire new subsets of buttons.
CentrafuseAura, Onyx Skins coming soon
Soon to be available will be the CF2 skins Aura and Onyx Day/Night. Many thanks to Centrafuse users Marcelp and Willem for helping to complete these skins.
The Centrafuse 3 SDK is in Alpha stage and will remain as such until the CML implementation is completed.
Alpha 2 (Unsupported) SDK release can be downloaded here:
http://www.fluxmedia.net/downloads/Centrafuse_SDK_3.1_alpha2.exe
SDK Online Docs can be found here:
Centrafuse SDK
V 6.4.299.0 available from IVT
IVT has released a new version of their stack since the CF 3.1 release. Some users have found fixes in this new stack. If you are experiencing issues with the shipped stack version (6.4.289.0), please try IVT's latest. Please note that stack versions not shipped with CF can not be officially supported by the Centrafuse staff, however you can easily roll back your BlueSoleil version by uninstalling and re-running the CF 3.1 installer.
*** 3.1 NEW FEATURES ***
* New Playlist Builder
* All volume controls easier to access
* Multi-User Support
* Nested Menu Support
* Improved Voice Recognition: Dynamic grammar creation for Albums, Artists, and Genres. Say "Play artist Linkin Park" or "Play genre country", etc, etc, and the commands now work with near complete accuracy with included MSSAPI voice rec module. Currently English only for the word "Play".
* NowPlaying button displays icon of currently paying audio source, configurable through CML
* Volume dialog removed in default clean skin, volume buttons added back to main screen
* Paging buttons moved back to main screen area on far left and right
* When searching for a handsfree bluetooth phone, you can now start the pairing before the entire search has completed.
Attention Skinners and Developers:
* New CFPlugin.CFVideo class for ease of making video capable plugins
* CML Text for labels and buttons
* New powerful CML button/label attributes
* Tab groups control for buttons using CML (behaves as HTML radio style selection groups)
* CML labels: elapsed time, duration, format, source, etc... put current media info anywhere using CML.
* Use different number of main screen main buttons. Nested menus can be a different button layout from the main layout. Note dynamic buttons must be used in this case.
* New "CML hold action" and "hold time" xml attributes for easliy specifying different actions when user pushes and hold a control for specified amount of time
* New "scroll" xml attribute for label controls to make any text scroll like the CF main title always has done
*** 3.1 BUG FIXES ***
* Nav Plugin TMC does not work
* Aspect ratio button still visible when exiting video
* Tab indexes not working correctly, tabbing/keying through CF controls
* When use main menu hotkey on main menu, a transition runs and main menu reloads
* When using hotkey for any action to go to screen, and screen was already open, transition runs and screen reloads
* When first enable rear screen, rear plugins do not scale correctly
* Background image does not set/display right away when changed, and does not show right in settings
* Logarithmic volume issues with volume slider
* Push-and-hold to add button actions does not work on added pages (if more than 4 pages)
* Indexing in media player searches by title instead of artist
* Volume dialog is misaligned by a few pixels, obvious in Dest plugin
* VR does not disable when phone call is active
* Many Centrafuse.Main CML commands do not work with holdaction
* Centrafuse.System commands do not work until after the system dialog is opened at least once
* Volume dialog pops up when changing use pre as master and log volume settings
* LostFocus CML events do not work correctly when rear screen is in use
* mute button does not update to mute status when rear soundcard is not in use
* rear screen volume slider is controlling main volume even when rear soundcard is in use
* with music paused, giving 2 speech commands will unpause music
* custom settings would prompt for unsaved changes if cancel even if no changes have been made
* Turn-by-turn list in Nav does not include very next turn
* Visualization disappears when change skin with hotkey, when visual is visible
* Destinator GetManeuverList() error
* DVD now playing issue
* When a plugin is a page 1 button action, when first start CF, the button text is not displayed
* When change skin, email plugin listview gets cleared and will not repopulate
* If something is set other than MainMenu for startup location, the home button is not displayed on startup (the paging buttons are still there)
* Empty pages (no button actions) should be dynamically removed
* Vista voice notes issue in record line mute attribute
* Voice commands to make phone calls does not work.
* Reports that phone hangs/freezes at certain points of dialing/receiving phone call, assuming this is due to loading circle according to some system reports, changed loading circle code, again
* TrackDetail dialog. In elapsed label I see remaining time for example -044 instead of 0:01:11... This has happen in last update before has normaly work
* Can not change generic used icon for external application. In skin.xml i change "generic.png" to (as example) "gps.png", but nothing happens.
* When satradio or am/fm radio are in non-buffer mode, play/pause button works (for unmute/mute) but when audio first starts it is out of sync (play icon is showing instead of pause icon)
* When audio adapter is removed and media is playing, bass returns error and playlists are auto ejected, so all playlists are lost
* Radio is playing and i go to navigation screen! (Radio minimized). Now i click on Radio Button in the upper left. It shows me for a short time the mainscreen and after that it switched to radio screen (This issue is only when radio is playing, it works for xm, media player).
* When satradio or am/fm radio are in non-buffer mode, and vis was set to show, and then open satradio, vis is not set to show the channel image (no vis in non-buffer mode, just black box), should also not be able to turn image off to see vis
* Number Pad dialog will only open on display 1, will not open on rear display or secondary display
* Fixed spinning loading circle operation, causing various issues here and there, no longer runs on separate application thread
Please visit our downloads page for a free 30 day trial and/or full 3.1 installer.
3.1 SELF EXTRACTING UPDATE
Can be installed on top of any 3.0 or 3.1 install.
http://www.fluxmedia.net/downloads/CF_3.1.24.309-Update.exe
Thanks,
Scott and the Flux team!
Старый 13.03.2010, 01:53   #2
St@rz
Аватар для St@rz
Машина: INDESIT/2007
Примерно так:
Изменения в версии 3.1:
* Изменен алгоритм генерации ID компьютера, теперь при переустановке Windows Centrafuse больше не будет генерировать новый ID номер и Вам не придется заново получать новый ключ лицензии
* Убрана графическая нагрузка в главном меню,убраны тормоза при смене меню.
* Добавлена возможность создания и быстрой смены пользователей
* Изменен скин, кнопки прокрутки треков перенесены вверх.
* Более легкий вызов регулятора громкости
* Добавлена возможность создания вложенных меню
* Улучшена система распознавания голоса
Обновление доступно в двух версиях :
* Обновление в виде патча
* Полноценный инсталятор
Рекомендуется использовать полноценный инсталятор для полной установки.
Как производить установку обновления:
Можно поставить поверх версии 3.0 как патч так и обновление.Но только перед установкой необходимо удалить все установленные вами плагины и скины от версии 3.0
Внимание плагины и скины от версии 3.0 не будут работать на версии 3.1. Приносим свои извинения за данное неудобство в скором времени эта ситуация будет исправлена и все плагины и скины будут перекомпилированны под версию 3.1
Почистите перед установкой папку плагинов C:\Program Files\Centrafuse\Centrafuse Auto\Plugins
Во время установки Вы можете сохранить ваши старые настройки пользователя,когда программа спросит вас "Сохранить настройки пользователя" отметьте "Да" или "Нет" если не хотите сохранять настройки.
Если у Вас возникли проблемы при установке то это может быть вызвано либо наличием плагинов от 3.0 или скинов, удалите все плагины и скины от предыдущей версии и переустановите заново патч или полноценный инсталятор.
В скором времени будет доступны для загрузки скины от Centrafuse 2 Aura и Onyx
Старый 15.03.2010, 01:48   #3
oops1
Аватар для oops1
Машина: Audi Q7
oops1 is on a distinguished road
Дождались!
Куль будем качать
oops1 вне форума   Ответить с цитированием
Старый 15.03.2010, 08:20   #4
Lion008
Аватар для Lion008
Регион: 56
Машина: Lancer 9
Супер!
Только как же ее регистрировать? не понятно
собирал себе комп в машину:
Все что осталось
моник Mystery MMT-8120s
Wi-Fi модуль mini-PCI Qcom
винт 160 Gb SATA-II 300 TOSHIBA 2.5"
приводDVD±R/RW Pioneer DVR-TS08
D-Link 7-port USB2.0 Hub + б.п.
корпус Cooler Master Elite100
читалка для машинки OBDII USB ELM327 v1.3 адаптер
Старый 15.03.2010, 19:28   #5
Actyon
Аватар для Actyon
поставил, юзаю. Выявились множество багов с плагинами. Звука в радио добиться вообще не удалось. Пишут, что надо с кодеками пробывать, но полдня с возни с ними, результатов не принесло. Если запустить дистинатор, просмотр фильмов в движении запрещено. при просмотре фильмов, отсутсвует видимая полоска трека, а так же звук идет только на 2 передних колонки (опять же кодеки, но для платно проги я считаю это несерьезно). С обычной СФ3 все нормуль. Прогу устанавливал после форматирования диска С на свежую винду. Уменьшение кнопок запуска как по мне не самое удачное решение. Половина плагинов работает не коректно или вообще не видится (в папке самого плагина почему то нет длл). В общем завалил я ее, опять поставил 3.0, все работает стабильно все летает проблем нет. единственно ищется карта на дистинатор Украины, но с этим проблема. Может кто подскажет как ее скомпилировать? похожме проги том том или стандартная навигашка от бмв и мерседеса
Старый 16.03.2010, 01:09   #6
скачал, поставил, зарегил.
новый стандартный скин полный отстой, мало того что выглядит не очень, так еще и не удобный, мультимедийные кнопки разбросаны по экрану.
поставил Onyx Day, привычно. подправил скин под встраивание ситигайда, поменял шрифты для русских тегов, но с русским все равно косяк, в верхней полосе отображается нормально, а в списке кракозябры. Как побороть?
остальное все работает.
UPD решение нашел, нужно править не только skin.xml соответствующий выбранному скину, но и
\Centrafuse\Centrafuse Auto\Skins\выбранный скин\listview\commonfonts.xml
Старый 31.03.2010, 16:17   #7
Yoga
Регион: 69
Машина: Mazda 6 2.0
Yoga is on a distinguished road
Шура не гнобите скин. У каждого свой вкус, сказал индус слезая с......
Yoga вне форума   Ответить с цитированием
Старый 31.03.2010, 16:23   #8
Yoga
Регион: 69
Машина: Mazda 6 2.0
Сообщение от Actyon Посмотреть сообщение
Поменяй аудио драйвер. У меня было тоже самое играл только на левый канал правый молчал. Я выбрал драйвер вручную похожий на тот что стоит и все поперло. А навигашка у меня Гармин работает великолепно. Встроил через Rebelleum3 клава для поиска русская.
Старый 22.04.2010, 17:21   #9
yuras
Аватар для yuras
Машина: LADA PRIORA
yuras is on a distinguished road
Сообщение от Yoga Посмотреть сообщение
А Как установить Rebelleum3?? У меня через инсталятор не ставится.. пишет что то тип не та версия винды, как ручками установить его??
Пробовал под 3.1 плагины для встраивания, ниодин не подошол.. а отдельным окном запускать навигашку, не удобно и некрасиво, да и не удобно
Восьмёрка ТЫКНИ
Лада Приора ТЫКНИ
Последний раз редактировалось yuras; 23.04.2010 в 18:36.
yuras вне форума   Ответить с цитированием
Часовой пояс GMT +4, время: 18:50.
