Результаты опроса: Do you think to use this plugin ? | |||
Yes |
22 | 95.65% |
No |
1 | 4.35% |
Опрос с выбором нескольких вариантов ответа. Голосовавшие: 23. Вы ещё не голосовали в этом опросе |
#251 |
![]() Регистрация: 07.11.2010
![]() Winlin,
When you use the new plugin , do you think to set off the original plugin into iCarDSConfig.exe ? |
#252 |
![]() I have done several tests with the Bersenev 1.7.0.33 version !
The new plugin seems running well ! But if i try to use the two plugins in same time, it's not possible to call a contact with the original plugin ! I think that will be the same issue with the version 1.7.060 b19 !!! |
#253 |
![]() Регистрация: 14.06.2013
![]() All use version 1.7.060.
It does not matter by Bersenev or by Lexx09 |
#254 |
![]() Регистрация: 01.06.2013
Машина: SUBARU Impreza WRX
![]() pierrotm777
Hello ![]() If it's not too much trouble maybe you write a little program in VB.NET to toggle speakers <> mobile phone ? fist run program get phone and write to ini... next run program read from ini and just toggle connected phone... speakers <> phone. This little tool very help people who use standard icards phone plugin ![]()
Готовые сборки foobar2000 для КарПС //--- FLAT ---\\ Сборки PotPlayer Полезные утилиты |
#255 |
![]() New feature in 1.6.4 version !
Sms reader screen return if a file is attached ! |
#256 | ||
But this command is only for the new plugin ! I don't know the command for the original plugin (if its exist ) ! Цитата:
I can't for the original plugin but it's possible for my new plugin ! I have no access to the original plugin code !!! Последний раз редактировалось pierrotm777; 27.10.2016 в 19:47. |
#257 |
![]() Регистрация: 19.11.2009
![]() contact always Unknow Sender № telephone always empty The "IDmessage" is not fully displayed plugin 1.6.3 iCar 1.7.0.48 resolution 1024*600
HONDA CR-V все сделано в 1.5 Din корпусе MSI H61I-E35/Pentium G2030T/4Gb/M4-CT128M4SSD2/8"монитор/Wi-Fi/Bluetooth/усилитель MiniQuad 4х50 + конвертер SPDIF>аналог/m2-atx/HD RADIO DMHD1000I/Logitech QuickCam Pro 9000...Win7 prof |
#258 | |
![]() Version 1.6.4 will be updated ! |
#259 |
![]() contact always "Неизвестно"
#260 |
![]() reload, resetup, no changes
contact always "Неизвестно" № telephone always empty and you don't need to select plugin
