Вернуться   PCCar.ru - Ваш автомобильный компьютер > MP3Car ТехИнфа > Разработка программ > Программы управления > iCarDS > iCarDS и телефон
Результаты опроса: Do you think to use this plugin ?
Yes 22 95.65%
No 1 4.35%
Опрос с выбором нескольких вариантов ответа. Голосовавшие: 23. Вы ещё не голосовали в этом опросе
Старый 24.07.2016, 19:45   #51
seriousstas
Can you explain , i don't understand what you say exactly !
I mean - that the letters in our alphabet of 33 and there are only 26 in a small keyboard + Search works only for lower-case letters(small keyboard!) a b c d, and does not work for the A B C D
See PM
Старый 26.07.2016, 01:14   #52
seriousstas
What is it and how to translate? :
PhoneSpeechRecognitionReset
These buttons (commands) do not work! :
l_set_BTM_Update
l_set_BTM_Pair
l_set_BTM_UnPair
l_set_BTM_DeletePaired
These letters is no in a small keyboard : Б Ж Л Х Э Ю
The language russian file is under C:\Program Files\TipTop software\iCar DS\Extentions\MobilePhone\Languages\russian\russia n.txt
If you want help me for a better translation ?
send to PM
Последний раз редактировалось seriousstas; 26.07.2016 в 03:45.
Старый 26.07.2016, 13:07   #53
seriousstas
If use iCarDS Plugin BTMobilePhone (PBAP & MAP services) V1.4.9 DS Setup (V1.5 DS Setup) installer with two checkboxes, at the start,
then need to do these points from the readme ?:
2.Under C:\Users\pierre\Documents\iCarDS\skins\Chameleon\L ABELS\
a) folder LABELS
copy the files found into Chameleon_AddOns\LABELS\
b) Under C:\Users\pierre\Documents\iCarDS\skins\Chameleon\l anguage\
copy the files found into Chameleon_AddOns\language\
3.Copy the files that follow under you skin directory C:\Users\pierre\Documents\iCarDS\skins\Chameleon\
cf_ind.txt
setting.skin
setting2.skin
setting3.skin
setting4.skin
setting5.skin
Think you need to replace 33 by 7.
I can change that into the installer if needed !
to replace on +38 for Ukraine
Think you need to keep 112 for emergency.
This number is correct
Старый 26.07.2016, 13:48   #54
seriousstas
Actually, he don't want !
I made the correct translation + there are some problems, and after revisions, when the plugin will be stable - I think he is sure add.
Write a new instruction - I'll translate.
Readme.txt is not actual.
Старый 27.07.2016, 06:33   #55
seriousstas
Definitive version 1.5.0 is out !
Unfortunately, all the old problems are present
1 indicator looks for SMS endlessly and constantly blinking.
2 Keypad search (by first letter) does not work! Please remove it and make basic by clicking - a second keyboard (hold).
3 All messages are recorded in dialer string - and it is not convenient then removed (screen №2)
4 Closing the "information window" (1-t screen) often leads either to freeze or to IcarDS fall.
5 Why can not you just dial the number - why should I enter?
6 New window continues to hang from the top, if you close the other button. I think - this window do not need (screen №3)
Why Prefix box? and how to change the country on your own?
ID:	44353   Нажмите на изображение для увеличения
ID:	44354   Нажмите на изображение для увеличения
Старый 27.07.2016, 06:35   #56
seriousstas
should like is that Lexx09 add these add ons into the last icards version !
Said added after the stable version
Старый 27.07.2016, 16:40   #57
pierrotm777
Аватар для pierrotm777
Smile
If the sms number is different to 0, the indicator is blinking always.
Read your sms with your phone , you will see that the indicator blinking is stopped and number return 0.
I want to keep a little keyboard for this feature (click button) but i need help for build this screen. Latin keyboard is ok but not the russian and i don't know why! May be a guy of the forum can help us ?
I don't understand why this issue ! I have not this problem why the RR version.
Do you use the log file ? If yes set log file in settings to 'false'.
Can you explain please ?
It's an Overlay option that we can stop ! Just stop the idle option into the mobilcall.skin screen that call this window !
The prefix list help just the user when he want call an international number !
Into the second setting's screen, click on the second right line and change with your country code.
You can also change it with a text editor (replace 33 by your code).
The two buttons under the 'Apply' (save button) are needed.
One stop any change and the second, save a default xml file!
I have the idea to have just one SMS notification after the icarDS start and only other one notification each time we receive a new sms !
PS. The last version 1.5.1 solve the iPhone issue with the sms that we can no read !
Старый 27.07.2016, 18:20   #58
pierrotm777
Smile
Can you test this new keyboard !
I think that all your letters are in this version !
By default, the variable KBLAYOUT is set to 0 for your country !
SETVAR;KBLAYOUT;0
Последний раз редактировалось pierrotm777; 27.11.2016 в 18:19.
Старый 27.07.2016, 18:31   #59
pierrotm777
Into the MOBILPHONE.skin screen, edit the button search with:
B,512,540,100,84,"MENU;SKIPTO_OSK.skin||SETVAR;KBLAYOUT;1",@OSKTOCMD;SEARCHNAME;SEARCHLIST;$SEARCHNAME$ @
Старый 27.07.2016, 19:53   #60
Gadina
Машина: Honda CR-X
Gadina is on a distinguished road
also 2 th character
2 th character it should be " Б " , but not " Ь "
7 th character it should be " Ё " , but not " Я "
Gadina вне форума   Ответить с цитированием
Часовой пояс GMT +4, время: 11:28.
