Старый 01.07.2008, 11:04   #1
nemo61
nemo61 is on a distinguished road
По умолчанию Индикация температуры
Подскажите, а есть ли возможность вывести индикацию о температуре, которую выдает материнская плата?
nemo61 вне форума   Ответить с цитированием
Старый 01.07.2008, 12:04   #2
DNZ_
Аватар для DNZ_
Машина: Suzuki Vitara
DNZ_ is on a distinguished road
Сообщение от nemo61 Посмотреть сообщение
Файл Skin Commands.txt:
Код:
"MBMXX"			- Information from Mother Board Monitor 5 (XX denotes the sensor number).
			  When using this, the tooltip defines the format of display examples are:
			  CODE   , Tooltip
			  "MBM01", "C2F"	(Celcius to Farenheit conversion, "F2C" also available)
			  "MBM01", "0C"		(0 is replaced to show "59C", could also be "0.0 C" etc)
			  "MBM49", "0 RPM"	(0 is replaced to show "4216 RPM", "0.00V" etc)
"SFXXX"			- Information from SpeedFan -- SF codes start with a letter denoting the type of Info.
			  'v' for voltage, 't' for temperature and 'f' for fan.
			  For instance '"SFV3" would be the third voltage sensor
Себе сделал вот так:
Код:
L401,500,150,100,030,255,255,255,14,"ISOCPEUR:B","=CPU temp:","RIGHT"
L402,600,150,100,030,255,255,255,14,"ISOCPEUR:B","SFT2"," 0.0 `C","LEFT"
L403,500,170,100,030,255,255,255,14,"ISOCPEUR:B","=MBR temp:","RIGHT"
L404,600,170,100,030,255,255,255,14,"ISOCPEUR:B","SFT0"," 0.0 `C","LEFT"
L405,500,190,100,030,255,255,255,14,"ISOCPEUR:B","=HDD temp:","RIGHT"
L406,600,190,100,030,255,255,255,14,"ISOCPEUR:B","SFT6"," 0.0 `C","LEFT"
L407,500,220,100,030,255,255,255,14,"ISOCPEUR:B","=CPU fan:","RIGHT"
L408,600,220,100,030,255,255,255,14,"ISOCPEUR:B","SFF2"," 0000 RPM","LEFT"
L409,500,240,100,030,255,255,255,14,"ISOCPEUR:B","=MBR fan:","RIGHT"
L410,600,240,100,030,255,255,255,14,"ISOCPEUR:B","SFF0"," 0000 RPM","LEFT"
Естественно не забыть установить и запустить SpeedFan или MBM.
HW:Intel D945GCLF2 | 512M | 2,5" 120 Gb WD | G-Alantic GA677iBK-A1 | E10000, rev850 | GPS GlobalSat EM332 + AT-65 | IRRemote Control | LILLIPUT - GL859-NP/C/T
SW:RR+PGS+Ozi+Russa+SlyControll+fma
DNZ_ вне форума   Ответить с цитированием
Старый 01.07.2008, 16:37   #3
nemo61
Спасибо, получилось.
Часовой пояс GMT +4, время: 20:36.
