Старый 11.09.2007, 12:59   #1
archer
Аватар для archer
Машина: 2007\chery\Amulet
По умолчанию Свежачек от 09-09-2007
http://www.mp3car.com/vbulletin/road...-p-hehehe.html
In this version:
-Added support for UNICODE Media Library (Winamp 5.33+)
-Added support to display Album Art while Browsing Albums from the Winamp Library
-Added support for custom folder/media icons for each screen
-Added prevention against trying to use MediaInfo with files known not to have tags (M3U, WAV, PCM, etc)
-Added SAVERESUME command to save resume info at any desired time
-Improved music resume to resume last exact Pause/Play/Stop State
-Improved against "false" is not a valid skin issue
-Improved escape sequence in Sirius Module (Preventions)
-Improved garbage detection in ID3v2 Tags
-Fixed issue with scrolling using TouchWheel when browsing M3U playlists
-Fixed issue with iguidance position when ignative=true and RR's skin position is offset in general.ini
-Fixed issue with browsing playlists with few songs in them
-Fixed issue with reloading tags when adding files from media library/ipod
-Fixed issue with text art not resizing with resized skins
-Fixed issue with runtime error when clicking the road name in Mappoint
-Fixed issue with import route sometimes not loading correctly (Mappoint)
-Fixed random lockup issue when selecting files in FMOD player
-Improved text art to also work with non-windows text file formats
-Improved/added minor prevention against garbage when adding files with Winamp.DLL
-Improved FMODRR.DLL to allow setting background color of the Visualization
Notes:
-Media/Folder images can be specified on each screen now by listing them with the on/down/off/empty images -- see skin commands.txt
-Remember to Re-register Winamp.DLL and FMODRR.DLL as they were updated
-Other than that, a couple of improvements and fixes to make the software a little more complete and more stable.
-Websites ARE updated.
Старый 12.09.2007, 12:14   #2
AndrewSha
Аватар для AndrewSha
Регион: 45
Этот релиз очень сырой. Намучившись с настройками целый день, пришлось вернуть старую версию.
В релизе 09-09-07 так и не удалось заставить отображаться mp3 файлы в AUDIO BROWSER. Они появляются после добавления в плэй-лист. Ну и оболочка нормально работает с winamp`ом 5-ой версии.
Старый 17.09.2007, 08:09   #3
Dm_Dm
Регион: 56
Машина: 1997\Nissan\Maxima
Dm_Dm is on a distinguished road
Сообщение от AndrewSha Посмотреть сообщение
Попробуй в rr.ini найти строчку audiofiles=*.mp3 *.wav
что добавишь - то и будет показывать
У меня вот если поставить transitions - виснет наглухо.... Если их не использовать - то все ок
Вообще по ощущениям - побыстрее работает
Dm_Dm вне форума   Ответить с цитированием
Старый 17.09.2007, 11:34   #4
AndrewSha
Регион: 45
Сообщение от Dm_Dm Посмотреть сообщение
Как все просто оказалось. да, все запоказывал...
Старый 17.09.2007, 12:07   #5
Freak
Аватар для Freak
Машина: 05\Matiz ver2 1,2i
Freak is on a distinguished road
Арчер а ты его пробовал? Там ужо есь пунктик силабз радио в конфиге...
Тока у меня засада какая то непонятная, выбираю канал а он через секунду или 2 перескакивает на 10 МГц вперёд и работает с етой частоты :-( Не знаешь в чём дело?
Freak вне форума   Ответить с цитированием
Старый 17.09.2007, 12:12   #6
archer
Аватар для archer
Не-а не ставил пока......
Но очень похоже, что у тебя нажата кнопка scan
Старый 17.09.2007, 12:39   #7
Freak
Аватар для Freak
нее, я смотрел не похоже на скан.... Не на всех каналах радио такая байда и потом он прыгает только на 10 МГц вперёд и останавливается, дальше воспроизводит на етой частоте пока не выключишь....
Старый 17.09.2007, 13:00   #8
archer
Аватар для archer
Странно... Надо будет старую Dll-ку сохранить....
Старый 18.09.2007, 03:22   #9
AndrewSha
Регион: 45
Первые итоги тестирования версии 090907.
1. Увеличения Скорости особо не заметил.
2. Устранены некоторые досадные ошибки оболочки (раздражали сильно)
3. USB-радио работает с LART, без всяких перескоков по частоте, но как запрограммировать несколько станций на быстрое переключение - так не понял (может, кто подскажет)
Так что возврата к старой версии не будет - продолжаю юзать "новье".
Старый 18.09.2007, 11:52   #10
Freak
Аватар для Freak
В корень RR файлик вот такого вида с таким именем кидаешь Вложение 3820
Последний раз редактировалось Freak; 14.12.2007 в 13:59.
Часовой пояс GMT +4, время: 18:21.
