Результаты опроса: Do you think to use it ?
yes 19 100.00%
no 0 0%
Голосовавшие: 19. Вы ещё не голосовали в этом опросе
Старый 14.02.2011, 14:44   #1
pierrotm777
Аватар для pierrotm777
Smile SkinTool for DS
I don't know if you use it very often , but for me it is very important for debug my programs and screens.
With the RR skintool i have several issues.
So, i have made mine SkinTool for DS .
Now, the screen edition don't ask a .txt file but a .skin .
You can see your variables.
Etc...
For each new version please backup before your skintoolds.ini file and delete it !
History:
V1.7 18-8-2016
-Version .NET with log file ready !
-add Gps Simulator and other Gps tools by Lefebure
-add color picker
V1.6 5/4/2011
-if you edit the screens files with the "Screen DS" button, you can save it without error.
-detect automatically if RR or DS is running
V1.5 23/3/2011
-now, you can launch skintoolds before RR or DS.
-add the 'copy to clipboard' when you are on the Debug Window
-add the 're-execute command' when you are on the Debug Window
-best use with RR
-best use on Vista and Seven
V1.4 14/3/2011
-new cool option, add a paint editor button into the 'Screen DS' option that open the four screen's files
-add a paint editor combo that set the paint editor that you like (MsPaint|Paint.NET|Photoshop|Paintshop|Gimp)
You can open several files selected into the list (use the CTRL button)
-The network meter don't run on Vista ans Seven (sorry), added an modification for that !
v1.3 12/3/2011
-the editor's list has the filter (*.skin,*.txt,*.*,*.png)that run now.
-the network meter is now always on the top right,put into the tools gui and give you your ip !
-added a backup for the variables with a $ into the name (=$skinpath$)
-added a backup for the sliders with and without a $ into the name (=$slider$)
-added the possibility to edit the label_list.txt and label_xx.ini files (DSFiles)
V1.2 9/3/2001
-the double | is now saved into the command's list
(you can send a command as , activate;Sygic FLEET||sendkey;{F1} and see it well into the list)
-the commands list and variables list are now in real time when you use the option 'Clear Settings'
V1.1 7/3/2011
-The 'Window Info' run well now
-I have added a 'compare two folders' option into the tools.
-Under the 'Edit Screen' button exist now a button for edit all file that you want into the skin folder with a filter (*.skin,*.txt,*.png and *.*)
-under the 'Gps' button exit a ''Net' button that show you the upload and download speed .
-slider option is now ok and with a combo option !
-you compare two folders !
V1.0 4/3/2011
-Now the log is fully functional .You can also, pause , clear and save the log file !
-the dll is optimized ('runlog', run the log,'pauselog', stop the log and clean the log when skintoolds start)
-better compatibility with RR
V0.9 3/3/2011
- i have solved the 'Live Debug Log' issue
V0.8 3/3/2011
-a little update for a best compatibility with Vista and 7
V0.7 2/3/2011
-addition of a Tools option
calc,police viewer,screen coordinates,paint editor,pallet colour,key code viewer,class name and title of a window(not active now)
V0.6 21/02/2011
-you can use SkinToolDS with DS or RR.
-addition of a settings file that backup all your commands or variables that you have used
(each new command never used by you is saved)
(each command can be deleted)
-addition of the reading debug file (iCarDS.log)
-profiles are fully usable
I have always an issue with the Window 'Live Debug Log'. Sorry
V0.5 20/2/2011
-add the options possibility (with issues, sorry, i try to found a solution)
-the log is actif through the skintoolds.dll (with some issue, sorry, i try to found a solution)
-some cosmetics changes
-the separate window between the log's window and the main window is now actif
-the DSFiles are fully enable
V0.4 18/2/2011
-add a screen .png or .jpg viewer
-add a gps's values screen
V0.3 15/2/2011
-add the possibility to read the documentation
(The Documentation folder must to be under the iCarDS folder)
C:\Program Files\TipTop software\iCar DS\Documentation
V0.2 15/2/2011
-With this version, you can edit your .ini files
-With the skin CFStyle ONLY, you can edit your files language also
V0.1 14/2/2011
First version
Тип файла: zip SkinToolDS.zip (203.9 Кб, 1229 просмотров)
Последний раз редактировалось pierrotm777; 18.08.2016 в 12:49.
Старый 14.02.2011, 15:03   #2
Замечательно
Старый 14.02.2011, 15:40   #3
pierrotm777
Smile
Замечательно
Thanks
Старый 14.02.2011, 19:04   #4
Мишаня 121
Машина: BMW E46
Мишаня 121 is on a distinguished road
Переводчики в тырнете кривые)))) Это что-то типа редактора скинов, или я не так понял?
Мой проект: http://www.pccar.ru/showthread.php?p=165201#post165201
Мишаня 121 вне форума   Ответить с цитированием
Старый 14.02.2011, 19:18   #5
pierrotm777
Red face
Сообщение от Мишаня 121 Посмотреть сообщение
I am sorry , but i don't understand what you say me !
Старый 14.02.2011, 19:26   #6
pierrotm777
Smile
The first version is downloadable !!!
Старый 14.02.2011, 19:27   #7
В RR есть такой плагин SkinTool, он позволяет отлаживать скины, то есть смотреть значения индикаторов, переменных, отправлять команды скину.
Он работает и с iCar, но немного криво. А данная версия конкретно для работы с iCar.
Старый 14.02.2011, 21:17   #8
Psix_anp
Машина: Ford Focus2
Psix_anp is on a distinguished road
Super tool!
Готовое решение для Ford Focus2 (atom 1.6, RAM 2Gb, HDD 160Gb, Screen 7", GPS, Radio ГаГа)
Psix_anp вне форума   Ответить с цитированием
Старый 15.02.2011, 00:33   #9
Мишаня 121
Машина: BMW E46
Спс, разъяснил.
Старый 15.02.2011, 00:34   #10
Мишаня 121
Машина: BMW E46
Сообщение от pierrotm777 Посмотреть сообщение
Хороший плагин, полезный
Часовой пояс GMT +4, время: 11:42.
