Вернуться   PCCar.ru - Ваш автомобильный компьютер > Новости и Объявления > Новости
Старый 18.07.2010, 20:15   #1
aptm
Аватар для aptm
Машина: VW Passat Variant
По умолчанию Новые платы от commell
Две платы формат mini-ITX под i7-i5-i3:
первая LV-67C
Key Feature:
CPU: Intel® Core™ i7/ i5/ i3/ Pentium desktop in the LGA1156 socket.
Memory: Two DDR3 1066/1333 MT/s DIMM up to 8GB.
Chipset: Intel® BD82Q57 PCH.
Display Interface: Intel® 32nm Core™ i5/i3 integrated HD Graphics Technology, VGA and DVI output interface.
LAN Interface: 2 x Intel® 82574L Giga LAN.
Serial ATA: Support four SATAII up to 300MB/s with RAID 0,1,5,10.
Audio: Intel® Q57 integrated with Realtek ALC888 High Definition Audio.
I/O ports: 3 x RS232 and 1 x RS232/422/485 Serial Ports, 8 x USB2.0 ports, 1 x DB15 VGA port, 1 x PS/2 keyboard and mouse ports.
Extended interface: One x16 PCIe, 1 x Mini-PCIe & 1 x Mini-PCI socket.
GPIO interface: Onboard programmable 8-bit Digital I/O interface.
WatchDog Timer: 256-level generates NMI or system reset programmable watchdog timer.
Specification:
Form Factor Mini-ITX Motherboard
Processor Intel® Core™ i7 / i5 / i3 / Pentium® Desktop processor
Package Type: FCLGA1156
Bus Speed: 2.5GT/s DMI
Memory 2 x 240-pin DDR3 1066/1333 MT/s DIMM up to 8GB (ECC memory supportability depends on CPU)
Chipset Intel® BD82Q57 PCH (Platform Controller Hub)
Real Time Clock Chipset integrated RTC with onboard lithium battery
Watchdog Timer Generates a system reset with internal timer for 1min/s ~ 255min/s
Power Management ACPI 1.0 compliant, supports power saving mode
Serial ATA Interface Intel® Q57 PCH built-in 4 x Serial ATA II interface up to 300MB/s Support RAID 0, 1, 5, 10 and Intel® Rapid Storage Technology
VGA Interface Intel® Core™ integrated HD Graphics Technology
Video Memory Up to 1.7GB shared with system memory
Audio Interface Intel® integrated Q57 with Realtek ALC888 HD Audio
LAN Interface 2 x Intel® 82574L Gigabit Ethernet Controller
GPIO Interface Onboard programmable 8-bit digital I/O interface
Extended Interface One x16 PCIe, 1 x Mini-PCIe, 1 x Mini-PCI
Internal I/O Port 1 x RS232/422/485, 1 x GPIO, 1 x CDIN, 1 x SMBus, 1 x Audio, 1 x IrDA, 4 x USB2.0
External I/O Port 1 x PS/2 keyboard/mouse, 2 x RJ45, 1 x VGA, 4 x USB2.0, 1 x Audio, 3 x RS232
External Audio Line-in, MIC-in, Front, Rear, Center/Subwoofer and optical SPDIF
Power Requirement Standard 24-pin ATX power supply and P4 4-pin 12V. (20-pin is compatible)
Board Dimension 170mm x 170 mm (L x W)
Temperature Operating within 0 ~ 60°C Storage within -20 ~ 85°C
вторая LV-67F - аналог LV-67C, но на мобильном чипсете QM57 и под мобильный процессор.
Oдна Pico-ITX LP-170
CPU: Intel Atom N450/ D410 single core/D510 dual core processor 1.66GHz.
Memory: 1 x DDR2 SO-DIMM up to 2.0GB.
Chipset: Intel ICH8M Chipset.
VGA Interface: Intel integrated GMA 3150 technology.
LAN Interface: Intel 82583V Giga LAN.
LVDS: Onboard 18-bit single channel LVDS.
Serial ATA: Support 1 x SATAII interface with 300MB/s transfer rate.
Audio: HD Audio.
I/O Ports: 2 x RS232 Serial Ports,4 x USB2.0 ports, 1 x DB15 VGA port, 1 x PS/2 keyboard and mouse ports.
Solid State Disk: 1 x CompactFlash Type II socket.
Extended Interface: 1 x PCIE mini card socket.
WatchDog Timer: 256-level generates system reset programmable watchdog timer.
Power: 12VDC in.
Dimension: 100mm x 72mm
LV-67C и LP-170 доступны в Москве. Первая около 11т.р. , вторая в зависимости от конфигурации от 9 до 11.6 т.р.
Старый 04.08.2010, 20:12   #2
fmy1
Машина: 1/2
fmy1 is on a distinguished road
А где?
fmy1 вне форума   Ответить с цитированием
Старый 04.08.2010, 20:20   #3
aptm
Аватар для aptm
Сообщение от fmy1 Посмотреть сообщение
А где?
А тут
Старый 05.08.2010, 11:54   #4
fmy1
Машина: 1/2
А нету тут. Заказ 4-6 недель по предоплате. (касаемо LP-170)
Старый 05.08.2010, 13:37   #5
MiD_E34
Аватар для MiD_E34
а как у них с нагревом? Охлаждать сильно надо?
Андроид ГУ.
Старый 06.08.2010, 17:24   #6
fmy1
Машина: 1/2
На счёт малого нагрева - commell http://www.commell.com.tw/Product/SBC/LP-171.HTM LP 171
на Z510P
Старый 06.08.2010, 20:50   #7
Fasterpast
Машина: Suzuki Skywave 400
на Z510P
#VGA Interface: Intel® integrated extreme GMA 500 technology.
Вот этот адаптер - это ужасный ужас! На него дрова наисырейшие и не обновляются, даже чтобы включить поддержку OpenGL нужно шаманить с подставными библиотеками... Хотя HD видео играет )))
Старый 06.08.2010, 22:46   #8
fmy1
Машина: 1/2
Га-га...-гу-гу,. Кому, чем хочется заниматься.. ?
Кста..., извини, aptm - большое спасибо !!!
Старый 02.10.2010, 10:31   #9
aptm
Аватар для aptm
Еще одна плата формата mini-ITX - LV-67F, под мобильные процессоры core i3/i5/i7
Processor Intel® Core™ i7 / i5 / i3 Mobile processor
Package Type: rPGA988
Memory 2 x DDR3 800/1066 SO-DIMM up to 8GB
Chipset Mobile Intel® QM57 Express chipset
Power Management ACPI 2.0 compliant
Serial ATA Interface 6 x Serial ATA II interface up to 300MB/s.Support RAID 0/1/5/10
VGA Interface Integrated Intel® HD graphics Controller (depends on CPU).
LVDS Interface 24-bit dual channel LVDS interface
DVI Interface Optional DVI interface (LV-67FXD)
Audio Interface Intel® integrated QM57 with Realtek ALC888 HD Audio
Extended Interface PCI-Express X16 slot, Mini-PCIe & Mini-PCI socket.
External I/O Port 1 x PS/2 keyboard/mouse, 2 x RJ45 LAN, 1 x VGA, 6 x USB2.0, 1 x Audio, 1 x RS232, 1 x SPDIF
Power Requirement Standard 20-pin ATX power supply or DC 9 ~ 24V input
Если отвлечься от цены, которая наверняка будет не маленькой, в России скорее всего порядка 15 килорублей, то радует снижение потребления (TDP мобильного i5 от 18 до 35 W, а i7 до 45W) при очень хорошей производительности и набор слотов расширения, особенно на фоне конкурентов и вариант с встроенным источником питания. Жаль, что встроенный LVDS только 24bit и отсутствует HDMI.
Старый 12.10.2010, 17:15   #10
aptm
Аватар для aptm
Три модификации платы LV-67F, уже доступны под заказ и в Москве.
Oтличие в количестве видеовыходов: VGA+LVDS/VGA+DVI+LVDS/2xVGA+LVDS и в питании - 9...24V DC или ATX.
Цены, хотя и меньше чем я ожидал, но все же не радуют - первый вариант 13113 р., второй и третий по 13671 р.
Часовой пояс GMT +4, время: 07:10.
