Старый 04.10.2006, 11:07   #1
2func
Аццкий модер
Машина: 2000\Hyundai\Sonata4
По умолчанию Матери miniITX (чтобы не было вопросов)
P4 boards
Commell LV-670
Socket 478 Intel Pentium 4 / Celeron @ 533/400 MHz FSB
Intel Hyper-Threading Technology
Intel Embedded 845GV/ICH4 Chipset
Intel 845GV Built-in Extreme Graphics
Intel Dynamic Video Memory up to 64MB
Optional Single/Dual 18-/24-bit LVDS
Onboard Intel PRO/100+ LAN
5.1 Channel & S/P DIF AC97 3D Audio
Onboard IEEE 1394 Interface
Hi-Speed USB 2.0 with 480 Mbps
AV/S-Video TV-out Interface
IDE-based DiskOnModule SSD Interface
Compact Size @ 170 x 170 mm (L x W)
Commell LV-670M
Mobile Intel Pentium 4 / Celeron CPU
Intel Micro-FCPGA Package, 400 MHz FSB
1 GBytes DDR266/333 SDRAM
Intel NetBurst Microarchitecture
845GV GMCH Built-in Extreme Graphics
Single/Dual 18-/24-bit LVDS Interface
Onboard PCI IEEE 1394 Interface
i-Base MB877
PDF Link
Intel® Pentium 4, ATI RS400 Mini ITX Motherboard
Mini ITX (170mm X 170mm)
ATI RS400 Chipset, 400/533/800MHz FSB
Supports Intel® Pentium® 4, up to 3.8GHz
Built-in VGA, ATi M10 graphic core, support CRT or TV-out
PCI Express Gigabit LAN controller
Two DDR2 sockets support up to 2GB
Digital I/O, Serial ATA, one PCI slot, AC97
Four USB ports, four COM ports
i-Base MB870
PDF Link
Intel® Pentium 4, ATI RS300M Mini ITX Motherboard
Intel® Pentium® 4, 2.0GHz~3.2GHz
ATI RS300M Chipset, up to 800MHz FSB
Built-in VGA, AGP 4X, support CRT, TV-out & LVDS
Realtek 8100BL 10/100Mb LAN controller
One DDR socket supports up to 1GB Memory
i-Base MB850
PDF Link
Intel 845 chipset with Pentium 4 processor-based 845GV mini-itx motherboard
Intel® Pentium® 4 processor, 1.7GHz~3.06GHz
Intel® 82845GV built-in VGA, AGP 4X, support CRT
Optional Chrontel CH7017 LVDS supports LCD panel or TV Out
Digital I/O (4 in/4 out), one PCI slot, AC97, four USB ports, four COM ports
Инсталяция Hyundai Sonata 4
Прогресс [##########] - 100%
Старый 04.10.2006, 11:07   #2
2func
Аццкий модер
Pentium Mobile / Celeron boards
Commell LV-673
Intel Pentium M processor with Intel 915GM & ICH6M
dual channel DDR2 400/ 533 MHz SDRAM up to 2GB
Intel GMA 900 technology
Intel 915GM integrated
18-bit LVDS and analog TV-out interface
Onboard PCI-Express 16x and Mini-PCI socket
Support CompactFlash and PCMCIA on solder side
6 x USB2.0 , 2 x RS232 , 2 x SATA, 1 x SPDIF , 1 x IrDA , 1 x GPIO
Commell LV-671
Intel® Centrino™ Mobile Platform
Intel® Pentium® M Processor
On-die 1 MB L2 Cache, 400 MHz FSB
1 GBytes DDR266/333 SDRAM / ECC
Intel Extreme Graphics 2 Technology
Multiple Display LVDS / DVI / HDTV
Intel PRO/1000 GbE Interface
Intel PRO/Wireless WLAN 802.11a/b
Mini-PCI, PCMCIA PC Card Interface
IDE-based CompactFlash Interface
i-Base MB879
PDF Link
Intel® Pentium® M, ATI Radeon Express Mini ITX Motherboard
ATI Radeo Express 200 (RC410MD) Chipset,
Supports Intel® Pentium® M/ Celeron® M, up to 2.26GHz
Built-in VGA, ATi M10 graphic core, support CRT, TV out and LVDS
10/100 LAN and PCI Express Gigabit LAN controller
DDR2 socket support up to 1GB memory
Digital I/O, Serial ATA, 1394, one PCI slot
Six USB ports, four COM ports
i-Base MB890
PDF Link
Intel 855GME Pentium M mini-itx motherboard
Mini- ITX Form Factor (170mm X 170mm)
Intel® 855GME or 852GM Chipset
Supports Pentium® M / Celeron® M processors
Up to 2.0GHz, 400MHz FSB
1x DR DIMM, max. 1GB
Integrated VGA, shared memory, CRT/LVDS/DVI
Integrated 10/100 BaseT Ethernet
Watchdog timer, 6x USB 2.0 ports, PCI slot
Mini-PCI slot, optional 2x 1394
i-Base MB896
PDF Link
Socket 479 Pentium® M Mini-ITX Motherboard with Intel® 915GM Chipset
Supports up to 2.26GHz, 400MHz/533MHz FSB
One DDR2 SDRAM DIMM, Max. 1GB memory
Onboard 10/100 BaseT and Marvell PCI-Express Gigabit LAN
Intel® 915GM VGA for CRT / 18-bit dual channel LVDS
2x SATA, 6x USB 2.0, 2x COM, Watchdog timer, 1394
1x PCI, 1x MiniPCI, 1xPCI-E(x1) slots, optional single/dual DVI card
AOpen i915GMt
Intel Pentium M CPU (Dothan) Socket 479 533MHz
Chhipset: Intel 915GM Intel ICH6-M
Main Memory: Realtek (RTM865) Dual Channel Mode Support : DDRII 667/533/400 DDRII DIMM x 2 DIMM Type : 128/256/512MB & 1GB Max Memory : 2GB
Graphics: Integrated VGA Engine in chipset
IDE: Integrated ATA100 and Serial ATA Controller
LAN: Realtek Gigabit PCI LAN Chip
Sound: Azalia 7.1 channel codec on-board (ALC880) Integrated in chipset
Slots: PCI x 1
Storage & Back Pannel I/O: Adapter Connector x 1, IDE Channel : ATA100 x 1, Serial ATA Channel x 2, PS/2, Keyboard x 1, PS/2 Mouse x 1, DVI Connector x 1, VGA Port x 1, Standard Video x 1, 1394 Port x 1, LAN Port x 1, USB Port x 4, COM Port x 1, Line_In x 1, MC_In x 1, Speaker_Out x 1, Center/Subwoofer x 1, Rear Surround x 1, Side Surround x 1
On Board Connector: 4-pin 12V Connector x 1, CPU FAN x 1, System FAN x 1, Power Temperature Connector x 1, Front Panel x 1, USB Port x 4, COM Port x 1, IEEE 1394 x 1, S/PDIF x 1, CD_IN x 1
BIOS: Award PnP 4Mb Flash ROM BIOS
Form Factor: Flex ATX (mini ITX): 170 mm x 170 mm
PSU: Carnetix p1900
iGoLogic Inc MBI3368G
Processor - Compatible with Intel® Pentium M and Celeron-M LV (Low Voltage) /ULV (Ultra Low Voltage) CPU’s
Chipset - Intel® 852GM + ICH*4
System Memory - 1 x 184-pin DDR DIMM memory up to 1GB
VGA - Integrated in Intel® 852GM GMCH, max. up to 64MB frame buffer sharing system memory
Expansion Slots - 1 PCI
Onboard IDE - 2 x PATA-100 IDE
Onboard LAN - Dual LAN (One Gigabit & One Fast)
Onboard Audio - AC’97 codec audio
Onboard LVDS Out - 2 x LVDS display out
Back Panel I/O - 1 PS2 mouse port - 1 PS2 keyboard port - 2 RJ-45 LAN port - 3 Serial port - 4 USB 2.0 ports - 1 VGA port - 3 Audio jacks: line-out, line-in and mic-in
Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0 ports - 1 COM port - 1 Front-panel audio connector (Mic-in and Line-out) - 1 FIR connector - 2 Fan connectors: CPU/Sys FAN - 2 LVDS connectors - ATX power connector
Старый 04.10.2006, 11:08   #3
2func
Аццкий модер
Core Duo and Core 2 Duo boards
Kontron 986LCD-M/mITX
Intel® Core™ Duo and Core™ Solo Processors (mPGA478 socket, mBGA479 prepared), Support Yonah and Merom CPU core, Front Side Bus 533/667 MHz, Intel® 945GM + Intel® ICH7R Chipset, Intel® GMA950 graphic controller on board
Flat Panel Display Support, Dual independent Display Support (incl. 2x LCD)
1x 16x PCI-Express /SDVO external graphic card socket
2GB DDR2 memory support
3x 10/100/1000 Mbps Ethernet
8x USB 2.0, 4x RS232C, 2x IEEE1394, 1x ATA100 and 4x SATA150/300 IDE Controller, 1x Compact Flash socket, 1x mini PCI-Express socket for easy expansion of i.e. wireless LAN
On board RAID 0/1/5/10 support with SATA harddisk
7.1ch HDA / AC-97compliant audio output
Size: 170 x 170 mm (6.7" x 6.7")
i-Base MB899
PDF Link
Socket 478 Intel® Core® Duo Mini-ITX Motherboard
Socket 478 for Intel® Core™ Duo /Solo processors
Mobile Intel®; 945GM Chipset, Two DDR2 DIMM sockets
Supports CRT, LVDS, optional TV out or DVI
10/100 BaseT LAN, PCI Express Gigabit LAN
SATA x2, USB x6, Digital I/O, Watchdog timer
PCI x1, PCI-E (x1) x1, Mini PCI x1, Mini PCIe x1
AOpen i945GTt
INTEL Core Duo i945GTt
CPU: Intel Core Duo/Core Solo CPU (Yonah)
Chipset: Intel 945GT Intel ICH7MDH
Main Memory: Dual Channel Mode Support : SO-DIMM DDRII 667/533/400, SO-DIMM DDRII 667/533/400 x 2, 128/256/512MB & 1GB x 2, Max Memory : 2GB
LAN: Intel Gigabit PCI Express LAN chip
Sound: Azalia 7.1 channel codec on-board (ALC882D)
Slots: PCI Express (PCIe x1) x 1, Mini PCI x 1
Storage & Back Panel I/O: Adapter Connector x 1, IDE Channel : ATA100 x 1, Serial ATA Channel x 2, PS/2 Keyboard x 1, PS/2 Mouse x 1, DVI Connector x 1, Standard Video x 1, 1394 Port x 1, LAN Port x 1, USB Port x 4, COM Port x 1, Line_In x 1, MIC_In x 1, Speaker_Out x 1, Center/Subwoofer x 1, Rear Surround x 1, Side Surround x 1
On Board Connector: 4-pin 12V Connector x 1, CPU FAN x 1, System FAN x 1, Front Panel x 1, USB Port x 2, COM Port x 1, COM2 x 1, IEEE 1394 x 1, S/PDIF x 1, CD_IN x 1
BIOS:Award PnP 4Mb Flash ROM BIOS
Commell LV-677
CPU: Intel Core Duo and Intel Core Solo processors @ 667MHz FSB.
Memory: 2 x 240 pin DDR2 533/667MHz up to 4.0GB.
Chipset: Intel 945GM and ICH7-M.
VGA Interface: Intel 945GM integrated GMA 950 Technology.
LVDS Interface: 18-bit dual channel LVDS interface.Supports up to WUXGA panel resolution.
TV out: HDTV built-in.
LAN Interface: Intel 82537L PCIE Giga LAN
PCI Enhanced IDE: UltraATA100 IDE up to 2 ATAPI .
Serial ATA: Integrated Serial ATA controller facilitates high-speed data transfers at up to 150 MB/s for each of 2 ports.
Audio: Intel ICH7-M integrated with Realtek ALC880 High Definition Audio.
I/O Ports:1 x RS232 and 1 x RS232/422/485 Serial Ports, 1 x Parallel port, 6 x USB2.0 ports, 1 x DB15 VGA port, 1 x IEEE1394, 1 x PS/2 keyboard and mouse ports.
Extended Interface: One PCI Express x 16 bus add-in card connector, 2 x Mini-PCI socket
SSD: IDE1 supports DOM, 1 x CompactFlash socket (underneath board)
GPIO Interface: Onboard programmable 8-bit Digital I/O interface.
Power supply: ATX P/S or DC 8~21V used optional.
Power requirements : Most core duo use a max of 31watts, and the DC board version has built in regulator so you only need a uSDC20A from mpegbox and you will get ypur 12V/5A + 5V/3A onboard regulated for devices such as hd's and usb hubs. The onboard regulator also survives engine cranking and ranges from 8 to 21 Vdc
Endura TP945GM
Intel® Core™ Duo, Celeron® M, LV and ULV processors
Intel® 945GM Express chipset; 667/533MHz Front-Side Bus
Two DIMM sockets; Up to 4GB DDR2-667 memory; Dual-Channel memory
Intel® GMA950 Graphics; x16 PCI Express graphics slot; 18-bit, dual channel LVDS; TV-out header; VGA output; Dual independent displays
Intel® High Definition Audio; Eight channel CODEC for 7.1 audio; S/PDIF digital audio output
Mini-PCI Type lllA socket; PCMCIA Type II socket; Compact Flash Type I socket
Single or dual Gigabit Ethernet; Eight USB 2.0 ports; Four RS-232 serial ports
PS/2 keyboard and mouse ports; IrDA interface
Two SATA 1.5 Gbps ports; One Ultra ATA100 port
Phoenix TrustedCore™ BIOS
TPM 1.2 header
GPIO port
ACPI 3.0
RoHS compliant
AMD mobile boards
Jetway J7F3 Series
PDF Link
SiS 741CX Northbridge + SiS 964 Southbridge Chipsets
Support Socket-462 AMD Geode NX processor
Support Front Side Bus 133MHz
Single Channel DDR2 400 Memory DIMM
Support 2 Serial ATA Devices with RAID 0, 1
Support 2xAD Connector With Expansion Daughter-boards
Ethernet LAN Supported
AC’97 6 Channel Audio CODEC
VIA VT6307S IEEE1394a Controller for J7F3E
17 x 17CM Mini-ITX Form Factor
i-Base MB740
PDF File
AMD Geode NX Mini ITX Motherboard
Socket A for AMD Geode NX processors
Up to 1.4GHz speed, 133MHz FSB
DDR DIMM x 1, Max. 1GB, DDR266/333
Onboard 10/100 and Realtek 8110S Gigabit Ethernet
Integrated SiS 741CX VGA, supports CRT
Optional LVDS/TV-out, DVI/CRT2 MAGP VGA cards
2 x SATA, 6 x USB 2.0, 2 x COM, Watchdog timer
1x PCI, 1x Mini PCI, 1x MicroAGP, optional 1394
Albatron KI51PV-754
AMD Athlon™ 64 / Sempron™ /Turion™ 64 Processors
Socket 754 with Hyper Transport?800+ MHz
1 DDR333/400 Memory Sockets
Integrated NVIIDA GeForce 6150 Graphics Engine.
Provides DVI / D-SUB / HDTV-out (by optional cable) interface.
Realtek AC97 6 channel
Marvell 10/100 Mbps LAN PHY / Marvell Gbit LAN & NVIDIA Active Armor
1*PCI Solt
4 SATA II Channels, SATA RAID 0,1,5& 0+1
2 ATA133 Channels
Dual BIOS (Second BIOS by Optional ABS Card)
8 USB 2.0/1.1 Ports (4 ports by optional cable)
Старый 04.10.2006, 11:08   #4
2func
Аццкий модер
VIA boards
VIA EPIA CN13000
1.3GHz/1.0GHz VIA C7 nanoBGA2 Processor
VIA CN700 North Bridge
VIA VT8237R-Series South Bridge
System Memory -1 DDR2 400/533 DIMM socket, Up to 1GB memory size
Integrated VIA UniChrome™ Pro AGP graphics with MPEG-2 decoding acceleration
Onboard IDE - UltraDMA 133/100/66 Connectors
Onboard LAN - VIA VT6103 LAN Controller
Onboard Audio - VIA VT1618 8-channel AC'97 Codec
Back Panel I/O -1 PS2 mouse port; 1 PS2 keyboard port; 1 Serial port; 1 VGA port; 1 RJ45 port; 4 USB 2.0 ports; 1 RCA port (S/PDIF or TV out); 1 S-Video port; 3 Audio jacks: line-out, line-in and mic-in (Horizontal, Smart 5.1 Support)
Onboard I/O Connectors - 1 USB connector for 4 additional USB 2.0 ports; 2 SATA Connectors; 1 Front-panel audio connector (Mic and Line Out); 1 CIR connector (Switchable for KB/MS); 1 LPT connector; 1 CD-in connector; 2 Fan connectors: CPU/Sys FAN
VIA EPIA EN15000
1.5GHz/1.2GHz VIA C7 nanoBGA2 Processor
System Memory - 1 DDR2 400/533 DIMM socket, Up to 1GB memory size
Integrated VIA UniChrome™ Pro AGP graphics with MPEG-2 decoding acceleration Expansion Slots - 1 PCI
Onboard IDE - 2 UltraDMA 133/100/66 Connectors
Onboard LAN - VIA VT6122 GLAN Controller
Onboard Audio - VIA VT1618 8 channel AC'97 Codec
Onboard 1394 - VIA VT6307S IEEE 1394 Firewire
Back Panel I/O - 1 PS2 mouse port; 1 PS2 keyboard port; 1 Serial port; 1 VGA port; 1 RJ45 port; 4 USB 2.0 ports; 1 RCA port (S/PDIF or TV out); 1 S-Video port; 3 Audio jacks: line-out, line-in and mic-in (Horizontal, Smart 5.1 Support)
Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0 ports; 1 1394 connector for 1 1394 port; 2 SATA Connectors; 1 LPC connector; 1 Front-panel audio connector (Mic and Line Out); 1 Serial port connector for a second com port; 1 CIR connector (Switchable for KB/MS); 1 SIR pin header (IrDA 1.0); 2 Fan connectors: CPU/Sys FAN; 1 SMBUS connector; 1 S/PDIF in connector; 1 S/PDIF out connector; 1 LVDS/TTL/DVI module connector (an add-on card is required); 1 Component (YPbPr) video pin header
VIA EPIA SP13000 and SP8000
VIA C3™/ VIA Eden™ EBGA processor
VIA CN400 North Bridge
System Memory - 1 DDR266/333/400 DIMM socket. Up to 1GB memory size
VGA - Integrated VIA UniChrome™ Pro AGP graphics with MPEG-2 decoder /MPEG-4 Accelerator
Onboard IDE - 2 X UltraDMA 133/100 Connector
Onboard Serial ATA - 2 SATA Connectors
Onboard LAN - VIA VT6103 10/100 Base-T Ethernet PHY
Onboard Audio - VIA VT1617A 6channel AC'97 codec
Back Panel I/O - 1 PS2 mouse port; 1 PS2 keyboard port; 1 RJ-45 LAN port; 1 Serial port; 2 USB 2.0 ports; 1 VGA port; 1 PCA port (SPDIF or TV out); 1 S-video port; 3 Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
Onboard I/O Connectors - 3 USB connector for 6additional USB 2.0 ports; 1 1394 connector for 1 1394 port; 1 Serial port connector for a second com port; 1 VIP connector; 1 Front-panel audio connector (Mic-in and Line-out); 1 CD audio-in connector; 1 FIR connector; 1 CIR connector (Switchable for KB/MS); 1 LPT port connector; 1 Wake-on-LAN connector; 2 Fan connectors: CPU/Sys FAN; 1 I2C connector; 1 LVDS/TTL module connector (Optional); 1 +12V power connector
VIA EPIA ML6000 and ML8000
VIA CLE266 North Bridge
VIA VT8235M South Bridge
System Memory - 1 DDR266 DIMM socket, Up to 1GB memory size
VGA - Integrated VIA UniChrome AGP Graphics with MPEG-2 Accelerator
Onboard IDE - 2 X UltraDMA 133/100/66 Connectors
Onboard Audio - VIA VT1616 6 channel AC' 97 codec
Back Panel I/O - 1 PS2 mouse port; 1 PS2 keyboard port; 1 Parallel port; 1 RJ-45 LAN port; 1 Serial port; 2 USB 2.0 ports; 1 VGA port; 3 Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
VIA EPIA MII12000 and MII10000 and MII6000
VGA - Integrated VIA Unichrome AGP graphics w/MPEG-2 Accelerator
Onboard Floppy - 1 x FDD Connector
Onboard Audio - VIA VT6103 10/100 Base-T Ethernet PHY
Onboard 1394 - VIA VT6307S IEEE 1394 (Optional)
Onboard CardBus / CompactFlash - CardBus Type I & Type II; Ricoh R5C476 II / R5C485 CardBus Corntroller
Back Panel I/O - 1 CardBus Type I and Type II slot +1 CompactFlash Slot; 1 CompactFlash slot; 1RJ-45 LAN port; 1 PS2 mouse port; 1 PS2 keyboard port; 1 Serial port; 2 USB 2.0 ports; 1 VGA port; 1 RCA port (SPDIF or TV-Out); 1 S-Video port; 1 1394 port; 3 Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0 ports; 1 Front-panel audio connectors (mic-in and line-out); 1 CD Audio-in connector; 1 FIR connector; 1 CIR connector (Switchable for KB/MS); 1 Wake-on-LAN connector; 1 LPT port header; CPU/Sys FAN/Fan 3; 1 Connector for LVDS module (Optional); 1 Serial port connector for second COM port
VIA EPIA M10000 and ME6000
VGA - Integrated VIA Unichrome AGP graphics with MPEG-2 Accelerator
Onboard Audio - VIA VT1616 6 channel AC'97 Codec
Back Panel I/O - 1 PS2 mouse port; 1 PS2 keyboard port; 1 Parallel port; 1 RJ-45 LAN port; 1 Serial port; 2 USB 2.0 ports; 1 VGA port; 1 RCA port (SPDIF or TV out); 1 S-Video port; 3 Audio jacks: line-out, line-in and mic-in; can be switched to 6 channel output
Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0 ports; 2 1394 connectors for 2 1394 ports; 1 Front-panel audio connector (Mic and Line Out); 1 CD Audio-in connector; 1 FIR connector; 1 CIR connector (Switchable for KB/MS); 1 Wake-on-LAN connector; CPU/Sys FAN/Fan 3; 1 SMBUS connector; 1 Connector for LVDS module1 Serial port connector for a second com port
VIA EPIA 800 and 5000
VIA C3/EDEN EBGA Processor
VIA PLE133 North Bridge
VIA VT8231 South Bridge
System Memory - 2 PC133 DIMM sock, Up to 1 GB memory size
VGA - Integrated AGP 4X Graphics
Onboard LAN - VIA VT6103 PHY 10/100 Ethernet
Onboard Audio - VIA VT1612A 2 channel AC'97 Codec
Back Panel I/O - 1 PS2 mouse port, 1 PS2 keyboard port, 1 VGA Port, 1 Parallel, 1 RJ-45 LAN port, 1 RCA port (SPDIF or TV out), 1 S-Video port, 2 USB 1.1 ports, 1 Serial port, 3 Audio jacks: line-out, line-in and mic-in
Onboard I/O Connectors - 1 USB connector for 2 USB 1.1 ports, 1 CD Audio-in connector, 1 FIR connector, 1 CIR connector, 1 PS2 connector, 1 CPU/Sys FAN
Jetway 627F Series
PDF Link
Support VIA C3 processor in EBGA packaging, for 133MHz Front Side Bus Frequency
VIA VT8623 North Bridge
VIA VT8235 High Bandwidth Vlink Client South Bridge
1 x 184-pin DDR Module Sockets Support Max 1GB, 2.5V DDR266 DDR SDRAM
Support 2 x Ultra DMA 133 IDE Interface
128bit 2D/3D graphics engine
Support NTSC/PAL TV system S-Video/AV Output
6xUSB 2.0 Ports, 1xParallel Port
Jetway / Phylon / Versa / Vista J7F2WE
PDF Link
VIA CN700 Northbridge + VT8237RP Southbridge Chipsets
Chipset (MCP51G)
Support VIA C7 Nano-BGA processor
CPU core speed
1G0 is 1.0GHz C7 CPU [All]
1G2 is 1.2GHz C7 CPU [Jetway Only]
1G3 is 1.3GHz C7 CPU [Phylon Only]
1G5 is 1.5GHz C7 CPU [All]
VIA VT6307S IEEE1394a Controller for J7F2E / J7F2WE
Jetway J7F4 Series
PDF Link
VIA VT1622A TV encoder
Старый 04.10.2006, 11:09   #5
2func
Аццкий модер
и еще куча всего, торжественно передрано отседова: http://www.mp3car.com/vbulletin/showthread.php?t=82299
Старый 31.01.2007, 01:30   #6
aptm
Аватар для aptm
Машина: VW Passat Variant
Еще одна материнка mini-ITX IEI KINO-9452 на i945GM
Процессор Сокет 479, процессор Intel® Core Duo/Solo, FSB 667 МГц
Чипсет Intel® 945GM + ICH7M
BIOS AMI BIOS
Оперативная память 2 x 240-конт. двухканальный DDR2 677/533/400 МГц объемом до 2 Гб
Ethernet Двойной BROADCOM BCM5787 PCI-E GbE с удаленным управлением ASF2.0
Интерфейсы 8 x USB 2.0
2 x SATAII-300
3 x RS232
1 x RS232/422/485
2 x PS/2 Mini DIN (клавиатура/мышь)
1 x IDE
1 x mini PCI (слот расширения)
1 x PCI (слот расширения)
Звуковой контроллер Realtek ALC883 с интерфейсом HD 7.1 с поддержкой 2 аудиопотоков
Цифровой вход/выход 8-битный, 4 входа / 4 выхода
Интерфейсная микросхема ITE8712
Дисплей Встроенный в чипсет Intel 945GM поддержка формата HDTV-Out, два 18-битных LVDS, VGA
HDTV-Out: Macrovision, Overscaling, Component, S-Video, Composite-Video
480P / 720P / 1080i / 1080P / NTSC / PAL
Сторожевой таймер Программно регулируемый интервал перезапуска системы от 1 до 255 с.
Питание Поддержка AT/ATX
Потребление питания +5 В@1.58 А, +12 В@2.05 А, +3,3 В@3.12 А, +5 В(ст)@0.32 А ((Intel® Core Duo 2.16 ГГц, DDRII 1Гб*2) -- 3D MARK)
Рабочая температура 0°C-60°C
Влажность 5%-95%, без конденсата
Размер (Ш x В) (мм) 170 x 170
По сравнению с Commell LV-677, которая у меня, нет:
второго mini-PCI
PCI-E
разьема FDD
CF
На мой взгляд плюсы:
- SATA-II
- 8-ми канальный звук
- можно купить в Москве
минусы:
оптический аудиовыход
крайне не удачно расположен ICH7 - под картой, если такая будет, mini-PCI, что крайне затруднит в этом случае охлаждение микросхемы северного моста. А греться он при навеске переферии на USB будет неслабо, чтобы они там на диаграммах не показывали.
P.S. У меня с даже зимой температура доходила до 50°С при работе видеокамеры, TV тюнера с подключеной второй видеокамерой, так что не дожидаясь лета, поставил вентилятор.
Последний раз редактировалось aptm; 31.01.2007 в 05:23.
Старый 09.03.2007, 21:36   #7
Sanyk
Почетный лекарь
Аватар для Sanyk
Машина: Ford Focus II
Sanyk will become famous soon enoughSanyk will become famous soon enough
Новые mini-itx матери от MSI
Fuzzy 945GM1[ MS‑7265 ]
CPU
- Supports Intel® Yonah (Intel® Core™ Duo/ T2000 Seqence) and Merom (Intel® Core™ 2 Duo/ T5000 & T7000 Sequence) processor up to 2.33GHz (Napa Platform) in PGA Package
- 2MB L2 cache (Yonah) / 4MB (Merom)
- Supports 3 pin CPU Fan Pin-Header with Fan Speed Control
- Supports EIST Technology
- Supports Intel® Core™ Microarchitecture
- Supported FSB: 667/533 MHz
Chipset
- North Bridge: Intel® 945GM
- South Bridge: Intel® ICH7-MDH (82801GHM)
Memory Support
- DDRII 533/667 SDRAM (4GB Max)
- 2 DDRII DIMMs (240pin / 1.8V)
Slots
- 1 PCI v2.3 slot (for standard PCI add-on card)
On-Board IDE
- 1 IDE port by Intel® ICH7-MDH
- Supports Ultra DMA 66/100 mode
- Supports PIO, Bus Master operation mode
On-Board SATA
- 2 SATAII ports by Intel® ICH7-MDH
- Supports two SATAII devices
- Supports storage and data transfers at up to 300MB/s
LAN
- Supports Dual Intel® 10/100/1000 LAN by two Intel® 82541PI Giga- LAN controller)
Audio
- Chip integrated by Realtek® ALC658
- Flexible 5.1-channel audio
- Compliant with AC97 Spec
Connectors
Back Panel
- 1 PS/2 mouse port
- 1 PS/2 keyboard port
- 2 serial ports (COM ports)
- 4 USB 2.0 ports
- 2 LAN jacks 10/100/1000
- 3 audio jacks (1 Line-In, 1 Line-Out, 1 Mic-In)
- 1 D-Sub Graphics Card port
- 1 DVI port
Onboard Pinheaders
- 1 CD-In
- 2 USB 2.0 pinheaders
- 1 front audio connector
Fuzzy 945GM2[ MS‑9642 ]
CPU
- Intel® Core 2 Duo/Core Duo/Core Solo/Celeron M CPU in Socket M
- Supports Intel Dual Core Technology to 533/667MHz and up
- Supported FSB: 533/667MHz
Chipset
- North Bridge: Intel® 945GM chipset
- South Bridge: Intel® ICH7M chipset
Memory Support
- DDRII 533/667 SDRAM (2GB Max)
- 1 DDRII DIMM slot (240pin / 1.8V)
Slots
- 1 PCI Express x16 slot (supports MS-V004 ADD2 DVI Card)
- 1 PCI Express x 1 slot
- 1 PCI 32-bit/33MHz slot
On-Board IDE
- 1 IDE port by ICH7M
On-Board SATA
- SATA ports by ICH7M
- Supports two SATA devices
- Supports storage and data transfers at up to 150MB/s
LAN
- Supports 3 PCI Express Gb Ethernet by Intel 82573L or one Intel 82562GZ 10/100 LAN (optional)
Audio
- HDA Codec by Realtek® ALC888 7.1 channel
- Compliant with Azalia 1.0 Spec.
- 6 watt amplifier (optional)
Connectors
Back Panel
- 3 RJ-45 LAN jacks
- 2 USB 2.0 ports
- 1 D-Sub Graphics Card connector
- 1 serial port
- 1 PS2 keyboard/mouse port
- 1 Line-In/Line-Out/Mic-In stacked audio jack
Onboard Pinheaders
- 1 USB 2.0 pinheader (2 ports)
- 1 parallel port pinheader
- 1 f ront audio pinheader
- 1 LVDS connector
- 1 Digital I/O pinheader (16GPIO)
- 1 RS232/422/485 COM port header for COM2~COM5 (optional)
- 1 front panel pinheader
Интересно?
Сейчас будет ещё интереснее!!!
Цена, например на www.logicsupply.com, хотя доставка только в США:
Fuzzy 945GM1[ MS‑7265 ] 220$
Fuzzy 945GM2[ MS‑9642 ] 235$
Моя установка Ford Focus 2
Sanyk вне форума   Ответить с цитированием
Старый 14.03.2007, 22:44   #8
LKnight
Машина: Pajero 5D 3.5GDI 2001
LKnight is on a distinguished road
А в тему матерей, кроме выше(в начале) упомянутой AOpen i945GTt, у них есть и гораздо (имхо) более вкусный вариант матери.
Но о нём чуть ниже, а пока про 945 - полный индекс -
i945GTt-VFA
И она поддерживает не только Yonah, а
Intel Core 2 Duo/Core Duo/Core Solo CPU (Merom/Yonah)
Socket 479
Например, продающийся конструктор idid i345
http://www.aopen.ru/products/mb/
Socket 479 667MHz
Chipset: Intel 945GT / 945GM (Option)+Intel ICH7M-DH / ICH7M (Option)
Memory: Dual Channel Mode Поддержка : SO-DIMM DDRII 667/533/400,SO-DIMM DDRII 667/533/400 x 2, 256/512MB & 1GB x 2, Max Memory : : 4ГБ
Graphics: Integrated VGA Engine in chipset (Intel GMA 950)
Max Disk: : 144,000,000GB [by 48 bits LBA Spec.]
LAN: Intel / Realtek Gigabit PCI LAN Chip (Option)
звук: Azalia Codec on-Board 7.1 Channel and above
USB: Integrated in chipset USB2.0 x 8
IEEE 1394: Agere 1394 Control Chip
Слоты: PCI Express (PCIe x1) x 1, Mini PCI x 1
IDE Channel : (1)асинхронный терминальный адаптер (2)ATA 100 (英俄通用) x 1
серийный канал АТА II x 2
Клавиатура PS/2 x 1
Мышь PS/2 x 1
DVI Connector x 1
Standard Video x 1
1394 порт x 1
LAN Port x 1
USB Port x 4
COM Port x 1
Line_In x 1
MIC_In x 1
звукоговорящий_выключен x 1
Rear Surround x 1
Side Surround x 1
Встроенный Соединитель 4-pin 12V Connector x 1
CPU FAN x 1
Вентилятор x 1
Front Panel x 1
USB Port x 2
COM Port x 1
COM2 x 1
IEEE 1394 x 1
S/PDIF x 1
CD_IN x 1
BIOS Award PnP 4Mb Flash ROM BIOS
Form factor Flex ATX (mini ITX)
Board Size 170 mm x 170 mm
Может кому поможет
зы. на днях попытаюсь у AOpen узнать думают ли они везти этих зверей в мск или нет, если будут интересные новости - отпишу
LKnight вне форума   Ответить с цитированием
Старый 26.03.2007, 10:42   #9
Большой
Местный Бог Акустики
Аватар для Большой
Машина: 2007 Hyundai Elantra
Большой is on a distinguished road
По умолчанию Ещё одна mini-ITX плата под Athlon
Albatron KI690-AM2
Дал бы характеристики, но информация пока скудная.
Прогресс нас убьет, но как упоителен сам процесс
Большой вне форума   Ответить с цитированием
Старый 07.04.2007, 14:23   #10
Sanyk
Почетный лекарь
Аватар для Sanyk
Новая mini-itx материнка Commell LV-676
Intel Core 2 Duo LGA775 Desktop /Pentium D processor with Intel Q965
CPU: Intel Core 2 Duo Desktop / Pentium D / Pentium 4 with LGA775 @ 533/800/1066 MHz FSB. ( Extreme Edition processor don't support )
Memory: 2 x 240-pin DDR2 533/667/800MHz!!! up to 3.0GB.
Chipset: Intel Q965 and ICH8DO.
VGA Interface: built-in Intel extreme GMA 3000 technology.
DVI / LVDS Interface: Optional Onboard DVI or LVDS interface .
Serial ATA: 6 x Serial ATA II interface with 300MB/s transfer rate.Support RAID 0,1,5,10
LAN Interface: 2 x Intel 82573L Gigabit Ethernet Controller.
Audio: Realtek ALC888 High Definition Audio.
IEEE 1394: 2 x IEEE1394 port.
GPIO interface: Onboard 8-bit Digital I/O interface.
Extended interface: 1 x Mini-PCI socket and 1 x PCI slot
I/O ports: LAN ports , RS232/422/485 ports , USB 2.0 ports , IEEE 1394 , IrDA , S/PDIF , Audio
Даташит
Цена девайса пока не известна.
Часовой пояс GMT +4, время: 16:48.
