Старый 09.06.2009, 01:52   #51
Beer100
Аватар для Beer100
Машина: 2002\Audi\A6 3.0i
Z@GR, намекни товарисчу, что у нас ни кто не обидется, если он свой прожект покажет. ;-)
Старый 09.06.2009, 03:26   #52
Z@GR
Аватар для Z@GR
Сообщение от malavita Посмотреть сообщение
Z@GR balsoi spaciba!!
Παρακαλώ! Είμαι στην ευχάριστη θέση να βοηθήσει.
I immagine then that you have an ON/OFF controller to open the pc remotely.Right? I spoke with Saturn-ht.ru and they told me that if my motherboard has wake up from USB then when i press POWER ON on the Prology the USB (Touch screen) wake up the PC..
How you work with it?
Is it a good monitor in general? Do i have to watch out something?
About inclusion of the PC from USB when I press POWER ON - I did not spend such experiment and unfortunately to spend now I have no possibility because the monitor has established in the car the day before yesterday, and the computer meanwhile is not present.
About the monitor : "On a table" using the monitor even was pleasant, despite discussion of the given model in a profile theme was not found out in me a considerable part of lacks sounded by other users. it was not pleasant that the touch panel somehow strange conducts itself along the edges of the screen. Like it is calibrated on 25 points and in the central part of the screen all is normal, and along the edges somehow inertly reacts to pressing and is mistaken that-whether a little; in general it is strange. 1 day of continuous work of the monitor "on a table" has revealed that the screen case is heated as the battery))). Gaugings have shown that the monitor consumes 10 watt at connection to the accumulator with pressure of 12.55 volt.
After dismantling \assemblage (accurate) for the resoldering of light-emitting diodes on red instead of regular dark blue something somewhere falls off, therefore the monitor ceases to react to pressing of buttons. From here the CONCLUSION : the monitor too gentle!
P.S. Colleagues on a forum asked to hint that we would be not against to look and estimate your project if it at you somewhere is described...
I also use online translation to understand your perfect forum. I wish it was in English too..
Я также использую перевод онлайн, чтобы понять ваш прекрасный форум. Мне жаль, что это не на английском языке также..
спасибо очень
By the way you can use the translator of sites (NOT ADVERTISING). I think in general it will be clear about what there is a speech.
намекнул ;-)
Старый 09.06.2009, 12:10   #53
malavita
Регион: Греция
malavita is on a distinguished road
Конечно я скажу Вам о моих проектных друзьях. Пока я скажу Вам систему и картины, которые я дам через 2 недели, когда я заканчиваю. Мой автомобиль - черокез Джипа 2003 3.7
http://www.magicom.gr/store/index.ph...oduct_id=29882
http://www.matrixcarpc.com/product_i...roducts_id=356
http://www.matrixcarpc.com/product_i...roducts_id=294
http://www.matrixcarpc.com/product_i...roducts_id=301
http://www.matrixcarpc.com/product_i...roducts_id=299
http://www.matrixcarpc.com/product_i...roducts_id=352
http://www.matrixcarpc.com/product_i...roducts_id=256
http://www.matrixcarpc.com/product_i...roducts_id=264
http://www.matrixcarpc.com/index.php?cPath=86_119
http://www.matrixcarpc.com/product_i...roducts_id=313
+ Prology PCM-750T
Я надеюсь, что все, что я пишу, входит в удобочитаемый русский язык
malavita вне форума   Ответить с цитированием
Старый 09.06.2009, 13:04   #54
Z@GR
Аватар для Z@GR
+ Prology PCM-750T
Well done
I liked the case!
Configuration PC the normal.
If there is a desire and possibility - place the project a separate theme in section "Workolog" and tell about its advancement.
Transfer turns out not ideal, but the sense is clear.
Старый 09.06.2009, 14:30   #55
malavita
Регион: Греция
Конечно я буду! Я видел все проекты. Я понимаю основные российские слова как работа. P.S я люблю Москву так. Я приеду снова в сентябре
Старый 09.06.2009, 15:53   #56
Z@GR
Аватар для Z@GR
Ждём размещения Вашего проекта на нашем форуме - если будут вопросы - обращайтесь, поможем.
Старый 16.06.2009, 20:29   #57
Z@GR
Аватар для Z@GR
Exclamation UPDATE
Добавил описание подключения монитора и организации питания монитора и компа
Старый 17.06.2009, 14:51   #58
Z@GR
Аватар для Z@GR
Question питание монитора
Питание монитора сейчас сделано так:
ACC монитора подключил к штатному разъему магнитолы на клемму с названием "CLK".
На этом контакте разъема появляется 12 вольт если включить зажигание или если с выключенным зажиганием включить магнитолу.
в момент запуска двигателя монитор конечно-же выключается
иногда и магнитола штатная бывает выключается и включается
я вот думаю может поставить на монитор (как минимум) а может и на магнитолу какой-то DC-DC инвертор типа
такой ?!?!?
Описание:
Наименование: PSD-15B-12
Производитель: Mean Well
Pвых, Вт : 15
Uвх, В : 18-36
Uвых, В: 12
Iвых, А: 0-1,25
Разм., мм: 94х49х25
Вес, кг: 0,081
Основные параметры:
Широкий диапазон входного напряжения: 2:1
Электрическая прочность изоляции: вход-выход 2000 В
Защита от КЗ, перегрузки, перенапряжения
Защита от перегрева у моделей PSD-05
Естественное охлаждение
Встроенный фильтр электромагнитных помех, низкий уровень шумов и пульсаций
Прогон при 100% нагрузке
Соответствуют требованиям директив LVD (низковольтная аппаратура) и EMC (электромагнитная совместимость), получили знак CE
Цена одной штуки: : 368,70 руб.
Или даже лучше такой
Описание:
Наименование: SD-15B-12
Pвых, Вт : 15
Uвх, В : 18-36
Uвых, В : 12
Iвых, А : 0-1,25
Основные параметры DC/DC преобразователей серии SD:
Диапазон входного напряжения: 2:1;
Электрическая прочность изоляции: 1,5 кВ DC
Комплекс защит: от короткого замыкания, перегрузки, перенапряжения;
Защита от перегрева у моделей SD-350;
Встроенный фильтр помех;
Все модули проходят прогон
Возможность подстройки выходного напряжения
Диапазон рабочих температур: -10...+60 °C
-20...+60 °C (для SD-200, SD-350)
Сертифицировано: UL, CUL, TUV, CE
Масса SD-15 0,18кг
Цена одной штуки: : 519,04 руб.
Последний раз редактировалось Z@GR; 18.06.2009 в 21:08.
Старый 17.06.2009, 15:02   #59
Beer100
Аватар для Beer100
А это разве проблема?
Ни когда на это не обращал внимания даже. Этоже секунда-две.
Старый 17.06.2009, 15:41   #60
Z@GR
Аватар для Z@GR
да - конечно, но он не включатся обратно, он остаётся в выключенном виде (то есть звук через монитор продолжает идти, а сам экран гаснет) и для его включения (вернее перевключения) нужно нажать кнопку "POWer" 2 РАЗа
и ещё я заметил, что с подключенным монитором и адаптером CAR2pc В момент запуска мотора при выключении магнитоллы делает хлопок штатный саб (в крыле который) чего не происходит вроде как при аналогичном выключении с включенным радио на магнитолле
короче пустячОк - а напрягает немного - хочется чтобы всё работало "как надо" (всё-таки мы тут уже гуру как ни как)))))
audi, car2pc, gps oem, prology pcm-750t, корпус из оргстекла
Часовой пояс GMT +4, время: 01:24.
