Результаты опроса: Do you think to use it ?
yes 19 100.00%
no 0 0%
Голосовавшие: 19. Вы ещё не голосовали в этом опросе
Старый 22.02.2011, 20:07   #21
pierrotm777
Аватар для pierrotm777
Smile
Сообщение от format_c Посмотреть сообщение
нету ссылки
Sorry , i have an issue with this version
Старый 23.02.2011, 17:27   #22
pierrotm777
Smile V0.6
You can download this new version
Старый 02.03.2011, 18:19   #23
pierrotm777
Smile v0.7
Please, see first post
Старый 03.03.2011, 16:41   #24
pierrotm777
Smile v0.8
Little update for a best compatibility with Vista and seven !
Старый 03.03.2011, 22:59   #25
pierrotm777
По умолчанию v0.9
The 'Live Debug Log' is ok NOW .
I wish you a good use .
Some minor bug exist, but i try to solve them !
Старый 04.03.2011, 22:29   #26
pierrotm777
Smile V1.0
Last update.
See the first post for the adds .
Delete your skintoolds.ini file for use this new version !!!
Старый 07.03.2011, 20:50   #27
pierrotm777
Smile update
See the first post for a new version (V1.1), with news options !!!
-The 'Window Info' run well now
-I have added a 'compare two folders' option into the tools.
-Under the 'Edit Screen' button exist now a button for edit all file that you want into the skin folder with a filter (*.skin,*.txt,*.png and *.*)
-under the 'Gps' button exit a ''Net' button that show you the upload and download speed .
-slider option is now ok and with a combo option !
-you compare two folders !
Последний раз редактировалось pierrotm777; 09.03.2011 в 22:10.
Старый 09.03.2011, 22:54   #28
pierrotm777
Smile update v1.2
-the double | is now saved into the command's list
(you can send a command as , activate;Sygic FLEET||sendkey;{F1} and see it well into the list)
-the commands list and variables list are now in real time when you use the option 'Clear Settings'
Старый 12.03.2011, 19:41   #29
pierrotm777
Smile Update v 1.3
New little version:
-the editor's list has the filter (*.skin,*.txt,*.ini,*.bmp,*.gif,*.jpg,*.png,*.*)th at run now.
-the network meter is now always on the top right,put into the tools gui and give you your ip !
-added a backup for the variables with a $ into the name (=$skinpath$)
-added a backup for the sliders with and without a $ into the name (=$slider$)
-added the possibility to edit the label_list.txt and label_xx.ini files (DSFiles)
If you use already an older skintoolds version please backup your skintoolds.ini file and delete it !
Последний раз редактировалось pierrotm777; 12.03.2011 в 21:54.
Старый 23.03.2011, 23:08   #30
pierrotm777
Smile v1.5 update
new features and bugs fixed ( see first post please ! )
Часовой пояс GMT +4, время: 01:32.
