Вернуться   PCCar.ru - Ваш автомобильный компьютер > MP3Car ТехИнфа > Разработка программ > Программы управления > iCarDS > iCarDS и телефон
Результаты опроса: Do you think to use this plugin ?
Yes 22 95.65%
No 1 4.35%
Опрос с выбором нескольких вариантов ответа. Голосовавшие: 23. Вы ещё не голосовали в этом опросе
Старый 13.09.2016, 20:52   #191
pierrotm777
Аватар для pierrotm777
Call in and out not run only? Or other things!
Старый 13.09.2016, 21:13   #192
seriousstas
Машина: Nissan Qashqai+2
Сообщение от pierrotm777 Посмотреть сообщение
Call out (see Video).
If Call in - window appears, but continues ring after lifting the handset
Старый 14.09.2016, 19:33   #193
pierrotm777
I send you a video with call out that run very well with 1.6.0 version !!!
https://youtu.be/iZrqyptrEWw
Старый 14.09.2016, 19:36   #194
pierrotm777
Smile
ring is a new feature that i have tested !
I see that !!!
Why do you say that the uninstall don't run ?
All files are removed (screens and plugin files)
And ini files are restored !
Старый 14.09.2016, 19:45   #195
seriousstas
Video Time : 3:38 after uninstall
Старый 14.09.2016, 20:01   #196
seriousstas
Did you make plugin just for yourself?
Standard plug-in works as a clock - with any! telephone.
Tested on the Chinese: Redmi, Lenovo, various MTK ... Not everyone Samsung and Sony (I a Sony Z3 + - killed)
Старый 14.09.2016, 20:03   #197
seriousstas
Allready said
Allready said :
I restarted Icar 10 times.
I certainly close Icar before uninstalling.
The video is not visible, it removes Bandicam
The uninstall issue is solved only after the 1.6.0 version
Video Time : 3:38 after uninstall is 1.6.0 version
Старый 14.09.2016, 20:20   #198
pierrotm777
Smile
Tested on the Chinese: Redmi, Lenovo, various MTC ... Not everyone Samsung and Sony (I a Sony Z3 + - killed)
I understand what you say but i have just one phone and do my test with this !
The standard use only two services , HFP and PBAP !
Mine is very complex with more services:
MAP,PAN,SPP,FTP,OPP .
iCards is more complex than RR that i know very well !
Without you i can do nothing !
I have no answer from Bersenev and other developer !
In this case, it's really difficult to code !
I use vista 32bits and framework 3.5 maximum for my code !
The goal is to find why you have not the same experience than me with this plugin !
See my last video and you will see that i have no your issues !
My code isn't perfect, and need to be improved !
I have tested the standard plugin and like as it fill the list .
We can see that it's possible to have a picture by contact in the list as it's possible with RR.
This plugin is also used by the RR community and run very well but with the same issues !
BTMobilePhone 1.6.0 for RideRunner
Know issues for me:
-iphone can't send sms !
-iphone extract differently the vcard !
-contact's info sometime are bad !
My phone is an android 6.0 .
May be we have some issue with different os version ? I don't know !
If other guy want test the plugin with other phone, they are welcome !!!
Старый 14.09.2016, 20:59   #199
seriousstas
http://pccar.ru/showpost.php?p=368846&postcount=252
http://pccar.ru/showpost.php?p=367093&postcount=193
skin.ini :
Тип файла: txt skin.ini.txt (9.5 Кб, 1094 просмотров)
Старый 26.09.2016, 23:14   #200
Игорь_К
Регион: 71
Машина: Aveo
Игорь_К is on a distinguished road
V1.6.0 - does not work.
Игорь_К вне форума   Ответить с цитированием
Часовой пояс GMT +4, время: 04:33.
