Вернуться   PCCar.ru - Ваш автомобильный компьютер > MP3Car ТехИнфа > Разработка программ > Программы управления > iCarDS > iCarDS и телефон
Результаты опроса: Do you think to use this plugin ?
Yes 22 95.65%
No 1 4.35%
Опрос с выбором нескольких вариантов ответа. Голосовавшие: 23. Вы ещё не голосовали в этом опросе
Старый 18.08.2016, 18:31   #151
seriousstas
Машина: Nissan Qashqai+2
Do you use the ALL SMS mode for your test or only UNREAD ?
No - simply click "Read SMS" button
Nothing happens
Старый 18.08.2016, 19:11   #152
pierrotm777
Аватар для pierrotm777
Sorry, i have no issue with the sms !
But the result isn't immediate !
You need to wait a certain time if you want read all sms ?
What number of sms do you have ?
Старый 18.08.2016, 22:49   #153
seriousstas
I'm testing on two phones:
First Redmi - reads SMS times out of 10 queries
Waiting for a very long time.
Second - Mediatek MT6582 - reads quickly - and then (after restart) did not work at all.
Always the status of "not connected." Helps only reinstall plug and iCar DS (till restart Icar)
Последний раз редактировалось seriousstas; 19.08.2016 в 01:54.
Старый 19.08.2016, 11:30   #154
pierrotm777
Smile
35-40
Can you do some test with the BlueSoleilTest.exe demo found in the Tools directory ?
Test the map feature please !
Your phone are android phone ?
Старый 19.08.2016, 12:26   #155
seriousstas
Yes
BlueSoleilTest.exe
Ок, 22 (on Monday)...
Старый 20.08.2016, 20:05   #156
pierrotm777
Smile
If someone can translate me these english sentence please ?
Код:
l_set_BTM_Help=Help
l_set_BTM_MobilePhoneHelpMsg=Double click a contact for save it as favorite.
l_set_BTM_FavoriteHelpMsg1=Hold on a position for save a favorite.
l_set_BTM_FavoriteHelpMsg2=Click a favorite for call it.
l_set_BTM_CheckSMS=Check SMS
l_set_BTM_ReadSMS=Read SMS
l_set_BTM_UnReadOnly=Unread
l_set_BTM_AllSMS=All
l_set_BTM_UnreadSmSInfo=Check Unread SMS is running !
l_set_BTM_AllSmSInfo=The program will be unresponsive for a minute or more !
l_set_BTM_SmsModels=Models
l_set_BTM_SmsSend=Send SMS
l_set_BTM_Contact=Contact :
l_set_BTM_ContactNbr=Phone N° :
l_set_BTM_MessageId=Msg Id :
l_set_BTM_MessageDate=Date :
l_set_BTM_TextToSend=Text To Send :
Thanks guys !
Последний раз редактировалось pierrotm777; 20.08.2016 в 20:53.
Старый 21.08.2016, 14:39   #157
pierrotm777
Smile
I have found a big issue with the gps and the plugin !
I don't know why, but when iCarDS is started it check the GPS value and return well by example GPSSAT , GPSSPDN labels but not update these value !
I use GpsGate for my tests as simulator and have no idea why this issue !!!!!
Do need i change something into the ExecTBL.ini file ?
For have no issue with sms, the version 1.5.6 set the Lock In Motion feature to off !!!
Код:
<LockInMotion>false</LockInMotion>
Старый 23.08.2016, 18:30   #158
seriousstas
keyboard language does not switch.
English characters are not correct, as in the photo above.
Change phone from the program does not work.
need restart
Displays the status is always "connected" - at all, why?
If - connect the second - the first continues to be connected as well.
Старый 23.08.2016, 18:41   #159
seriousstas
Код:
l_set_BTM_Help=Помощь
l_set_BTM_MobilePhoneHelpMsg=Кликнуть дважды для сохранения в избранные
l_set_BTM_FavoriteHelpMsg1=Удерживать , для сохранения в избранные
l_set_BTM_FavoriteHelpMsg2=Выбрать избранное для звонка
l_set_BTM_CheckSMS=Проверить SMS
l_set_BTM_ReadSMS=Прочитать SMS
l_set_BTM_UnReadOnly=Не прочитанные
l_set_BTM_AllSMS=Все
l_set_BTM_UnreadSmSInfo=Запущена проверка SMS !
l_set_BTM_AllSmSInfo=Программа может не отвечать некоторое время !
l_set_BTM_SmsModels=Модели
l_set_BTM_SmsSend=Отправить SMS
l_set_BTM_Contact=Контакт :
l_set_BTM_ContactNbr=N° телефона :
l_set_BTM_MessageId=Id сообщения:
l_set_BTM_MessageDate=Дата :
l_set_BTM_TextToSend=Текст для отправки :
Последний раз редактировалось seriousstas; 23.08.2016 в 23:21.
Старый 23.08.2016, 20:53   #160
pierrotm777
Smile
If you test the two keyboard in your desktop, please close all program other than icards, and start only icards alone.
Other program that run in same time than ds crash the keyboard !
need restart
The swap phone feature isn't ready to use . Don't use it please , just use the first phone !!!
The status 'Connected' return a connection between Bluesoleil and the phone , not a call in status !
I have found an issue with the read sms feature, where the message wasn't full !
The last version 1.5.7 solve this issue !
Do you have always an issue with sms or it's better ?
With the 1.5.7 , it will be possible to send our position into a sms with three formats:
Google Maps, Bing Maps and Yandex Maps !
Nice for give your position to a friend !
Часовой пояс GMT +4, время: 04:33.
