Вернуться   PCCar.ru - Ваш автомобильный компьютер > MP3Car ТехИнфа > Разработка программ > Программы управления > iCarDS > iCarDS и телефон
Результаты опроса: Do you think to use this plugin ?
Yes 22 95.65%
No 1 4.35%
Опрос с выбором нескольких вариантов ответа. Голосовавшие: 23. Вы ещё не голосовали в этом опросе
Старый 14.08.2016, 15:02   #121
seriousstas
Машина: Nissan Qashqai+2
good method for read sms is to wait 30s
I'm waiting for a minute or more - SMS can not be read at all (or after a few restarts):
VIDEO 2
In the video, I reran six times IcarDS - Only twice read messages !
Старый 14.08.2016, 17:06   #122
pierrotm777
Аватар для pierrotm777
Smile
VIDEO 2
About the sms, i think have found why you have this issue !
The code use two command but when the second command is used the first have not enough time for its work !
So, i have modified and simplified this part of code for a easier use !
The second command is send only after the first will be finished !
No the code is running very well for Unread or All sms !
We have now no popup but just an info line into the sms screens.
Старый 14.08.2016, 17:10   #123
pierrotm777
Smile
Always 466, although from mobile dial different numbers :
VIDEO
Humm, i understand now better !
You don't like that ? (it's a joke)
I see that !
I suppose your PhoneNoAddContact settings is set to false ? <PhoneNoAddContact>false</PhoneNoAddContact>
Старый 14.08.2016, 17:21   #124
pierrotm777
Smile
VIDEO
I have not this issue !
For my test, i use the number 123 that call my vocal message box !
I have no popup !
Do you have a timer that call again and again this popup or an IDLE into your exectbl.ini file ?
I send you my exectbl.ini file !
Can you do a test with this file please ?
Тип файла: zip ExecTBL.zip (61.0 Кб, 460 просмотров)
Старый 14.08.2016, 19:49   #125
pierrotm777
Smile
Something is now with the English keyboard :
The keyboard issue on the OnScreenStart command into the SKIPTO_OSK screen.
the command is:
Код:
Script,OnScreenStart,SETVARBYCODE;LANG;LangName||SHIFTLOCK||if;strcomp($LANG$;RU);{SetVar;KBLAYOUT;1};{SetVar;KBLAYOUT;0}
I check the label LangName that return RU if a russian keyboard is define in windows.
So i try to check if LANG = RU !!!
If yes, KBLAYOUT=1
If no, KBLAOUT = 0
But this line don't run and i don't know why !
Need help please !!!
Старый 15.08.2016, 06:48   #126
Winlin
В общем пока не решится проблема с уровнями громкости пользоваться не возможно.
Принял звонок, и дальше надо бируши резко вставить, чтобы не оглохнуть от включившейся музыки.
Может пока не найдено решение проблемы, при звонке МАСТЕР звука не 100 ставить, а 10 например.
HONDA CR-V все сделано в 1.5 Din корпусе
MSI H61I-E35/Pentium G2030T/4Gb/M4-CT128M4SSD2/8"монитор/Wi-Fi/Bluetooth/усилитель MiniQuad 4х50 + конвертер SPDIF>аналог/m2-atx/HD RADIO DMHD1000I/Logitech QuickCam Pro 9000...Win7 prof
Последний раз редактировалось Winlin; 15.08.2016 в 07:36.
Старый 15.08.2016, 17:55   #127
duzzy
Машина: SUBARU Impreza WRX
pierrotm777
What you will do with 100% volume on call?
You have already found a solution... Why not apply in your plugin ?
Код:
/ Входящий звонок(Incoming call)
"ONINCOMMINGCALLSTART","ByVar;IsPhoneTalk;INCOMMINGCALLSTARTif"
"INCOMMINGCALLSTARTif","Menu;call_in.skin||StartPhoneCall"
"ONINCOMMINGCALLEND","ByVar;IsPhoneTalk;<<INCOMMINGCALLENDTif"
"INCOMMINGCALLENDTif","ByVar;IsMixerSkinLoad;<<Esc||ByVar;IsPhoneOverlay;Esc<<PhoneCloseOverlay||EndPhoneCall"
/ Исходящий звонок(Outgoing call)
"ONINOUTGOINGCALLSTART","ByVar;IsPhoneTalk;INOUTGOINGCALLSTARTif"
"INOUTGOINGCALLSTARTif","Menu;call_out.skin||StartPhoneCall"
"ONINOUTGOINGCALLEND","ByVar;IsPhoneTalk;<<INOUTGOINGCALLENDif"
"INOUTGOINGCALLENDif","ByVar;IsMixerSkinLoad;<<Esc||ByVar;IsPhoneOverlay;Esc<<PhoneCloseOverlay||EndPhoneCall"
"StartPhoneCall","SetVar;IsPhoneTalk;1||ByVar;IsPausedMedia;<<CF_Pause||SaveMixerPreset_Media||LoadMixerPreset;Phone||volperc+;$vol_from_speed_full$"
"EndPhoneCall","SaveMixerPreset_Phone||LoadMixerPreset_Media||ByVar;IsPausedMedia;<<CF_Resume||SetVar;IsPhoneTalk;0"
"SaveMixerPreset_Media","ByVar;MixerPresetMode;SaveMixerPreset_Media_Manual<<SaveMixerPreset_Media_Manual<<SaveMixerPreset_Media_Auto"
"SaveMixerPreset_Media_Auto","volperc-;$vol_from_speed_full$||SaveMixerPreset;$Media_s$"
"SaveMixerPreset_Media_Manual","volperc-;$vol_from_speed_full$||SaveMixerPreset;tmp"
"SaveMixerPreset_Phone","ByVar;MixerPresetMode;<<<<SaveMixerPreset_Phone_Auto"
"SaveMixerPreset_Phone_Auto","volperc-;$vol_from_speed_full$||SaveMixerPreset;Phone"
"LoadMixerPreset_Media","ByVar;MixerPresetMode;LoadMixerPreset_Media_Manual<<LoadMixerPreset_Media_Manual<<LoadMixerPreset_Media_Auto"
"LoadMixerPreset_Media_Auto","LoadMixerPreset;$Media_s$||volperc+;$vol_from_speed_full$"
"LoadMixerPreset_Media_Manual","LoadMixerPreset;tmp||volperc+;$vol_from_speed_full$"
I found that MASTER volume set by this command...
--- "SETVOL;MASTER;0" --- 0%
--- "SETVOL;MASTER;100" --- 100%
Thanks to your SkinTool.
(an updated version of the SkinTool would be very good)
About lang change in osk...
you can use AHK script from seriousstas... download 7z archive with precompiled AHK script.
an example of a button in mini osk keyboard with AHK script...
B,0,200,130,50,"RUNQ;$SKINPATH$SCRIPTS\Lang_change .exe",""
skin command from osk and osk2 lang change...
osk2
B,0,200,130,50,"SENDKEY;$LangToggleSet$",""
OSK
B,567,510,70,90,"LangToggle",""
Старый 16.08.2016, 10:43   #128
Winlin
А в каком файле есть эта запись "SETVOL;MASTER"
зарядил поиск по диску. Не могу найти.
Старый 16.08.2016, 12:33   #129
duzzy
Winlin
Записи нет в файлах как и документации по Икару... что очень печально...
Разработчик мог бы и приложить хотя бы один файлик с командами Икара, и простенькими пояснениями... софтина то платная...
Я брал команду из RideRunner-а и опытным путем выяснил через SkinTool как менять громкость в процентном соотношении.
Старый 16.08.2016, 12:42   #130
Winlin
Просто автор плагина привел команды , как он делает. Я и хотел изменить 100 на 10 , скажем, но не нашел где.
Часовой пояс GMT +4, время: 04:34.
