Вернуться   PCCar.ru - Ваш автомобильный компьютер > MP3Car ТехИнфа > Разработка программ > Программы управления > iCarDS > iCarDS и телефон
Результаты опроса: Do you think to use this plugin ?
Yes 22 95.65%
No 1 4.35%
Опрос с выбором нескольких вариантов ответа. Голосовавшие: 23. Вы ещё не голосовали в этом опросе
Старый 25.10.2016, 15:59   #251
pierrotm777
Аватар для pierrotm777
Winlin,
When you use the new plugin , do you think to set off the original plugin into iCarDSConfig.exe ?
Старый 26.10.2016, 16:44   #252
pierrotm777
I have done several tests with the Bersenev 1.7.0.33 version !
The new plugin seems running well !
But if i try to use the two plugins in same time, it's not possible to call a contact with the original plugin !
I think that will be the same issue with the version 1.7.060 b19 !!!
Старый 26.10.2016, 16:57   #253
seriousstas
All use version 1.7.060.
It does not matter by Bersenev or by Lexx09
Старый 26.10.2016, 22:28   #254
duzzy
Машина: SUBARU Impreza WRX
pierrotm777
Hello
If it's not too much trouble maybe you write a little program in VB.NET to toggle speakers <> mobile phone ?
fist run program get phone and write to ini...
next run program read from ini and just toggle connected phone... speakers <> phone.
This little tool very help people who use standard icards phone plugin .
Старый 27.10.2016, 17:21   #255
pierrotm777
New feature in 1.6.4 version !
Sms reader screen return if a file is attached !
Старый 27.10.2016, 17:23   #256
pierrotm777
Smile
pierrotm777
Hello
Please, read this link http://pccar.ru/showpost.php?p=372518&postcount=352
But this command is only for the new plugin !
I don't know the command for the original plugin (if its exist ) !
You want save this in ini file for the standard phone plugin ?
I can't for the original plugin but it's possible for my new plugin !
I have no access to the original plugin code !!!
Последний раз редактировалось pierrotm777; 27.10.2016 в 19:47.
Старый 27.10.2016, 19:17   #257
Winlin
Winlin is on a distinguished road
contact always Unknow Sender
№ telephone always empty
The "IDmessage" is not fully displayed
plugin 1.6.3 iCar 1.7.0.48
resolution 1024*600
HONDA CR-V все сделано в 1.5 Din корпусе
MSI H61I-E35/Pentium G2030T/4Gb/M4-CT128M4SSD2/8"монитор/Wi-Fi/Bluetooth/усилитель MiniQuad 4х50 + конвертер SPDIF>аналог/m2-atx/HD RADIO DMHD1000I/Logitech QuickCam Pro 9000...Win7 prof
Winlin вне форума   Ответить с цитированием
Старый 27.10.2016, 19:46   #258
pierrotm777
Smile
Сообщение от Winlin Посмотреть сообщение
Вложение 45310
resolution 1024*600
Good comments Winlin I have solved these issues today !
Version 1.6.4 will be updated !
Старый 27.10.2016, 20:46   #259
Winlin
contact always "Неизвестно"
Старый 27.10.2016, 20:59   #260
Winlin
reload, resetup, no changes
and you don't need to select plugin
Часовой пояс GMT +4, время: 21:31.
