Вернуться   PCCar.ru - Ваш автомобильный компьютер > MP3Car ТехИнфа > Разработка программ > Программы управления > iCarDS > iCarDS и телефон
Результаты опроса: Do you think to use this plugin ?
Yes 22 95.65%
No 1 4.35%
Опрос с выбором нескольких вариантов ответа. Голосовавшие: 23. Вы ещё не голосовали в этом опросе
Старый 12.09.2016, 21:39   #181
pierrotm777
Аватар для pierrotm777
Smile
I have found a method for check if the phone is connected to an external power and run very well !
This feature will be added to the version 1.6.0 .
Старый 13.09.2016, 17:44   #182
seriousstas
Сообщение от pierrotm777 Посмотреть сообщение
Version 1.6.0 is out !
v1.6.0 13-9-2016
Uninstalling does not work.
But and the phone stopped ringing.
Just broke the plugin :
Старый 13.09.2016, 18:04   #183
pierrotm777
seriousstas,
The problem is you go too quickly !!!
1.In the video send in my PM !
After click on the phone button, you must see the button on top right blinking (red circle)!
You need to wait that all top buttons pass to green (green rectangle) !!!!
2.In the video in post 261 !
The first time you run the plugin, if you click on the phone button , the plugin go to the settings!
You must select your device and click on 'apply' button for save it into the settings.
After that , you must quit iCarDS, because the plugin not run all services the first time !
It's why you have no info as you phone number, network name etc...
Run again iCarDS, wait the connection , go to the main phone screen and WAIT the popup !
If all top buttons are ok (green), you can continue, and use, by example sms services !
If not , you have a problem !
But i see we have a big issue after a call out, i can't return to the phone screen !
Старый 13.09.2016, 18:19   #184
seriousstas
seriousstas,
I hope you're joking ...
V1.5.6 work call, but V1.6.0 - does not work.
I restarted Icar 10 times.
Старый 13.09.2016, 18:43   #185
pierrotm777
I have found a big issue with the MOBILECALL_IN_OVERLAY.skin screen that stop the good use of the plugin !
We need to add this line into this screen:
Код:
Script,OnScreenEnd,Esc||OverlayResume
With this add, it always possile to return to the phone screen after a call out or call in !
Старый 13.09.2016, 18:52   #186
pierrotm777
Smile
No, all is running well, but i don't know where is your issue !
Follow my advice !
I send a video as soon as possible !
Старый 13.09.2016, 19:59   #187
seriousstas
Versions 1.5.6 and below works the call.
The next tried 1.6.0 - does not work
I can try 1.5.9 , if have a link
Старый 13.09.2016, 20:31   #188
seriousstas
C:\Users\Home_PC\Desktop\iCarDS Plugin BTMobilePhone (PBAP & MAP services) V1.5.2 DS Setup.zip
C:\Users\Home_PC\Desktop\iCarDS Plugin BTMobilePhone (PBAP & MAP services) V1.5.3 DS Setup.zip
C:\Users\Home_PC\Desktop\iCarDS Plugin BTMobilePhone (PBAP & MAP services) V1.5.4 DS Setup.zip
C:\Users\Home_PC\Desktop\iCarDS Plugin BTMobilePhone (PBAP & MAP services) V1.5.5 DS Setup.zip
C:\Users\Home_PC\Desktop\iCarDS Plugin BTMobilePhone (PBAP & MAP services) V1.5.6 DS Setup.zip
WORK !
C:\Users\Home_PC\Desktop\iCarDS Plugin BTMobilePhone (PBAP & MAP services) V1.6.0 DS Setup.zip
NOT WORK !
Старый 13.09.2016, 20:41   #189
pierrotm777
Follow the post 264 and try please
Старый 13.09.2016, 20:49   #190
seriousstas
RideRunner Skin
RRScreen call_in_overlay
screen_600x110_off.png,screen_600x110_off.png,scre en_600x110_off.png,screen_600x110_off.png
/SHOWEFFECT6
/HIDEEFFECT5
/POSY=0
Added - no changes
Часовой пояс GMT +4, время: 18:39.
