Результаты опроса: Do you think to use this plugin ? | |||
Yes |
22 | 95.65% |
No |
1 | 4.35% |
Опрос с выбором нескольких вариантов ответа. Голосовавшие: 23. Вы ещё не голосовали в этом опросе |
#41 | ||
![]() Регистрация: 07.11.2010
I see that your main contacts indicator is red, so you have no MobilePhone_PB.txt file under the directory: C:\Program Files\TipTop software\iCar DS\Extentions\MobilePhone\PhoneBook\ Can you delete all the files under this directory, and you will see that on the MOBILEPHONE screen, the extract contact button (second in top right) is blinking ! When all list are ready , you receive a message and all top contacts indicators are green !!!! You can always use the extract contact button manually ! Retry after that the search screens ! I don't understand why skipto icards command don't accept russian alphabet ! I think , we need to change the search screen for have a good use ! But i don't know well all icards command! Where can i found all icards commands list ? I know that the plugin stop and restart always Bluesoleil when iCards is loaded! It's the only method, because Bluesoleil SDK is very hard to use ! The plugin need this time for run correctly ! Цитата:
You need to click on your phone device and after click on the 'Apply' button ! After that, the plugin run alone ! You can quit the setting's screen and click again on the mobilephone button ! This time the plugin will load the main screen and will extract alone the contacts! After the message, just click on the main contacts button ! You have two videos that explain this part ! |
#42 | ||
![]() Регистрация: 14.06.2013
Can be done with a single click "look next" ? - important for large books - where many repetitions Цитата:
#43 | ||
Please make if possible re-search button: "NEXT SEARCH", For not to open the keyboard window again and again to the same words: http://pccar.ru/showpost.php?p=365254&postcount=67 Thnx! Цитата:
Код:
Run('taskkill /f /im BtTray.exe',"", @SW_HIDE) Run('taskkill /f /im BlueSoleilCS.exe',"", @SW_HIDE) Run('taskkill /f /im BsHelpCS.exe',"", @SW_HIDE) Run('taskkill /f /im BsMobileCS.exe',"", @SW_HIDE) ShellExecute("C:\Program Files (x86)\IVT Corporation\BlueSoleil\BtTray.exe") BlueSoleilCS.exe Последний раз редактировалось seriousstas; 23.07.2016 в 02:19. |
#44 |
![]() Can you try this last screen please ?
Последний раз редактировалось pierrotm777; 27.11.2016 в 18:16. |
#45 |
![]() Can you try these other modified mobilecall screen ?
After 10 secondes, the mobilecall is exited and an overlay replace it ! I suppose than an overlay stay always on top if we change to another screen, but actually, it is exited ! If you have an idea how to do ? Последний раз редактировалось pierrotm777; 27.11.2016 в 18:16. |
#46 |
![]() I added a video in PM
1.Now stopped working SMS read (but works from BlueSoleil). Previously it worked. 2. Search works well with large keyboard (hold) and still does not work with smallt does not work with small (single-click). still does not work with small (single-click). Search works, but for small letters. And all the letters are still do not have enough. It should be 32 - 26 there. Yet sometimes when starting a window appears IcarDS falling, but IcarDS not falling - everything works well. Последний раз редактировалось seriousstas; 23.07.2016 в 22:27. |
#47 | ||
Does not display the them. Always blinks search (infinitely) I put back again iCarDS Plugin BTMobilePhone (PBAP & MAP services) V1.4.9 DS Setup.exe and messages are displayed! Цитата:
#48 | ||
Other - well read ! Цитата:
Seeking the All - 385, then again Unrear - 68 The following start - not seeking at all. ADD Video3 |
#49 | |
![]() iCarDS Plugin BTMobilePhone (PBAP & MAP services) V1.5.0 DS Setup
"Msg Read" icon blinking after search(infinitely) Keyboard : Цитата:
Последний раз редактировалось seriousstas; 23.07.2016 в 22:25. |
#50 |
![]() Did you have modify the settings for your country ?
Код:
<EmergencyNumber>112</EmergencyNumber> <VocalMessageryNumber>123</VocalMessageryNumber> Код:
<PhoneCountryCodes> <string>0</string> <string>33</string> <string>00</string> </PhoneCountryCodes> Think you need to keep 112 for emergency. About your voice message and don't know ! I can change that into the installer if needed ! |
