Вернуться   PCCar.ru - Ваш автомобильный компьютер > MP3Car ТехИнфа > Разработка программ > Программы управления > iCarDS > iCarDS и телефон
Результаты опроса: Do you think to use this plugin ?
Yes 22 95.65%
No 1 4.35%
Опрос с выбором нескольких вариантов ответа. Голосовавшие: 23. Вы ещё не голосовали в этом опросе
Старый 22.07.2016, 12:56   #41
pierrotm777
Аватар для pierrotm777
Smile
Replaced two files:
SKIPTO_OSK.skin
MOBILEPHONE.skin
Now, if I choose to search butt - I do not see this (search)window
Nothing appears ..
For search by word, you need to hold the button search !
I see that your main contacts indicator is red, so you have no MobilePhone_PB.txt file under the directory:
C:\Program Files\TipTop software\iCar DS\Extentions\MobilePhone\PhoneBook\
Can you delete all the files under this directory, and you will see that on the MOBILEPHONE screen, the extract contact button (second in top right) is blinking !
When all list are ready , you receive a message and all top contacts indicators are green !!!!
You can always use the extract contact button manually !
Retry after that the search screens !
I don't understand why skipto icards command don't accept russian alphabet !
I think , we need to change the search screen for have a good use ! But i don't know well all icards command!
Where can i found all icards commands list ?
I know that the plugin stop and restart always Bluesoleil when iCards is loaded!
It's the only method, because Bluesoleil SDK is very hard to use !
The plugin need this time for run correctly !
Also not clear how to go to Contacts from the settings after connecting -
should always close the settings window, and then run the phone again - it is not convenient!
The first time you use the plugin, the xml file hasn't your phone name, so when you click on mobilephone button, the plugin go to the first setting screen !
You need to click on your phone device and after click on the 'Apply' button !
After that, the plugin run alone !
You can quit the setting's screen and click again on the mobilephone button !
This time the plugin will load the main screen and will extract alone the contacts!
After the message, just click on the main contacts button !
You have two videos that explain this part !
Старый 22.07.2016, 15:14   #42
seriousstas
For search by word, you need to hold the button search!
It works on Hold.
Can be done with a single click "look next" ? - important for large books - where many repetitions
This is a problem of compatibility with BlueSoleil - not with the plugin
Старый 23.07.2016, 00:19   #43
seriousstas
Сообщение от pierrotm777 Посмотреть сообщение
You can swap the click and hold command on this button if you want ?
I do not know about any command there is a speech.
Please make if possible re-search button: "NEXT SEARCH",
For not to open the keyboard window again and again to the same words:
http://pccar.ru/showpost.php?p=365254&postcount=67
Thnx!
I already restarted via AutoIt script (along with IcarDS) :
Код:
Run('taskkill /f /im BtTray.exe',"", @SW_HIDE)
     Run('taskkill /f /im BlueSoleilCS.exe',"", @SW_HIDE)
     Run('taskkill /f /im BsHelpCS.exe',"", @SW_HIDE)
     Run('taskkill /f /im BsMobileCS.exe',"", @SW_HIDE)
ShellExecute("C:\Program Files (x86)\IVT Corporation\BlueSoleil\BtTray.exe")
And it seems only one restart enough:
BlueSoleilCS.exe
Последний раз редактировалось seriousstas; 23.07.2016 в 02:19.
Старый 23.07.2016, 13:09   #44
pierrotm777
Smile
Can you try this last screen please ?
ID:	44292   Нажмите на изображение для увеличения
Последний раз редактировалось pierrotm777; 27.11.2016 в 18:16.
Старый 23.07.2016, 13:27   #45
pierrotm777
Smile
Can you try these other modified mobilecall screen ?
After 10 secondes, the mobilecall is exited and an overlay replace it !
I suppose than an overlay stay always on top if we change to another screen, but actually, it is exited !
If you have an idea how to do ?
Старый 23.07.2016, 14:21   #46
seriousstas
I added a video in PM
1.Now stopped working SMS read (but works from BlueSoleil).
Previously it worked.
2. Search works well with large keyboard (hold) and still does not work with smallt does not work with small (single-click).
still does not work with small (single-click).
Search works, but for small letters. And all the letters are still do not have enough. It should be 32 - 26 there.
Yet sometimes when starting a window appears IcarDS falling, but IcarDS not falling - everything works well.
Последний раз редактировалось seriousstas; 23.07.2016 в 22:27.
Старый 23.07.2016, 17:59   #47
seriousstas
Run very well for me send a sms to you and you will see that sms icon is blicking when sms number is > 0 .
NEW plugin does not work with messages!
Does not display the them. Always blinks search (infinitely)
I put back again iCarDS Plugin BTMobilePhone (PBAP & MAP services) V1.4.9 DS Setup.exe
and messages are displayed!
May be another video ?
this is usually when you first install or replace theme - I can not repeat - but it was several times ..
Старый 23.07.2016, 21:23   #48
seriousstas
It's not normal
normal! Only with this phone.
Other - well read !
Do you wait 30s for check if SMS is running well ?
Reinstalled - to work, but strangely ..
Seeking the All - 385, then again Unrear - 68
The following start - not seeking at all.
ADD Video3
Старый 23.07.2016, 21:44   #49
seriousstas
iCarDS Plugin BTMobilePhone (PBAP & MAP services) V1.5.0 DS Setup
"Msg Read" icon blinking after search(infinitely)
Keyboard :
Search works, but for small letters. And all the letters are still not hvaaet. It should be 32 - 26 there.
Последний раз редактировалось seriousstas; 23.07.2016 в 22:25.
Старый 24.07.2016, 12:14   #50
pierrotm777
Smile
Did you have modify the settings for your country ?
Код:
  <EmergencyNumber>112</EmergencyNumber>
  <VocalMessageryNumber>123</VocalMessageryNumber>
and
Код:
  <PhoneCountryCodes>
    <string>0</string>
    <string>33</string>
    <string>00</string>
  </PhoneCountryCodes>
Think you need to replace 33 by 7.
Think you need to keep 112 for emergency.
About your voice message and don't know !
I can change that into the installer if needed !
Часовой пояс GMT +4, время: 05:09.
