#101 |
![]() Регистрация: 09.11.2006
#102 |
![]() Регистрация: 15.07.2009
#103 | |
![]() Регистрация: 04.02.2008
Машина: 2006\Daewoo\Nexia
#104 |
![]() 1) При установленном провайдере контактов через vcard и пустом или отсутствующим каталоге с vcard при попытке набрать номер вылетает
Код:
Message: Value cannot be null. Parameter name: array ParamName: array Data: System.Collections.ListDictionaryInternal InnerException: TargetSite: Int32 IndexOf[T](T[], T) StackTrace: at System.Array.IndexOf[T](T[] array, T value) at ContactProviderModel.Utils.Utils.GetIContactsByRegex(IList`1 contactList, Regex exp, String[] propExcludeFromCompare) at ContactProviderModel.Utils.Utils.GetIContactsByRegex(IList`1 contactList, Regex exp) at ContactFromvCardDir.ContactManager.GetContactsByRegex(Regex expr) at BTPhone.Model.Internal.ContactService.set_DialpadInput(Char[] value) at BTPhone.Model.DialerViewModel.DialerPadViewModel_PropertyChanged(Object sender, PropertyChangedEventArgs e) at System.ComponentModel.PropertyChangedEventHandler.Invoke(Object sender, PropertyChangedEventArgs e) at BTPhone.Model.ViewModelBase.OnPropertyChanged(String propertyName) at BTPhone.Model.DialerPadViewModel.AddInputData(Object parametr) at BTPhone.Model.DialerPadViewModel.<get_DialPadDigitKeyPressedCommand>b__0(Object param) at BTPhone.Model.RelayCommand.Execute(Object parameter) at MS.Internal.Commands.CommandHelpers.CriticalExecuteCommandSource(ICommandSource commandSource, Boolean userInitiated) at System.Windows.Controls.Primitives.ButtonBase.OnClick() at System.Windows.Controls.Button.OnClick() at BTPhone.Componets.DialerButton.OnClick() at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e) at System.Windows.UIElement.OnMouseLeftButtonUpThunk(Object sender, MouseButtonEventArgs e) at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget) at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent) at System.Windows.UIElement.CrackMouseButtonEventAndReRaiseEvent(DependencyObject sender, MouseButtonEventArgs e) at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e) at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget) at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted) at System.Windows.Input.InputManager.ProcessStagingArea() at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input) at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport) at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel) at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) HelpLink: Source: mscorlib 3) Несколько раз повторялась уже указанная проблема - когда вместо имени сети пишется фиг знает что. Есть предложение - если это действительно проблема блюсолейла, то попытаться либо пересоединится для получения нормального имено сети (а оно не может быть таким большим и должно состоять только из латинских букв и цифр) или хотя бы выводить первые десять (пятнадцать и т.п.), чтобы не перекашивало весь скрин из-за кривой строки. |
#105 |
![]() Регистрация: 01.10.2009
Машина: Nissan Note
![]() Если у кого имеются проблеммы с тормозами при использовании кнопак набора номера, то для определения проблемного места, скачайте архив во вложении, и распакуйте его содержимое в папку skins (предварительно сохранив оригинальный файл skins.xml). Далее в настройках программы выберите по очереди тему test1 и test2.
Сообщите мне если проблемма решилась на какой либо из тем. Проблемму по менеджеру контактов vCard принял. Функционал автоматического переподключения уже сделан (если включена данная опция, то при ошибке соединения или его разрыве не со стороны программы принимаются попытки его востановления с периодичностью 60 сек. Наверное введу в программу ограничение на длинну имени оператора до 10 символов. Обновленную версию программы планирую выложить на этой следующей неделе. |
#106 |
Машина: Nissan Note
![]() Версия 0.8
Изменения: - добавлен алгоритм контроля соединения; - в окне настроек для опций указывающих пути к файлам добавлены кнопки "Обзор..." открывающие окно открытия фала. При этом если для файла были укзаны параметры запуска то они сохраняются. - изменена индикация не верно указанных настроек. теперь вместо красной рамки вокруг ЭУ перед ним отображается круг с восклицательным знаком, при наведении на данный значок выводится сообщение об ошибке. - добавлен провайдер контактов vCard. - добавлена проверка версии .NET Framework в программе установки, минимальная версия 3.5 SP1. - добавлено понятие номера по умолчанию. - добавлено форматирование номеров. Контроль соединения Включается в настройках на закладке Bluetooth, по-умолчанию включен. При инициализации подключения если произошла ошибка или подключение было разорвано не по инициативе программы принимаются попыке к переподключению. Количество поыток не ограничено. Пауза между попытками 60 сек. Программа может находится в 3 состояниях: не подключена (фон иконки Bluetooth синий), подключена (фон иконки Bluetooth зеленый), предпринимаются попытки к подключению (фон иконки Bluetooth синий с красным рисунком). Отключиться от устройства и прекратить попытки подключения можно нажатием на иконку Bluetooth. Провайдер контактов vCard Данный провайдер загружает контакты из файлов формата vCard 2.1 и vCard 3.0, расположенных в катлоге BTPContacts, размещенного в директории профиля пользователя. Для открытия директории контактов пользователя нажмите Пуск->Выполнить..., введите %USERPROFILE%, нажмите OK. По умолчанию данная папка отсутствует. Данный номер отображается в списке контактов. По умолчанию выбирается первый номер в контакта. При длительном нажатии (>0.5 сек) на контакте в списке выполняется звонок на телефон по умолчанию. Номер по умолчанию При длительном нажатии на запись в списке контактов выполняется звонок на номер по умолчанию. Если номер по умолчанию не назначен, то используется первый в списке. Для назначения номера по-умолчанию нажмите в списке контактов правой кнопкой мыши на высвеченный номер и выберите другой номер из списка (Данная возможность пока не поддерживается провайдером контактов Outlook). Направление дальнейшей работы Все что планировал включить в этот релиз не включил в связи с недостатком времени, в часности отсутствует ограничение по длине имени оператора. Начал заниматься релизацией работы через Widcomm, для этих целей был приобретен свисток Acer. Поддержка Т.к. карпьютера у меня нет то программу я пишу не для личного пользования, а для Вас. Посему буду благодарен за финансовую поддержку, в любом размере ![]() Webmoney: R651991578882 E390479316406 Z175049746970 Яндекс 41001514466027 Последний раз редактировалось genius_p; 13.01.2010 в 13:16. |
#107 |
![]() Регистрация: 06.07.2009
Машина: Nissan Almera Classic 06
![]() Предыдущую версию удалил, а при установке новой, пишет: Необходим Microsoft .NET Framework 3.5 SP1.
Он у меня стоит, так как предыдущая версия работала :-( |
#109 |
![]() Не успел добавить картинку, как уже получил ответ :-) спасибо за оперативность.
По ветке реестра HKLM\Software\Microsoft\NET Framework Setup\NDP ни каких значений нет вообще. Подскажите где скачать рабочий SP1. |
#110 |
Машина: Nissan Note
