Старый 19.10.2014, 01:23   #271
ВладимирC
Машина: Hyunday Grandeur 3.3
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -MMD -DUSB_VID=0x2341 -DUSB_PID=0x8036 -DARDUINO=104 -IE:\Arduino\arduino-1.0.4\hardware\arduino\cores\arduino -IE:\Arduino\arduino-1.0.4\hardware\arduino\variants\leonardo X:\TEMP\build8376110162395595122.tmp\sketch_oct18a .cpp -o X:\TEMP\build8376110162395595122.tmp\sketch_oct18a .cpp.o
sketch_oct18a.ino: In function 'void loop()':
sketch_oct18a.ino:32: warning: suggest parentheses around && within ||
sketch_oct18a.ino:48: warning: suggest parentheses around && within ||
sketch_oct18a.ino:111: warning: suggest parentheses around && within ||
sketch_oct18a.ino:133: warning: suggest parentheses around && within ||
sketch_oct18a.ino:141: warning: suggest parentheses around && within ||
Using previously compiled: X:\TEMP\build8376110162395595122.tmp\malloc.c.o
Using previously compiled: X:\TEMP\build8376110162395595122.tmp\WInterrupts.c .o
Using previously compiled: X:\TEMP\build8376110162395595122.tmp\wiring.c.o
Using previously compiled: X:\TEMP\build8376110162395595122.tmp\wiring_analog .c.o
Using previously compiled: X:\TEMP\build8376110162395595122.tmp\wiring_digita l.c.o
Using previously compiled: X:\TEMP\build8376110162395595122.tmp\wiring_pulse. c.o
Using previously compiled: X:\TEMP\build8376110162395595122.tmp\wiring_shift. c.o
Using previously compiled: X:\TEMP\build8376110162395595122.tmp\CDC.cpp.o
Using previously compiled: X:\TEMP\build8376110162395595122.tmp\HardwareSeria l.cpp.o
Using previously compiled: X:\TEMP\build8376110162395595122.tmp\HID.cpp.o
Using previously compiled: X:\TEMP\build8376110162395595122.tmp\IPAddress.cpp .o
Using previously compiled: X:\TEMP\build8376110162395595122.tmp\main.cpp.o
Using previously compiled: X:\TEMP\build8376110162395595122.tmp\new.cpp.o
Using previously compiled: X:\TEMP\build8376110162395595122.tmp\Print.cpp.o
Using previously compiled: X:\TEMP\build8376110162395595122.tmp\Stream.cpp.o
Using previously compiled: X:\TEMP\build8376110162395595122.tmp\Tone.cpp.o
Using previously compiled: X:\TEMP\build8376110162395595122.tmp\USBCore.cpp.o
Using previously compiled: X:\TEMP\build8376110162395595122.tmp\WMath.cpp.o
Using previously compiled: X:\TEMP\build8376110162395595122.tmp\WString.cpp.o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-ar rcs X:\TEMP\build8376110162395595122.tmp\core.a X:\TEMP\build8376110162395595122.tmp\malloc.c.o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-ar rcs X:\TEMP\build8376110162395595122.tmp\core.a X:\TEMP\build8376110162395595122.tmp\WInterrupts.c .o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-ar rcs X:\TEMP\build8376110162395595122.tmp\core.a X:\TEMP\build8376110162395595122.tmp\wiring.c.o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-ar rcs X:\TEMP\build8376110162395595122.tmp\core.a X:\TEMP\build8376110162395595122.tmp\wiring_analog .c.o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-ar rcs X:\TEMP\build8376110162395595122.tmp\core.a X:\TEMP\build8376110162395595122.tmp\wiring_digita l.c.o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-ar rcs X:\TEMP\build8376110162395595122.tmp\core.a X:\TEMP\build8376110162395595122.tmp\wiring_pulse. c.o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-ar rcs X:\TEMP\build8376110162395595122.tmp\core.a X:\TEMP\build8376110162395595122.tmp\wiring_shift. c.o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-ar rcs X:\TEMP\build8376110162395595122.tmp\core.a X:\TEMP\build8376110162395595122.tmp\CDC.cpp.o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-ar rcs X:\TEMP\build8376110162395595122.tmp\core.a X:\TEMP\build8376110162395595122.tmp\HardwareSeria l.cpp.o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-ar rcs X:\TEMP\build8376110162395595122.tmp\core.a X:\TEMP\build8376110162395595122.tmp\HID.cpp.o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-ar rcs X:\TEMP\build8376110162395595122.tmp\core.a X:\TEMP\build8376110162395595122.tmp\IPAddress.cpp .o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-ar rcs X:\TEMP\build8376110162395595122.tmp\core.a X:\TEMP\build8376110162395595122.tmp\main.cpp.o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-ar rcs X:\TEMP\build8376110162395595122.tmp\core.a X:\TEMP\build8376110162395595122.tmp\new.cpp.o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-ar rcs X:\TEMP\build8376110162395595122.tmp\core.a X:\TEMP\build8376110162395595122.tmp\Print.cpp.o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-ar rcs X:\TEMP\build8376110162395595122.tmp\core.a X:\TEMP\build8376110162395595122.tmp\Stream.cpp.o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-ar rcs X:\TEMP\build8376110162395595122.tmp\core.a X:\TEMP\build8376110162395595122.tmp\Tone.cpp.o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-ar rcs X:\TEMP\build8376110162395595122.tmp\core.a X:\TEMP\build8376110162395595122.tmp\USBCore.cpp.o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-ar rcs X:\TEMP\build8376110162395595122.tmp\core.a X:\TEMP\build8376110162395595122.tmp\WMath.cpp.o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-ar rcs X:\TEMP\build8376110162395595122.tmp\core.a X:\TEMP\build8376110162395595122.tmp\WString.cpp.o
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-gcc -Os -Wl,--gc-sections -mmcu=atmega32u4 -o X:\TEMP\build8376110162395595122.tmp\sketch_oct18a .cpp.elf X:\TEMP\build8376110162395595122.tmp\sketch_oct18a .cpp.o X:\TEMP\build8376110162395595122.tmp\core.a -LX:\TEMP\build8376110162395595122.tmp -lm
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 X:\TEMP\build8376110162395595122.tmp\sketch_oct18a .cpp.elf X:\TEMP\build8376110162395595122.tmp\sketch_oct18a .cpp.eep
E:\Arduino\arduino-1.0.4\hardware\tools\avr\bin\avr-objcopy -O ihex -R .eeprom X:\TEMP\build8376110162395595122.tmp\sketch_oct18a .cpp.elf X:\TEMP\build8376110162395595122.tmp\sketch_oct18a .cpp.hex
Размер скетча в двоичном коде: 7*430 байт (из 28*672 байт максимум)
Старый 19.10.2014, 03:47   #272
lti1
Аватар для lti1
т.е. Вот так?
void setup()
digitalWrite(analogPin, HIGH);
Keyboard.begin();
Да
Я первый день с ардуино, буду изучать конечно, но пока могу только готовые скетчи заливать)..... да и то как выянилось, без подсказок не обошлось))
Для получения значений Ваших кнопок используйте такой скетч:
Код:
int analogPin=A0;
int data;
void setup()
Serial.begin(9600);
void loop()
data=analogRead(analogPin);
Serial.println(data);
delay(1000);
В мониторе порта увидите значения.
Выход резистивных кнопок подключите к A0 pro micro.
Если в дальнейшем скетч pro micro не захочет заливаться попробуйте так.
Старый 19.10.2014, 12:26   #273
ВладимирC
Спасибо огромное
Старый 19.10.2014, 18:21   #274
ВладимирC
А возможно объединить это в один скетч, чтобы не перезаливать их туда сюда, а сразу вычислить кнопки и испытать, и перекинув проводов от кнопок? И если возможно, то как их состыковать?
Старый 19.10.2014, 19:44   #275
Chubaka885
Регион: 56
Машина: Toyota Corolla e150
Chubaka885 is a jewel in the roughChubaka885 is a jewel in the roughChubaka885 is a jewel in the roughChubaka885 is a jewel in the rough
Можно. Вот так.
Код:
int analogPin=A0;    //пин для подключения кнопок
int data;
unsigned long flag = 0;
unsigned long eventTime = 0;
unsigned long pauseMillis = 0;
void setup()
Serial.begin(9600);
Keyboard.begin();
void loop()
data=analogRead(analogPin); //читаем значение нажатой кнопки
delay(500);
//********************** Громкость ************************************
  if(data>=950 && flag == 0) // все кнопки отпущены
    eventTime=millis();
  if(millis()-eventTime>10 && millis()-eventTime<499 && data>=210 && data<=230 && flag == 0) // короткое нажатие кнопки от 10 до 499 миллисекунд (изменяется здесь millis()-eventTime>10 && millis()-eventTime<499)
    Remote.increase();
    flag = 5;
    delay(10);
    Remote.clear();
  if(millis()-eventTime>500 && data>=210 && data<=230 && flag == 5 || data>=210 && data<=230 && flag == 3) // удержание кнопки от 500 до ? миллисекунд (изменяется здесь millis()-eventTime>500)
    Remote.increase(); // действие после удержание кнопки, Увеличить громкость каждые 0,1 секунды
    flag = 3;
    Remote.clear();
    delay(100);
  if(millis()-eventTime>10 && millis()-eventTime<499 && data>=457 && data<=477 && flag == 0) // короткое нажатие кнопки от 10 до 499 миллисекунд (изменяется здесь millis()-eventTime>10 && millis()-eventTime<499)
    Remote.decrease();
    flag = 6;
    delay(10);
    Remote.clear();
  if(millis()-eventTime>500 && data>=457 && data<=477 && flag == 6 || data>=457 && data<=477 && flag == 3) // удержание кнопки от 500 до ? миллисекунд (изменяется здесь millis()-eventTime>500)
    Remote.decrease(); // действие после удержание кнопки, Уменьшить громкость каждые 0,1 секунды
    flag = 3;
    Remote.clear();
    delay(100);
//********************** AltTab + Play/pause ************************************
if(millis()-eventTime>10 && millis()-eventTime<499 && data>=567 && data<=587) // короткое нажатие кнопки от 10 до 499 миллисекунд (изменяется здесь millis()-eventTime>10 && millis()-eventTime<499)
    flag = 1;
  if(data>=950 && flag == 1 && pauseMillis == 0) // действие после короткого нажатия кнопки, Alt+Tab
    Keyboard.press(KEY_LEFT_ALT);
    Keyboard.press(KEY_TAB);
    Keyboard.release(KEY_TAB);
    flag = 0;
    pauseMillis = millis();
  if(data>=950 && flag == 1 && pauseMillis != 0) // действие после короткого повторного нажатия кнопки, Alt+Tab
    flag = 0;
  if(pauseMillis && millis()-pauseMillis >= 800 && data>=950) // && flag == 7 && data>=950)
    flag = 0;
    pauseMillis = 0;
    Keyboard.releaseAll();
  if(millis()-eventTime>500 && data>=567 && data<=587 && flag == 1) // удержание кнопки от 500 до ? миллисекунд (изменяется здесь millis()-eventTime>500)
    Remote.play_pause(); // действие после удержание кнопки, воспроизведение / пауза
    flag = 0;
    delay(10);
    Remote.clear();
//********************** Next и Fast Forward ************************************
  if(millis()-eventTime>10 && millis()-eventTime<499 && data>=0 && data<=10) // короткое нажатие кнопки от 10 до 499 миллисекунд (изменяется здесь millis()-eventTime>10 && millis()-eventTime<499)
    flag = 2;
  if(data>=950 && flag == 2) // действие после короткого нажатия кнопки, Next
    Remote.next();
    flag = 0;
    delay(10);
    Remote.clear();
  if(millis()-eventTime>500 && data>=0 && data<=10 && flag == 2 || data>=0 && data<=10 && flag == 3) // удержание кнопки от 500 до ? миллисекунд (изменяется здесь millis()-eventTime>500)
    Remote.forward(); // действие после удержание кнопки, Fast Forward
    flag = 3;
    Remote.clear();
    delay(100);
//********************** Previous и Rewind ************************************
  if(millis()-eventTime>10 && millis()-eventTime<499 && data>=74 && data<=94) // короткое нажатие кнопки от 10 до 499 миллисекунд (изменяется здесь millis()-eventTime>10 && millis()-eventTime<499)
    flag = 4;
  if(data>=950 && flag == 4) // действие после короткого нажатия кнопки, Previous
    Remote.previous();
    flag = 0;
    delay(10);
    Remote.clear();
  if(millis()-eventTime>500 && data>=74 && data<=94 && flag == 4 || data>=74 && data<=94 && flag == 3) // удержание кнопки от 500 до ? миллисекунд (изменяется здесь millis()-eventTime>500)
    Remote.rewind(); // действие после удержание кнопки, Rewind
    flag = 3;
    Remote.clear();
    delay(100);
  if(data>=950 && flag == 3 || data>=950 && flag == 5 || data>=950 && flag == 6) // действие после отпускания кнопки
    flag = 0;
Nexus 7 2012 (grouper), Cyanogenmod 11 - M10
фото установки Nexus 7 2012 & Toyota Corolla
Chubaka885 вне форума   Ответить с цитированием
Старый 19.10.2014, 20:40   #276
lti1
Аватар для lti1
Зачем? Это два разных скетча, малым Вы вычисляете значения своих резистивных кнопок и подставляете эти значения в большой скетч, а уже потом его заливаете и тестируете. Например у вас значение для Play/Pause 455, в данном скетче это значение 577, значит Вам необходимо заменить data>=567 && data<=587 на data>=445 && data<=465. И еще если объединить, то в Serial будут литься данные, а об delay(500); будет спотыкаться, не давая нормально работать кнопкам.
Старый 19.10.2014, 21:03   #277
ВладимирC
Для чего второй скетч, я прекрасно понял. А спросил, потому, что хотел не отходя от кассы попробовать. Потом понял, что чтобы значения изменить, все равно перезаливать надо)).
Старый 20.10.2014, 02:40   #278
ВладимирC
Еще вопрос, в основном скетче импользуется вход 6, в проверочном А0, почему? Если я ставлю резистор, не проще на одном порту и проверять и работать?
А, раз мы подтянули вход, то резистор не нужен, как я понимаю? Залил считывающий тест, пробовал резисторы разные подсовывать ( имитируя кнопки), вроде работает, на разные сопротивления, дает разные коды, без них шлет код 1022
Старый 20.10.2014, 15:06   #279
lti1
Аватар для lti1
Почему в основном скетче используется вход 6 не помню, возможно пожелание Chubaka885, вообще должен использоваться любой из аналоговых входов A0-A3 (Pro micro).
Резистор не нужен, я предоставлял Вам примерную схему подключения.
0 вольт - 0, 5 вольт - 1023
Аналого-цифровой преобразователь
Микроконтроллеры Atmega, используемые в Arduino, содержат шестиканальный аналого-цифровой преобразователь (АЦП). Разрешение преобразователя составляет 10 бит, что позволяет на выходе получать значения от 0 до 1023. Основным применением аналоговых входов большинства платформ Arduino является чтение аналоговых датчиком, но в тоже время они имеют функциональность вводов/выводов широкого применения (GPIO) (то же, что и цифровые порты ввода/вывода 0 - 13).
Старый 23.10.2014, 23:45   #280
Stray
Машина: Smart ForTwo
Stray is on a distinguished road
Уважаемые!
А что нужно отправить из Leonardo используя HID Keyboard для имитации кнопки выключения (гашения экрана)?
Перелопатил кучу инфы, ответ так и не найден.
Stray вне форума   Ответить с цитированием
Часовой пояс GMT +4, время: 01:46.
