Старый 20.12.2007, 22:18   #11
NSMax
Сибиряк
Аватар для NSMax
Машина: Jaguar X-Type
ELM 327 точно работает с опелевским HIGH-CAN (самой быстрой шиной). Что за обвязка незнаю.
Там стоит High-Speed CAN Transceiver MCP2551
Features
•Supports 1Mb/s operation
•Implements ISO-11898 standard physical layer requirements
•Suitable for 12V and 24V systems
•Externally-controlled slope for reduced RFI emissions
•Detection of ground fault (permanent dominant) on TXD input
•Power-on reset and voltage brown-out protection
•An unpowered node or brown-out event will not disturb the CAN bus
•Low current standby operation
•Protection against damage due to short-circuit conditions (positive or negative battery voltage)
•Protection against high-voltage transients
•Automatic thermal shutdown protection
•Up to 112 nodes can be connected
•High noise immunity due to differential bus implementation
•Temperature ranges:
-Industrial (I): -40°C to +85°C
-Extended (E): -40°C to +125°C
The MCP2551 is a high-speed CAN, fault-tolerant
device that serves as the interface between a CAN pro-
tocol controller and the physical bus. The MCP2551
provides differential transmit and receive capability for
the CAN protocol controller and is fully compatible with
the ISO-11898 standard, including 24V requirements. It
will operate at speeds of up to 1Mb/s.
Typically, each node in a CAN system must have a
device to convert the digital signals generated by a CAN
controller to signals suitable for transmission over the
bus cabling (differential output). It also provides a buffer
between the CAN controller and the high-voltage spikes
that can be generated on the CAN bus by outside
sources (EMI, ESD, electrical transients, etc.).
А так это в собраном за вечер виде (сорри за качество)
Старый 20.12.2007, 22:29   #12
Димон
Аватар для Димон
Машина: 09\Опиль\АстраХ
Для полного щщастья нехватает програмульки, чуть умнее гипертерминала, которая держит таблицу всех значений по адресам чтобы было видно какой адрес (например) реагирует на верчение ручки климата.....
Старый 20.12.2007, 22:31   #13
Димон
Аватар для Димон
2N.A.D.83, прости, нет у меня вагеновского разъема, не знаю распиновок. Народ болтает что если перепутать провода high-can-high и high-can-low ничего не сгорает, просто неработает. k-line у меня вообще ни разу в жизни не было, незнаю что за зверь.
качай tis какойнить.
Старый 20.12.2007, 22:38   #14
NSMax
Сибиряк
Аватар для NSMax
Как это нету вроде есть такое ТУЦ
Старый 20.12.2007, 22:58   #15
Димон
Аватар для Димон
Сообщение от NSMax Посмотреть сообщение
Супер. Все нужно!
зы. эх, говорили мне, учи немецкий, ая все английский да парлевуфрансе
Старый 20.12.2007, 23:02   #16
NSMax
Сибиряк
Аватар для NSMax
Супер. Все нужно!
А че это отменили?
Да ты спрашай помогем
Старый 04.01.2008, 22:41   #17
N.A.D.83
Машина: VW Passat1.8T
N.A.D.83 is on a distinguished road
Сообщение от pvn11 Посмотреть сообщение
Привет.Никто не подсоединял карпс семейство VW очень интересно так как сейчас собираюсь инсталировать в машинку.
Приветствую!
у меня подобная проблема хочу подсоединиться к своему VW passat 2001
возник такой вопрос - там есть К линия и контакты 6 и 14, те CAN
может ли быть два протокола в одной машине ?
если нет то как найти каким адаптером подключаться?
как определить есть что либо на К линии? можно ли просто померять напряжение мультиметром
Заранее спасибо
N.A.D.83 вне форума   Ответить с цитированием
Старый 06.02.2008, 00:53   #18
leman
Аватар для leman
Машина: Opel Astra х2
leman will become famous soon enoughleman will become famous soon enough
Ну как, есть ли успехи?
У самого стоит проблема впихнуть carpc в astra h, естественно хочется монитор вместо штатного дисплея впихнуть, а инфу в комп передать и как-нибудь во фронт-энд вписать... Не знаю правда, насколько это реально
Opel Astra'07
Постройка CarPC in progress:
Закупка компонентов 100%
Сборка 99%
Установка 99%
leman вне форума   Ответить с цитированием
Старый 12.02.2008, 22:32   #19
leman
Аватар для leman
Аууу Есть тут кто живой?
Кстати, у астры аш приемник с инфо дисплеем общается напрямую и через medium-speed can, а рулевые кнопки через can-модуль в рулевой колонке бродкастят в low-speed can вообще. Сами кнопки, правда, резистивные, т.е. в экстремальном варианте их можно напрямую к компу подключить через потроха от джойстика...
2 Димон
Что за адаптер работает у тебя с medium-speed can и чем он лучше по сравнению с обычным elm327? Умеет ли он с low-speed can работать?
Я для low-speed нашел пока только один, но он дикий небюджет (да и не адаптер он а целый девайс диагностический).
EDIT: нет, попутал, рулевые кнопки в mscan тоже шлют, причем с приемником они именно через него работают...
Opel Astra'07
Сборка 99%
Установка 99%
Старый 13.02.2008, 12:01   #20
Димон
Аватар для Димон
Моя приблуда ниразу не бюджетная, сидит на medium-CAN выдает рулевые кнопки (в резистивных сигналах кенвуд-альпайн-итп), асс, габариты, скорость итп. Штука фирменная т.е. даже если там и извесный проц стоит, то скорее всего с особой прошивкой. Написать программу врядли руки дойдут, остальные проблемы вроде как решены. Еще у меня нету high-can-usb адаптера.
Часовой пояс GMT +4, время: 02:32.
