Старый 29.08.2015, 10:25   #131
Lexx09
Машина: Приора хэтчбек
Попробуй так:
Код:
#pragma compile(Icon, "C:\Program Files (x86)\AutoIt3\Icons\au3script_v9.ico")
#Region ;**** Directives created by AutoIt3Wrapper_GUI ****
#AutoIt3Wrapper_Compression=4
#AutoIt3Wrapper_UseUpx=y
#AutoIt3Wrapper_Run_AU3Check=n
#EndRegion ;**** Directives created by AutoIt3Wrapper_GUI ****
#include <WindowsConstants.au3>
; Это команда на сон
Global $PBT_APMSUSPEND = 0x0004
Global $PBT_APMRESUMESUSPEND = 0x0007
Local $omyerror
$omyerror = ObjEvent("AutoIt.Error", "MyErrFunc")
Dim $vol_from_speed[201]
Global $rr = ObjCreate("RideRunner.sdk")
$hGUI = GUICreate("Restart", 100, 100, 1, 1)
GUIRegisterMsg($WM_POWERBROADCAST, "Standby")
; Запускаем GpsGate
ShellExecute("C:\Program Files (x86)\Franson\GpsGate 2.0\GpsGateXP.exe")
; Запускаем Bluestacks вместе с лаунчером MyLauncher
$Bluestacks_path = RegRead("HKEY_LOCAL_MACHINE\SOFTWARE\Bluestacks", "InstallDir")
ShellExecute($Bluestacks_path & "HD-RunApp.exe", "-p ru.znalexey.mylauncher -a ru.znalexey.mylauncher.LauncherActivity")
; Запускаем программу по коннекту интернета (У кого нет такой программы, тогда эту и следующие строки удалить!)
ShellExecute("C:\Program Files (x86)\SP Dialer\SP Dialer.exe")
_main()
Func myerrfunc()
	$hexnumber = Hex($omyerror.number, 8)
	Exit
EndFunc
Func _initvolarray()
	$delta = 0
	$vol_from_speed[0] = $delta
	For $i = 0 To 150 Step 10
		$tmp_vol_from_speed = $rr.getinfo("=$vol_from_speed_" & $i + 10 & "$") / 10
		For $j = 1 To 10 Step 1
			$delta = $delta + $tmp_vol_from_speed
			$vol_from_speed[$i + $j] = Round($delta, 2)
		Next
	Next
	For $i = 162 To 200 Step 1
		$vol_from_speed[$i] = Round($delta, 2)
	Next
EndFunc
Func _main()
	Global $iswork = 1
	Global $isrun = 0
	Global $name = "[CLASS:TSkinForm]"
	Global $namecontrol = ""
	Global $foobarwindowtitleprev = ""
	Global $speed_prev = Round(Number($rr.getinfo("$IsDriveSpd$")), 0)
	Global $speed_prev_round = Round($speed_prev, -1)
	Global $vol_from_speed_full = 0
	Global $vol_min = Number($rr.getinfo("=$vol_from_speed_min$"))
	Global $vol_max = Number($rr.getinfo("=$vol_from_speed_max$"))
	_initvolarray()
	$rr.execute("SetVar;vol_from_speed_full;" & Round($vol_from_speed[$speed_prev], 2))
	While $iswork
		$handle = WinGetHandle($name)
		If @error Then
			If $isrun Then
				$iswork = 0
			EndIf
		Else
			$isrun = 1
			If WinActive($name) OR WinActive("[CLASS:TOverlayForm]") OR WinActive("[CLASS:TPopupSkinForm]") OR WinActive("[CLASS:TModalSkinForm]") OR WinActive("[CLASS:TMediaForm]") Then
				$rr.execute("SETIND;!iCarDS_Active;ON")
			Else
				$rr.execute("SETIND;!iCarDS_Active;OFF")
			EndIf
		EndIf
		$volume = StringSplit($rr.getinfo("VOLUME"), "%")
		If @error = 0 Then
			$current_volume = Number($volume[1])
		Else
			$current_volume = 0
		EndIf
		$speed_current = Round(Number($rr.getinfo("$IsDriveSpd$")), 0)
		If $speed_current > $speed_prev Then
			$delta_vol = Round($vol_from_speed[$speed_current] - $vol_from_speed[$speed_prev], 2)
			If $current_volume + $delta_vol < $vol_max Then $rr.execute("volperc+;" & $delta_vol & "||SetVar;vol_from_speed_full;" & $vol_from_speed[$speed_current])
		Else
			If $speed_current < $speed_prev Then
				$delta_vol = Round($vol_from_speed[$speed_prev] - $vol_from_speed[$speed_current], 2)
				If $current_volume - $delta_vol > $vol_min Then $rr.execute("volperc-;" & $delta_vol & "||SetVar;vol_from_speed_full;" & $vol_from_speed[$speed_current])
			EndIf
		EndIf
		$speed_prev = $speed_current
		If Number($rr.getinfo("=$Is_new_vol_from_speed$")) = 1 Then
			_initvolarray()
			$rr.execute("SetVar;Is_new_vol_from_speed;0")
		EndIf
		Sleep(300)
	WEnd
EndFunc
Func Standby($hWnd, $Msg, $wParam, $lParam)
    Select
        ; Вход в спящий режим
        Case $wParam = $PBT_APMSUSPEND
            Suspend()
        ; Выход из спящего режима
        Case $wParam = $PBT_APMRESUMESUSPEND
            ResumeSuspend()
        Case Else
    EndSelect
EndFunc
Func Suspend()
    ; Закрываем iCarDS
    WinClose("iCar DS")
    ; Закрываем программу по коннекту интернета
    ProcessClose("SP Dialer.exe")
    ; Закрываем GpsGate
    WinClose("Franson GpsGate")
    ; Закрываем Блюстак
    ShellExecute("C:\Program Files (x86)\BlueStacks\HD-Quit.exe")
    If (ProcessWaitClose("iCarDS.exe", 3) == 0) Then
        ProcessClose("iCarDS.exe")
    EndIf
    If (ProcessWaitClose("SP Dialer.exe", 3) == 0) Then
    EndIf
    If (ProcessWaitClose("HD-Frontend.exe", 3) == 0) Then
        ProcessClose("HD-Frontend.exe")
    EndIf
EndFunc
Func ResumeSuspend()
    ; Запускаем GpsGate
    ; Запускаем iCarDS
    ShellExecute("C:\Program Files (x86)\TipTop software\iCar DS\iCarDS.exe")
EndFunc
Приора хэтчбек
Старый 29.08.2015, 12:34   #132
Krysanov
Аватар для Krysanov
Регион: 04
Машина: lexus rx300
Спасибо, попробую
Попробовал дома на ноуте
Скрипт компилировал, переименовал и подменил..
В планировщике задач все автозагрузки поотключал...
запустил икар, все запустилось, все хорошо.. закрыл крышку ноута, подождал пока не уснет.. открыл...
и.. чистый рабочий стол
Нажимаю на ярлык икара, - все запустилось..
Теперь я не пойму... а зачем были эти танцы с бубнами для последнего подмененного скрипта iCarMainScript, если пока не ткнешь в ярлык икара не заработает?
Или этот скрипт надо в автозагрузку закинуть? Тогда чем он отличается от
этого?
Последний раз редактировалось Krysanov; 29.08.2015 в 13:33.
Старый 29.08.2015, 13:50   #133
Lexx09
Это seriousstas что-то мутит.
Я - за отдельный скрипт! Правда, я пока не пользуюсь спящим режимом...
Приора хэтчбек
Старый 29.08.2015, 14:08   #134
Krysanov
Аватар для Krysanov
Регион: 04
Машина: lexus rx300
получается так.. запускаю САМ икар, переделанный скрипт iCarMainScript появляется в трее, загоняю в сон..просыпается ком .. ни икара ни скрипта ... и следа от них не осталось... Попробовал закинуть в автозагрузку скрипт, - та же песня..
Пока на отдельном скрипте посижу....
Lexx09, как в этом задержку на выход из сна уменьшить? ТОЧНЕЕ, чтобы икар быстрее загружался..!!
тут
Код:
покрутить?
Старый 29.08.2015, 14:12   #135
seriousstas
Машина: Nissan Qashqai+2
Lexx09
Да я только за десятки одновременно работающих скриптов , НО
считаю , что цикличные процессы вредят стабильности.
Скрипты сейчас везде и в Фубарах ,
в этом например :
http://zeremy.deviantart.com/art/FooTube-545591551
и в других программах - конфликтов не избежать .
Это видно и на разных видео - то прогу нужно дважды запускать,
то кнопки навигации не работают ...
Я в сборке Фубара использую таймеры и эмуляцию клавы ,
и если закрыть Икар при работающем скрипте из фубара (и ту-же запустить) - получим белое окно с ошибкой о конфликте и тд и тп .
Если есть способ скрипту отработать и выйти - то почему-бы нет ?
Добавленные команды в iCarMainScript точно умеют задержать отключение
винды и выгрузить необходимое (как писал) Krysanov - чистый экран .
А дальше - дело техники ...
Krysanov
Можешь запустить Икар через планировщик
Старый 29.08.2015, 14:26   #136
Krysanov
Аватар для Krysanov
Регион: 04
Машина: lexus rx300
Lexx09
Krysanov
Слушай, а зачем так, НАЗАД в БУДУЩЕЕ?? В этом скрипте есть все программы, которые загружаются и мне нужны... Этот же скрипт был у меня в автозагрузке и все работает..
Объясни чем твоя идея лучше (быстрее, надежней...) ? Как ты запускаешь икар и как он себя ведет после просыпания?
Старый 29.08.2015, 14:29   #137
Lexx09
Сделать апгрейд. Больше никак. Нет там никакой специальной задержки.
Сильно сомневаюсь в этом. А вот зависнувший/заглючивший один процесс, в который запихнуто все-все-все, приведет к краху всего. Да и отлаживать легче по отдельности.
Но хозяин барин, делайте, кому как удобнее.
Приора хэтчбек
Старый 29.08.2015, 15:26   #138
seriousstas
Lexx09
тут интересный пример :
http://www.pccar.ru/showthread.php?p=78811#post78811
А наша задача простая и согласен на все 100 ! ,что :
Я лишь за разнообразие вариантов , поэтому экспериментирую
Мой пример в шапке ни разу не подкачал это два крохотных скрипта , а теперь есть и (за что БОЛЬШОЕ спасибо!) :
http://pccar.ru/showpost.php?p=336689&postcount=107
который можно добавить для подстраховки в iCarMainScript,например , если Икар "растолстеет" со временем.
Krysanov какое будущее ? , я лишь написал
поробуй
, тк не стоят все эти проги , было интересно ,что получится.
Идею несколько раз озвучивал - искал способ (и нашел) - без дополнительных "следящих" скриптов , тк сталкивался с конфликтами в Икаре ,
который сам по-себе напичкан скриптами ...
все работает..
Это хорошо! Тему не зря подняли
Последний раз редактировалось seriousstas; 30.08.2015 в 13:52.
Старый 29.08.2015, 19:16   #139
Krysanov
Аватар для Krysanov
Регион: 04
Машина: lexus rx300
....я лишь написал
О, вот как !!...
Лично для меня - обсуждаемая тема приблизила к очередной минимизации моих действий после поворота ключа в машине.. В идеале хочу так.. повернул ключ зажигания и все само включилось, подхватилось .. а ты только "баранку" крутишь и новыми технологиями наслаждаешься....
Старый 29.08.2015, 19:26   #140
seriousstas
Да - не дело это ковырять шашечки , когда ехать надо )
Часовой пояс GMT +4, время: 01:21.
