Старый 18.05.2012, 10:04   #111
Dens-v
Машина: Hyundai Elantra
Dens-v is on a distinguished road
Скачал, запустил, в настройки тоже пустила, нажал на запись и на тебе...
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Exception: Failed creating compressed stream.
at AForge.Video.VFW.AVIWriter.Open(String fileName, Int32 width, Int32 height, Int32 asamples) in D:\PROGRAMS\CamWorker\Aforge\Video.VFW\AVIWriter.c s:line 239
at CamWorker.VideoWorker.CreateAVI() in D:\PROGRAMS\CamWorker\VideoWorker.cs:line 420
at CamWorker.CamWorker.button2_Click(Object sender, EventArgs e) in D:\PROGRAMS\CamWorker\CamWorker.cs:line 148
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5456 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
CamWorker
Assembly Version: 1.1.1.37814
Win32 Version: 1.1.1.*
CodeBase: file:///C:/CamWorker_1.1.3/CamWorker/Build/CamWorker.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 2.0.50727.5458 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
MainProg.Controls
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/CamWorker_1.1.3/CamWorker/Build/MainProg.Controls.DLL
Microsoft.DirectX.DirectDraw
Assembly Version: 1.0.2902.0
Win32 Version: 5.04.00.2904
CodeBase: file:///C:/CamWorker_1.1.3/CamWorker/Build/Microsoft.DirectX.DirectDraw.DLL
DSInterface
CodeBase: file:///C:/CamWorker_1.1.3/CamWorker/Build/DSInterface.DLL
Microsoft.DirectX
CodeBase: file:///C:/CamWorker_1.1.3/CamWorker/Build/Microsoft.DirectX.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Dens-v вне форума   Ответить с цитированием
Старый 18.05.2012, 13:18   #112
Likn
Регион: 69
Машина: Daihatsu YRV
Likn is on a distinguished road
Нужно кодек сменить, выставленный не поддерживает кжатие потоки почему-то.
Самодельная программа многокамерной видеорегистрации - http://pccar.ru/showthread.php?t=16241
Likn вне форума   Ответить с цитированием
Старый 18.05.2012, 17:00   #113
repon
Регион: 64
Машина: 15
repon is on a distinguished road
а какой камерой пишете и разрешение какое дает?
как в начале темы 800*600 ?
repon вне форума   Ответить с цитированием
Старый 18.05.2012, 17:15   #114
Dens-v
пока тестирую на ноуте со встроенной камерой, сейчас вроде запускается и пишет.
Так что вечером перенесу в машину и буду испытывать в полевых условиях, особенно на предмет просыпания и выхода из гибернации
Старый 18.05.2012, 19:06   #115
Likn
Регион: 69
У самого щас с310 основная, 800*600*20. И какая-то безродная 320*240*20. Кодек - XVID.
С просыпанием ничего обещать не могу, не тестировал.
Старый 19.06.2012, 11:22   #116
prts
Машина: dfgh
Likn
Попробовал программу, понравилась. Но сегодня резко ухудшилось качество изображения (во вложении 1- через программу, 2 - программа Web камеры).
Использую С910.
В чем может быть причина?
ID:	27122   Нажмите на изображение для увеличения
Старый 19.06.2012, 19:49   #117
prts
Машина: dfgh
Кто-нибудь пробовал программу под win 7x64?
У меня не хочет запускаться под 86 работает
Старый 21.06.2012, 21:40   #118
Likn
Регион: 69
prts - походу, уменьшено разрешение камеры. Камера скорее всего, "слетела". Например, из-за того, что неожиданно для программы оказалась в другом порту.
По поводу отказа в win 7x64 - пока не могу понять, в чем дело.
Старый 16.08.2012, 15:18   #119
prts
Машина: dfgh
Поставил на машину камеру С910, пишу через CamWorker. Одновременно пишутся через МиниКам (встроена в iCar) две аналоговые камеры (вперед и назад), также запущен iCar и встроенный в него CityGuide, а так же отдельно читалка книг.
Материнка Zotac, процессор Core i3, память 4 ГБ.
Проблемы: не выводится дата и время, не получилось подключить GPS (размножает xPort), звук пишется с ужасными искажениями (разобрать что выводит читалка не возможно) и плохого качества, видео записывается с ускорением. Когда ускорения видео нет - можно разобрать, что бормочет читалка, но таких кусков не более 20%.
P.S. программа определяет и плату видеозахвата. и Если перовой запустить CamWorker, то в Миникам не запускается одна камера (вперед). Поэтому сначала запускаю МиниКам, а потом CamWorker. Можно как-то сделать, чтобы программа не видела плату видеозахвата?
Что делаю не правильно?
Последний раз редактировалось prts; 16.08.2012 в 17:39. Причина: дополнил
Старый 30.08.2012, 15:16   #120
Likn
Регион: 69
Искажения звука и ускорение видео - от нехватки ресурсов. По идее, должна снижаться скорость записи, посмотрите, так ли это.
Где не выводится дата и время? На экране, или и в файле тоже? Плашка с датой и временем выводится в файл всегда, это жестко зашито.
Плату видеозахвата убрать из списка устройств не получится - она для программы такая же камера. Я натыкался на интересный баг винды - если запущено 2 камеры, 3я не запускается в принципе. Ничем. Где-то даже есть рекомендации по настройке системы для убирания этой проблемы.
Часовой пояс GMT +4, время: 04:59.
