Старый 23.04.2012, 09:35   #101
Likn
Регион: 69
Машина: Daihatsu YRV
Likn is on a distinguished road
Тогда я вообще ничего не понимаю. Попытаюсь поправить падение от сворачивания, может заодно и "починится" глюк с окном.
Likn вне форума   Ответить с цитированием
Старый 15.05.2012, 13:44   #102
Dens-v
Машина: Hyundai Elantra
Dens-v is on a distinguished road
с windows 7 программа так и не работает?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at CamWorker.CamSettingsForm..ctor(VideoWorker _vd, Configurer _cfg, CamWorker cmf) in D:\PROGRAMS\CamWorker\CamSettingsForm.cs:line 71
at CamWorker.CamWorker.button1_Click(Object sender, EventArgs e) in D:\PROGRAMS\CamWorker\CamWorker.cs:line 99
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5456 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
CamWorker
Assembly Version: 1.1.1.37814
Win32 Version: 1.1.1.*
CodeBase: file:///C:/Users/Administrator/Downloads/CamWorker_1.1.3/CamWorker/Build/CamWorker.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 2.0.50727.5458 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
MainProg.Controls
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Users/Administrator/Downloads/CamWorker_1.1.3/CamWorker/Build/MainProg.Controls.DLL
Microsoft.DirectX.DirectDraw
Assembly Version: 1.0.2902.0
Win32 Version: 5.04.00.2904
CodeBase: file:///C:/Users/Administrator/Downloads/CamWorker_1.1.3/CamWorker/Build/Microsoft.DirectX.DirectDraw.DLL
DSInterface
CodeBase: file:///C:/Users/Administrator/Downloads/CamWorker_1.1.3/CamWorker/Build/DSInterface.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Dens-v вне форума   Ответить с цитированием
Старый 15.05.2012, 14:50   #103
Ацкий_Кот
Аватар для Ацкий_Кот
Ацкий_Кот is on a distinguished road
Добавлю , в 7 , при нажатии на знак конфига вылетает вот такая ошибка, и при выходе из программы , и не видит вебку.
Подробная информация об использовании оперативной
(JIT) отладки вместо данного диалогового
окна содержится в конце этого сообщения.
************** Текст исключения **************
System.ArgumentOutOfRangeException: Индекс за пределами диапазона. Индекс должен быть положительным числом, а его размер не должен превышать размер коллекции.
Имя параметра: index
в System.ThrowHelper.ThrowArgumentOutOfRangeExceptio n(ExceptionArgument argument, ExceptionResource resource)
в System.ThrowHelper.ThrowArgumentOutOfRangeExceptio n()
в System.Collections.Generic.List`1.get_Item(Int32 index)
в CamWorker.CamSettingsForm.itemList1_SelectedIndexC hanged(Object sender, EventArgs e)
в CamWorker.CamSettingsForm..ctor(VideoWorker _vd, Configurer _cfg, CamWorker cmf)
в CamWorker.CamWorker.button1_Click(Object sender, EventArgs e)
в System.Windows.Forms.Control.OnClick(EventArgs e)
в System.Windows.Forms.Button.OnClick(EventArgs e)
в System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
в System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
в System.Windows.Forms.Control.WndProc(Message& m)
в System.Windows.Forms.ButtonBase.WndProc(Message& m)
в System.Windows.Forms.Button.WndProc(Message& m)
в System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
в System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
в System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Загруженные сборки **************
mscorlib
Версия сборки: 2.0.0.0
Версия Win32: 2.0.50727.5448 (Win7SP1GDR.050727-5400)
mscorlib.resources
CamWorker
Версия сборки: 1.1.1.37814
Версия Win32: 1.1.1.*
CodeBase: file:///Z:/CamWorker/CamWorker.exe
Версия Win32: 2.0.50727.5446 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Версия Win32: 2.0.50727.5453 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Версия Win32: 2.0.50727.5458 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
MainProg.Controls
Версия сборки: 1.0.0.0
Версия Win32: 1.0.0.0
CodeBase: file:///Z:/CamWorker/MainProg.Controls.DLL
Версия сборки: 1.0.2902.0
Версия Win32: 5.04.00.2904
CodeBase: file:///Z:/CamWorker/Microsoft.DirectX.DirectDraw.DLL
DSInterface
CodeBase: file:///Z:/CamWorker/DSInterface.DLL
Microsoft.DirectX
CodeBase: file:///Z:/CamWorker/Microsoft.DirectX.DLL
System.Windows.Forms.resources
Версия Win32: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_ru_b77a5c561934e089/System.Windows.Forms.resources.dll
************** Оперативная отладка (JIT) **************
Для подключения оперативной (JIT) отладки файл .config данного
приложения или компьютера (machine.config) должен иметь
значение jitDebugging, установленное в секции system.windows.forms.
Приложение также должно быть скомпилировано с включенной
отладкой.
Например:
<configuration>
</configuration>
При включенной отладке JIT любое необрабатываемое исключение
пересылается отладчику JIT, зарегистрированному на данном компьютере,
вместо того чтобы обрабатываться данным диалоговым окном.
Ацкий_Кот вне форума   Ответить с цитированием
Старый 15.05.2012, 14:52   #104
Ацкий_Кот
При этом версия из 80 поста этой темы отладочная нормально работает
Старый 15.05.2012, 14:55   #105
Ацкий_Кот
Разобрался, при отсутствии конфига программа вылетает, сама по умолчанию его не создает.
Старый 15.05.2012, 15:03   #106
Dens-v
У меня что то ни как не работает
Старый 15.05.2012, 15:29   #107
Ацкий_Кот
При сворачивании вылетает, и сжатия так понимаю нет, ибо 8секунд - 130мегоф...
Старый 17.05.2012, 22:35   #108
Likn
Регион: 69
Эххх... у меня действительно нет подопытной машины с семеркой. Кто бы помог?
При сворачивании вылетает, как уже писал - устройство теряется.
Сжатие настраивается через средства кодека. Наконец-то поставил вторую камеру в машину, нашел неприятный косяк - при старте зануляется положение картинки первой имеющейся камеры вместо первой используемой. На днях выложу обновление.
Еще раз - кто хочет помочь с запуском проги на семерке - буду рад, говорите.
UPD. Выложил чиненую версию, можно сворачивать. Правда, иногда все равно вылетает.
Самодельная программа многокамерной видеорегистрации - http://pccar.ru/showthread.php?t=16241
Последний раз редактировалось Likn; 17.05.2012 в 23:37.
Старый 18.05.2012, 07:54   #109
Dens-v
Сообщение от Likn Посмотреть сообщение
Я готов помочь, что требуется?
Старый 18.05.2012, 09:48   #110
Likn
Регион: 69
Требуется забрать проект(в 1 сообщении) и запустить его из-под студии на семерке, после чего сообщить, где упало и с каким текстом ошибки.
Часовой пояс GMT +4, время: 21:35.
