Вернуться   PCCar.ru - Ваш автомобильный компьютер > MP3Car ТехИнфа > Разработка программ > Программы управления > Cave Live!
Старый 31.07.2007, 13:36   #91
bluescreen25
Аватар для bluescreen25
bluescreen25 has a spectacular aura aboutbluescreen25 has a spectacular aura about
Сообщение от NSMax Посмотреть сообщение
Und wie mit meiner Bitte anlässlich Front und Rear in EQ?
For this option the soundcard must have multichannel. Ok most of the newer one have 5.1 or 7.1 so its possible to do. Now it depends on the soundcard hisself because each is from another firm. In the mixer-setup of your soundcard, is there to see each channel the card have?
If it is so, we can use the cAVe-Mixer-Id-function to control the channels.
Then we can develop to do the same output on new channel with slider to have front/rear.
If there are only 2 channels seen in your soundcard-mixer its more difficult because the soundcard can do multichannel but the easy way to have control of all soundcard,independed of firm and driver is away. So only a retrieving of channels out of driver is possible but we must look over much soundcards to do with cAVe.
@all:
cAVe soundengine can do FLAG and its possible, that there comes a DSP in V2.0, too....ohhh what i'am saying here...its..
One question: Is anyone using 5.1 or 7.1 in car ? With all amplifiers and loudspeakers ? In germany noone has asked.
regards, bluescreen25
bluescreen25 вне форума   Ответить с цитированием
Старый 31.07.2007, 13:54   #92
NSMax
Сибиряк
Аватар для NSMax
Машина: Jaguar X-Type
2 bluescreen25
Meine lautliche Karte modern, deshalb sie unterstützt den Mehrkanallaut. Wie Sie genügend bemerkt haben, diese Funktion gestimmt zu machen und, den Regler in EQ zu ertragen.
Старый 31.07.2007, 14:06   #93
archer
Аватар для archer
Машина: 2007\chery\Amulet
2 bluescreen25
Клять - ну на английском - ладно! Но по-немецки без перевода? Читаю ветку как шараду! Кончайте издеваться или дублируйте на русском или английском!
2bluescreen25 What radio modules is supported in Cave-Live? Can I use silabs USB Radio with your frontend?
2 Moderator - Не пора ли тему к фронтендам переместить - раз уж тут даже разработчик появляется?
Старый 31.07.2007, 14:29   #94
NSMax
Сибиряк
Аватар для NSMax
Сорри. Я попросил его сделать эквалайзер настраиваемым под разные звуковухи, вот и все
Старый 31.07.2007, 14:31   #95
bluescreen25
At the moment radio support:
- HQCT radio
- Andre radio (german build radio out of real carradio-hardware with comport)
In V2.0 it will be Silabs, too ! V2.0 comes out in december 2007.
Старый 31.07.2007, 15:03   #96
Sem_
Аватар для Sem_
Please, remove "Uhr" text near the clock, or make some window in SETUP to make possible to change it to any other text (Msk, Gmt, for ex.)
Thank you!
Старый 31.07.2007, 15:12   #97
terracan
Аватар для terracan
Машина: Terracan
А самому поправить в live.ini слабо?
Старый 31.07.2007, 15:14   #98
Sem_
Аватар для Sem_
Сообщение от terracan Посмотреть сообщение
Я даже в теле проги правил - не стартует... А в инишнике не догадался
2bluescreen25 - I am sorry It is possible in live.ini, now I am see
Старый 31.07.2007, 16:01   #99
bluescreen25
Сообщение от Sem_ Посмотреть сообщение
Thank you!
go to \Skins and open live.ini. there search in text for "uhr" and set new text.
Thank you !
Старый 31.07.2007, 16:16   #100
terracan
Аватар для terracan
Машина: Terracan
Как ты наверно догадался в нем можно весь скин перелопатить, что я и сделал.
т.к. кнопки управления вверху и внизу были не удобные для тыкания пальцем на маленьком экране.
Часовой пояс GMT +4, время: 21:43.
