Старый 20.02.2009, 12:23   #181
anator
Аватар для anator
Регион: 28
Машина: LAND CRUISER 80
anator is on a distinguished road
Хочу поменять стекло в своем мониторе, кто нибудь заказывал в фирме Sensis?, http://www.sensis.ru/catalog/rezz/2002.html , и подходит ли данное стекло на наш моник?
anator вне форума   Ответить с цитированием
Старый 25.02.2009, 22:12   #182
anator
Аватар для anator
Регион: 28
Кто менял тач, на этом монике..?, где стекло брали?, посоветуйте..
Старый 18.03.2009, 00:54   #183
coucouillu
Регион: 10
Машина: h
coucouillu is on a distinguished road
По умолчанию PCM-750T settings for 800*600 compatibility
Hi,
I just bought a PCM-750T thanks to someone of this forum.
I have played around with it and noticed that the picture wasn't good enough in 800*600 resolution.
I do not know if you have found solution (can't read Russian) but I found that :
1) In PC mode, push OSD button. The OSD menu appears
2) In the bottom, you have 3 pages: [VIDEO] [SYSTEM] [ABOUT]
3) Select [ABOUT]
4) In [ABOUT], you should have:
[1] MODEL No [DAH-700M]
[2] VERSION [ Ver 1.XX ]
[3] BUILD [ XXXX ]
[4] USED TIME [ XXXX ]
[5] VGA CARD [VGA TYPE-A]
5) Click on [VGA TYPE-A]. It should be highlighted in blue
6) Now with CH+ and CH- button (Channel+ and Channel-), you could change the mode in [VGA TYPE-A], [VGA TYPE-B] or [VGA TYPE-C]. Select [VGA TYPE-B] or [VGA TYPE-C] and the click on “SET” in the upper right corner to save settings
7) To finish, exit PC MODE : Push “MODE” button. Go to PC mode again by pressing “MODE” (AV1-> AV2-> CCD-> PC). The resolution should now appears good.
In TYPE-A mode, you will have problems in 800*600 resolution. This mode is factor default. You have to change it.
Please tell if it works for you?
Brice.
Последний раз редактировалось coucouillu; 21.07.2009 в 12:18.
coucouillu вне форума   Ответить с цитированием
Старый 18.03.2009, 05:24   #184
Glouck
Машина: Nissan Elgrand
Glouck will become famous soon enough
Сообщение от coucouillu Посмотреть сообщение
Yes, it works. This solution was posted a couple of months ago, but in russian.
Anyway, thanks for info.
Glouck вне форума   Ответить с цитированием
Старый 26.03.2009, 23:01   #185
Parnisha
Регион: 29
Parnisha is on a distinguished road
Сообщение от SergeyXL Посмотреть сообщение
А вообще может он автоматически включаться и выезжать при включении заднего хода
Я через диод провод с заднего хода на АСС подал и теперь даже если всё отключено, при вкл. заднего хода моник включается и выдвигается, а после выкл.- задвигается и отключается
Parnisha вне форума   Ответить с цитированием
Старый 27.03.2009, 14:07   #186
Z@GR
Аватар для Z@GR
Сообщение от Parnisha Посмотреть сообщение
схему сюда нарисуй пжста, если не сложно
Старый 27.03.2009, 16:44   #187
Parnisha
Регион: 29
Художник я не в пи..ду
У меня правда схема посложней.Провод от зажигания я вообще не подсоединял, а таким же макаром(через диод) подал с БП CarPC. чтоб PC тоже сам моник включал и ещё кнопку поставил, чтоб черз кнопку в этот же провод +подавать, чтоб просто ТВ смотреть, без CarPC
Старый 12.04.2009, 18:05   #188
anator
Аватар для anator
Регион: 28
Подскажите пожалста, как вывести отдельно кнопки?, сейчас слепил себе на панель, на место родной навигашки, короб, под этот моник. вопрос такой. как вывести с этого моника отдельно кнопку включения , кнопку MODE, и и глаз дистанционки ?,остальные не важны, можно просто подпаяться к кнопкам, или все серьезнее?
Старый 13.04.2009, 03:07   #189
Z@GR
Аватар для Z@GR
Сообщение от anator Посмотреть сообщение
можно, мне кажется, там обычные микрики припаяны
см картинку:
Старый 13.04.2009, 12:36   #190
Lion008
Аватар для Lion008
Регион: 56
Машина: Lancer 9
По умолчанию Prology PCM 750T
может у кого есть б.у. такой, только комплект
собирал себе комп в машину:
Все что осталось
моник Mystery MMT-8120s
Wi-Fi модуль mini-PCI Qcom
винт 160 Gb SATA-II 300 TOSHIBA 2.5"
приводDVD±R/RW Pioneer DVR-TS08
D-Link 7-port USB2.0 Hub + б.п.
корпус Cooler Master Elite100
читалка для машинки OBDII USB ELM327 v1.3 адаптер
prology pcm-750t, prology гори в аду, геморрой
Часовой пояс GMT +4, время: 19:03.
