#1891 |
![]() Регистрация: 17.10.2015
#1892 |
#1893 | |
![]() Регистрация: 14.06.2013
С этим - тоже всё нормально : Код:
// ==PREPROCESSOR== // @name "TOUCH LIBRARY PANEL TREE mod_5" // @version "1.0" // @author "Vo Thanh Dat moded by Terro" // @feature "watch-metadb" // @tooltip "custom-paint" // ==/PREPROCESSOR== // //=========================for full functionality use WSH Panel MOD 1.5.10 //======================================================================= Color change from line 104 - 107 function RGB(r,g,b) { return (0xff000000|(r<<16)|(g<<8)|(b)); } function RGBA(r, g, b, a) { return ((a << 24) | (r << 16) | (g << 8) | (b)); } function test_perfomance(){ } var slide_r = window.GetProperty("Slide_right",50) var lbdn = 0; var y_start = 0; var y_end = 0; var y_delta = 0; var form_text = "", form_text_b = "", form_text_b_ = "", form_his = [], form_his_ = []; var char_index = [], playlist = [], playlist_dr = [], index_search = [], index_search_ = [], index_path = [], list = plman.GetPlaylistItems(-1), list_; var m_x = 0,m_y = 0, ww = 0,wh = 0, bold_start = 0,bold_end = 0, mm_x = 0,mm_y =0,m_tam = -1, idx_idx = 0, scroll = 0,scroll_ = 0,scroll__ = 0,scroll___ = 0, mouse_index = -1, form_text_cusor = 0, form_text_cusor_x = 0, repaint_visible = 0, time_dl = 0; //=====================added var g_time000 = window.SetInterval(on_timer, 16); //===================== var time111 = (new Date().getTime()), time222 = time111, time333 = time111; var fso = new ActiveXObject("Scripting.FileSystemObject"), WshShell = new ActiveXObject("WScript.Shell"), htmlfile = new ActiveXObject('htmlfile'), vbe = new ActiveXObject('ScriptControl'); var time_h = fb.CreateProfiler(), time_repaint = fb.CreateProfiler(), time200 = fb.CreateProfiler("aaaa"), time_s = fb.CreateProfiler(); var mouse_l_hold = false,mouse_l_hold_f = false, window_visible = false,on_form = false, mouse_hold = false,mouse_drag = false, hold_shift = false,hold_ctrl = false, hold_scroll = false,mouse_in = false, repaint_f1 = false,repaint_f2 = false,repaint_f = false, repaint_main = true,repaint_main1 = true,repaint_main2 = true, form_text_cusor_hiden = true; var shift_index = 0, last_choose = -1, selected_cusor = -1; var grouph_by = window.GetProperty("Grouph by",0), auto_colapse = window.GetProperty("auto colapse",true), auto_exppant = window.GetProperty("auto exppant",true), show_scripts = window.GetProperty("show_scripts",true), grouph_option = window.GetProperty("grouph_option",""), search_async = window.GetProperty("search_async",true), font_size = window.GetProperty("font_size",20), library_path = window.GetProperty("Library path",""), istranparent = window.GetProperty("tranparent",true), heigh_row = window.GetProperty("heigh_row",30), Tooltip = window.GetProperty("Tooltip",false), Font_name = window.GetProperty("Font_name","Segoe UI"), time_delay_search = window.GetProperty("time_delay_search",200); var g_tooltip = window.CreateTooltip(), time_tooltip = fb.CreateProfiler("Time tooltip"), tooltip_state = false,time_tooltip_ = 0; g_tooltip.Text = " "; var qsearch = "", qsearch_t = fb.CreateProfiler(), qsearch_lidx = [],qsearch_idx = 0; g_tooltip.SetDelayTime(3, 0); var library_path_ = library_path.split(";"); var choose_playlist = plman.GetPlaylistItems(-1); var time_debug = [],time_c = 0; var color_text = RGB(153,141,249);//0xff998DF9; //================ Text Color var background_color = 0xff000000;//================= Background Color var choose_background_color = RGB(203,50,50)//0xFF8B0000;//============== Select Color var alfa_fade_color = RGBA(40,30,20,150);//====================== Alfa fade Background (if dont need comment line 913) var art_alb_sort = "\\%album artist%|%album%|%track number%|%title%"; var alb_sort = "\\%album%|%track number%|%title%"; var grouph_opt = grouph_option.split("|"); var g_font,g_font2,g_font3,g_font_q,g_font_marker; var img_blend_1,img_blend_2; var playlist_cache_name = "Media Library"; setfont(); var exppant_, research = false, search_done = false, research_k = 0; vbe.Language = 'VBScript'; window.DlgCode = 0x0081 ; var lib_search = ""; function indexer(){ var total = list.Count; index_search = []; index_path = []; index_path_ = []; var TitleFormat = "[$if(%title%,$replace(%title%,'&','and'),'N/A')] ^^ %album artist% ^^ %album% ^^ %genre% ^^ $if(%path%,$replace(%path%,'&','and'),'N/A') ^^ %composer% ^^ %performer% ^^ %comment%"; var FoobarTitleFormat = fb.TitleFormat(TitleFormat); var string = "", count = 0; for(var i = 0;i < total;i++){ string = FoobarTitleFormat.EvalWithMetadb(list.Item(i)); index_search[count] = string; index_search_[count] = string.toLowerCase(); count++; } switch(grouph_by){ case 0: for(var i = 0;i < total;i++){ string = index_search[i].split(" ^^ ")[4]; for(var j = 0;j < library_path_.length;j++) string = string.replace(library_path_[j],""); index_path[i] = string.split("\\")[0]; } break; case 1: for(var i = 0;i < total;i++){ string = index_search[i].split(" ^^ ")[1]; index_path[i] = (string.length < 2)?"Unknow Artist":string; } break; case 2: for(var i = 0;i < total;i++){ string = index_search[i].split(" ^^ ")[2]; index_path[i] = (string.length < 2)?"Unknow Album":string; } break; default: for(var i = 0;i < total;i++){ index_path[i] = fb.TitleFormat(grouph_opt[0]).EvalWithMetadb(list.Item(i)); } break; } } function get_library(reload){fb var Time_library = fb.CreateProfiler("Time Out Refresh library"); var pl_name = "", pl_idx = -1,list_;//,sort_patten; for(var i=0; i < plman.PlaylistCount; i++) { pl_name = plman.GetPlaylistName(i); if(pl_name == "Media Library") { pl_idx = i; break; } } switch(grouph_by){ case 1:sort_patten = art_alb_sort; break; case 2:sort_patten = alb_sort; break; case 3:sort_patten = grouph_option; break; } if(pl_idx < 0) { pl_idx = plman.PlaylistCount; fb.CreateAutoPlaylist(pl_idx,"Media Library","ALL",""); list = plman.GetPlaylistItems(pl_idx); (grouph_by == 0) && list.OrderByFormat(fb.TitleFormat("%path%"), 1); (grouph_by > 0) && list.OrderByFormat(fb.TitleFormat((grouph_by == 3)?grouph_option:art_alb_sort), 1); plman.InsertPlaylistItems(pl_idx,0,list); }else if(reload){ fb.RemovePlaylist(pl_idx); fb.CreateAutoPlaylist(pl_idx,"Media Library","ALL",""); list = plman.GetPlaylistItems(pl_idx); (grouph_by == 0) && list.OrderByFormat(fb.TitleFormat("%path%"), 1); (grouph_by > 0) && list.OrderByFormat(fb.TitleFormat((grouph_by == 3)?grouph_option:art_alb_sort), 1); plman.InsertPlaylistItems(pl_idx,0,list); }else list = plman.GetPlaylistItems(pl_idx); (grouph_by == 0) && list.OrderByFormat(fb.TitleFormat("%path%"), 1); (grouph_by > 0) && list.OrderByFormat(fb.TitleFormat((grouph_by == 3)?grouph_option:art_alb_sort), 1); test_perfomance(); Time_library.Print(); Time_library = fb.CreateProfiler("Time Out Indexer library"); indexer(); Time_library.Print(); } get_library(); function match(input, str){ for(var i in str){ if(input.indexOf(str[i]) < 0) return false; } return true; } function prcess_string(str){ str_ = []; str = str.toLowerCase(); var str = str.split(" ").sort(); for(var i in str){ if(str[i] != "") str_.push(str[i]); } return str_; } var timeaaaa = fb.CreateProfiler(); function get_pl_tree(start,string_,force){ var Time = fb.CreateProfiler(); if(start == null){ scroll = 0;start = 0;form_text_b_ = form_text; string_ = form_text; playlist = []; list_ = plman.GetPlaylistItems(-1); timeaaaa.Reset(); }else if(form_text_b_ != form_text){ fb.trace("Break -- -- -- -- Form text change"); return; } var i = playlist.length,k = start,temp = ""; str = prcess_string(form_text); var path = "",string_add = "",temp = "",string = "",total = list.Count,count = 0; var string_compare = (i > 0)?(playlist[i-1].name):"123456789123456789"; while(k < total){ count = 0; while(count < 200 && k < total){ count++; if(!match(index_search_[k],str)){ k++;continue; } string = index_search[k]; temp = index_path[k]; if(string_compare.toUpperCase() != temp.toUpperCase()){ string_compare = temp; playlist[i] = new Object(); playlist[i].name = temp; playlist[i].alpha = 0; playlist[i].child = []; playlist[i].pl = plman.GetPlaylistItems(-1); playlist[i].pl.Add(list.Item(k)); i++; }else{ playlist[i-1].pl.Add(list.Item(k)); } k++; } if(!force && Time.Time > 30){ research = true; research_k = k; return; } } repaint_main1 = repaint_main2; //fb.trace("Timeout break : " + Time.Time); fb.trace("Searching Done : " + timeaaaa.Time/1000); tree_to_list(playlist,0); if(auto_exppant && playlist.length == 1) tree_expant(playlist[0]); } function tree_minimum(obj){ obj.child = []; tree_to_list(playlist,0); } function tree_collasp(obj){ var child_ = 0; if(obj.lv == 0){ for(var i = 0;i < playlist.length;i++){ child_ += playlist[i].child.length; playlist[i].child = []; } }else{ var parrent = playlist_dr[obj.pr]; for(var i = 0;i < parrent.child.length;i++){ child_ += parrent.child[i].child.length; parrent.child[i].child = []; } } return child_; } function sorrt(a,b){ return (a.name > b.name)?1:-1; } function tree_expant(obj){ var i = 0,j = 0,k = 0; var path = "",string_compare = "123456789123456798",string_add = "",temp = "",meta,album_artist = "",title = "",item__ = false,track = ""; var FoobarTitleFormat = fb.TitleFormat(" $caps([$num(%track number%,2). ] $if(%title%,$replace(%title%,'&','and'),'N/A') [- $if(%artist%,$replace(%artist%,'&','and'),'N/A')])"); while(k < obj.pl.Count){ path = get_fol_path(obj.pl.Item(k),obj.lv+1); if(obj.leaf){ k++; continue; } item__ = false; if(path == "aaaaaa"){ path = FoobarTitleFormat.EvalWithMetadb(obj.pl.Item(k)); item__ = true; } if(string_compare.toUpperCase() != path.toUpperCase()){ string_compare= path; obj.child[i] = new Object(); obj.child[i].name = path; obj.child[i].alpha = 0; obj.child[i].child = []; obj.child[i].leaf = item__; obj.child[i].pl = plman.GetPlaylistItems(-1); obj.child[i].pl.Add(obj.pl.Item(k)); i++; }else{ obj.child[i-1].pl.Add(obj.pl.Item(k)); } k++; } obj.child.sort(sorrt); tree_to_list(playlist,0); if(auto_exppant && obj.child.length == 1 && !obj.child[0].leaf){ tree_expant(obj.child[0]); } } function tree_to_list(obj,lv){ var parrent = playlist_dr.length - 1; if(lv == 0) playlist_dr = []; for(var i = 0;i < obj.length;i++){ var idx = playlist_dr.length; playlist_dr[idx] = obj[i]; playlist_dr[idx].lv = lv; playlist_dr[idx].pr = parrent; playlist_dr[idx].idx = idx; playlist_dr[idx].choose = false; if(exppant_ == obj[i]) //=====================change scroll = (idx- Math.round(m_y/heigh_row-1.5))*heigh_row;//=====================change if(obj[i].child.length > 0){ tree_to_list(obj[i].child,lv+1); } } } function get_fol_path(item,lv){ switch(grouph_by){ case 0: var string = item.Path; for(var i = 0;i < library_path_.length;i++) string = string.replace(library_path_[i],""); for(var i = 0;i < lv && string.indexOf("\\") != -1;i++) string = string.substr(string.indexOf("\\")+1); return (string.indexOf("\\") == -1)?("aaaaaa"):(string.substring(0,string.indexOf("\\"))); break; case 1: switch(lv){ case 0: return fb.TitleFormat("$caps($if(%album artist%,%album artist%,Unknow Artist))").EvalWithMetadb(item); case 1: return fb.TitleFormat("$caps($if(%album%,%album%,Unknow Album))").EvalWithMetadb(item); default: return "aaaaaa"; } break; case 2: if(lv == 0){ return fb.TitleFormat("$caps($if(%album artist%,%album artist%,Unknow Artist) - $if(%album%,%album%,Unknow Album))").EvalWithMetadb(item); }else return "aaaaaa"; break; default: if(lv < grouph_opt.length){ return fb.TitleFormat(grouph_opt[lv]).EvalWithMetadb(item); }else return "aaaaaa"; break; } } var tmp_out; function on_size(){ ww = window.Width; wh = window.Height; scroll_++; repaint_main1 = repaint_main2; repaint_f1 = repaint_f2; tmp_out && window.ClearInterval(tmp_out); tmp_out = window.SetInterval(function(){ if(window.IsVisible){ img_blend_2 = null; create_blend(); repaint_main1 = repaint_main2; repaint_f1 = repaint_f2; tmp_out && window.ClearInterval(tmp_out); } },500); } function get_cusor_index(x){ var result = form_text.length; while(char_index[result] > x ) result--; return (result > 0)?result:0; } function refresh_char_index(gr){ char_index = []; for(var i = 0;i < form_text.length + 1;i++) char_index[i] = gr.EstimateLineWrap(form_text.substr(0,i),g_font,ww).toArray()[1]; } //===================================================== function on_mouse_lbtn_up(x,y,mask){ lbdn = 0; y_start = y; if(mouse_drag && x > ww) add_playlist(choose_playlist); mouse_drag = mouse_hold = mouse_l_hold = mouse_l_hold_f = hold_scroll = false; var tam = Math.round((y + scroll - heigh_row * 1.5)/heigh_row); if(y > heigh_row && tam < playlist_dr.length && tam >= 0 && check_item(playlist_dr[tam],x,y)){ (mm_x == x && mm_y == y && !utils.IsKeyPressed(0x11)) && on_chose(tam,!(mm_x == x && mm_y == y)); } } function on_mouse_lbtn_dblclk(x,y,mask){ var tam = Math.round((y + scroll - heigh_row*1.5)/heigh_row); if(y > heigh_row && tam < playlist_dr.length && tam >= 0 && check_item(playlist_dr[tam],x,y)) apply_playlist(playlist_dr[tam].pl); else if(y < heigh_row) on_mouse_lbtn_down(x,y,1.5); else on_mouse_lbtn_down(x,y,mask); } function check_item(obj,x,y){ if(!obj) return false; return (x - slide_r > (heigh_row * (obj.lv + 1)) && x - slide_r < (heigh_row * (obj.lv + 1) + obj.rg)); } //====================================================== function on_mouse_lbtn_down(x,y,mask){ lbdn = 1; y_start = y; g_drag = false; mouse_l_hold_f = on_form = (y < heigh_row); mouse_l_hold = !mouse_l_hold_f; if(y < heigh_row){ if(x < ww - heigh_row){ form_text_cusor = get_cusor_index(x); repaint_f1 = repaint_f2; form_text_cusor_hiden = true; time111 = (new Date()).getTime(); if(mask == 1.5){ bold_start = (" " + form_text + " ").lastIndexOf(" ",form_text_cusor); bold_end = (" " + form_text + " ").indexOf(" ",form_text_cusor+1)-1; }else bold_start = bold_end = form_text_cusor; }else if(x > ww - heigh_row){ bold_start = bold_end = form_text_cusor = 0; form_text = ""; time333 = (new Date()).getTime() + 800; } return; } if(y > heigh_row ){ var tam = Math.round((y + scroll - heigh_row * 1.5)/heigh_row); if(tam < playlist_dr.length && tam >= 0){ var playlist_tmp = playlist_dr[tam]; if(heigh_row * (playlist_tmp.lv + 1)> x - slide_r && heigh_row * playlist_tmp.lv < x - slide_r){ //TREE EXPANT OR COLAPSE if(playlist_tmp.child.length > 0){ tree_minimum(playlist_tmp); }else{ exppant_ = playlist_tmp; auto_colapse && tree_collasp(playlist_tmp); tree_expant(playlist_tmp); //tree_expant(playlist_dr[tam]) } }else if(check_item(playlist_tmp,x,y)){ //ITEM CHOOSE mm_x = x;mm_y = y; mouse_drag = true; if(!playlist_tmp.choose){ on_chose(tam,playlist_tmp.choose); selected_cusor = tam; mouse_hold = true; } else if(utils.IsKeyPressed(0x11)){ on_chose(tam,playlist_tmp.choose); } }else on_chose(-1); repaint_main1 = repaint_main2; repaint_f1 = repaint_f2; }else on_chose(-1); } if(playlist_dr.length * heigh_row > wh && x > ww - 8){ hold_scroll = true; scroll = Math.round((((y - heigh_row) * (playlist_dr.length * heigh_row ) / (wh - heigh_row)) - (wh - heigh_row)/2)/heigh_row-0.5)*heigh_row; } } function on_chose(index,mouse_up){ repaint_main1 = repaint_main2; if(index == -1){ for(var k = 0;k < playlist_dr.length;k++) playlist_dr[k].choose = false; }else if((utils.IsKeyPressed(0x10) || mouse_hold) && last_choose > -1){ choose_playlist = plman.GetPlaylistItems(-1); var dd = (index > last_choose)?1:-1; if(!utils.IsKeyPressed(0x11)){ for(var k = 0;k < playlist_dr.length;k++) playlist_dr[k].choose = false; } for(var k = last_choose; ;k += dd){ playlist_dr[k].choose = true; choose_playlist.AddRange(playlist_dr[k].pl); if(k==index) break; } repaint_main1 = repaint_main2; }else if(utils.IsKeyPressed(0x11)){ playlist_dr[index].choose = !(playlist_dr[index].choose); playlist_dr[index].choose && choose_playlist.AddRange(playlist_dr[index].pl); last_choose = index; }else if(!mouse_up){ choose_playlist = plman.GetPlaylistItems(-1); for(var k = 0;k < playlist_dr.length;k++) playlist_dr[k].choose = false; playlist_dr[index].choose = true; choose_playlist.AddRange(playlist_dr[index].pl); last_choose = index; } } function check_playlist(name){ var pl_name = "", pl_idx = -1; for(var i=0; i < plman.PlaylistCount; i++) { pl_name = plman.GetPlaylistName(i); if(pl_name == name) { pl_idx = i; break; } } return pl_idx; } function on_char(code){ time333 = (new Date()).getTime(); var input = String.fromCharCode(code); if(on_form){ form_text_cusor_hiden = true; selected_cusor = -1; switch(code){ case 13://ENTER if(form_text.length < 3) break; str = prcess_string(form_text); var total = list.Count; var pltemp = plman.GetPlaylistItems(-1); for(var i = 0;i < total;i++) if(match(index_search_[i],str)) pltemp.Add(list.Item(i)); apply_playlist(pltemp); pltemp.Dispose(); break; case 25: form_his.push(form_text); if(form_his.length > 30) form_his.shift(); if(form_his_.length > 0) form_text = form_his_.pop() + ""; break; case 26: form_his_.push(form_text); if(form_his_.length > 30) form_his.shift(); if(form_his.length > 0) form_text = form_his.pop() + ""; break; case 1://CTRL + A bold_start = 0; bold_end = form_text.length; break; case 3: // COPPY (bold_start != bold_end) && htmlfile.parentWindow.clipboardData.setData('text',form_text.substring(bold_start,bold_end)); break; case 24://CUT (bold_start != bold_end) && htmlfile.parentWindow.clipboardData.setData('text',form_text.substring(bold_start,bold_end)); case 8://DELETE save_form_his(); if(bold_start == bold_end){ form_text = form_text.substring(0,form_text_cusor-1) + form_text.substring(form_text_cusor,200); if(form_text_cusor > 0) form_text_cusor--; bold_end = bold_start = form_text_cusor; }else{ form_text = form_text.substring(0,bold_start) + form_text.substring(bold_end,200); form_text_cusor = bold_start; bold_end = bold_start; } break; case 22://CTRL + V//PASTE input = htmlfile.parentWindow.clipboardData.getData('text'); default: //CHAR save_form_his(); if(char_index[form_text.length] + heigh_row >= ww - 10) break; if(bold_start == bold_end){ form_text = form_text.substring(0,form_text_cusor) + input + form_text.substring(form_text_cusor,200); form_text_cusor += input.length; bold_end = bold_start = form_text_cusor; }else{ form_text = form_text.substring(0,bold_start) + input + form_text.substring(bold_end,200); form_text_cusor = bold_start + input.length; bold_end = bold_start; } break; } repaint_f1 = repaint_f2; }else{ //============================================================qsearch_t var str,end_,lg,i,search_ = true; qsearch_t.Reset(); switch(code){ case 13://ENTER qsearch = ""; break; case 8://DELETE qsearch = qsearch.substr(0,qsearch.length - 1); break; case 60: case 44: qsearch_idx--; search_ = false; break; case 62: case 46: qsearch_idx++; search_ = false; break; case 39 : case 37 : search_ = false; break; break; default: qsearch += input; break; } str = prcess_string(qsearch == ""?"@@@@":qsearch); choose_playlist = plman.GetPlaylistItems(-1); end_ = playlist_dr.length; if(search_){ str = prcess_string(qsearch == ""?"@@@@":qsearch); qsearch_lidx = []; for(i = 0;i < end_;i++){//String.toLowerCase if(match(playlist_dr[i].name.toLowerCase(),str)){ qsearch_lidx[qsearch_lidx.length] = i; playlist_dr[i].choose = true; choose_playlist.AddRange(playlist_dr[i].pl); }else playlist_dr[i].choose = false; } }else for(i = 0;i < end_;i++) playlist_dr[i].choose = false; lg = qsearch_lidx.length; qsearch_idx += lg; if(lg != 0){ selected_cusor = qsearch_lidx[qsearch_idx%lg]; scroll = (selected_cusor - 5) * heigh_row; !search_ && on_chose(selected_cusor); } repaint_main1 = repaint_main2; } } function save_form_his(){ if(time_h.Time < 100) return; form_his.push(form_text); form_his_ = []; if(form_his.length > 30) form_his.shift(); time_h.Reset(); } function on_key_down(vkey) { switch(vkey){ case 0x25:case 0x27: if(on_form){ if(vkey == 0x25 && form_text_cusor > 0) form_text_cusor--; if(vkey == 0x27 && form_text_cusor < form_text.length) form_text_cusor++; if(hold_shift){ bold_start = Math.min(form_text_cusor,shift_index); bold_end = Math.max(form_text_cusor,shift_index); }else bold_start = bold_end = form_text_cusor; }else if(selected_cusor >= 0){ on_form = false; if(vkey == 0x25){ if(playlist_dr[selected_cusor].child.length > 0){ var tmp = playlist_dr[selected_cusor]; tree_minimum(tmp); on_chose(tmp.idx); selected_cusor = tmp.idx; }else try{ var tmp = playlist_dr[playlist_dr[selected_cusor].pr]; tree_minimum(tmp); on_chose(tmp.idx); selected_cusor = tmp.idx; }catch(err){ }; }else{ var tmp = playlist_dr[selected_cusor]; auto_colapse && tree_collasp(tmp); tree_expant(tmp); on_chose(tmp.idx); selected_cusor = tmp.idx; } if((selected_cusor + 1 ) * heigh_row > (scroll + wh)) scroll = (selected_cusor + 2) * heigh_row - Math.round(wh / heigh_row)* heigh_row; else if((selected_cusor - 1) * heigh_row - scroll < 0) scroll = (selected_cusor - 1) * heigh_row; repaint_main1 = repaint_main2; } break; case 0x10: hold_shift = true; shift_index = form_text_cusor; break; case 0x11: hold_ctrl = true; break; case 13: if(on_form)return; if(choose_playlist.Count == 0) return; //apply_playlist(choose_playlist); add_playlist(choose_playlist);//================================== Add to playlist(Shift + Enter) break; case 40:case 38: if(playlist_dr.length == 0) break; if((selected_cusor == 0 && vkey == 38)||(selected_cusor == playlist_dr.length - 1 && vkey == 40)){ repaint_main1 = repaint_main2; form_text_cusor_hiden = !form_text_cusor_hiden; on_form = true; on_mouse_lbtn_down(ww - 21,10,0); on_chose(-1); break; } (vkey == 40) && selected_cusor++; (vkey == 38) && selected_cusor--; selected_cusor = (selected_cusor + playlist_dr.length)% playlist_dr.length; if((selected_cusor + 2) * heigh_row - (scroll + wh - heigh_row) > 0) scroll = (selected_cusor + 3) * heigh_row - Math.round(wh / heigh_row - 1)* heigh_row; else if((selected_cusor - 1) * heigh_row - scroll < 0) scroll = (selected_cusor - 1) * heigh_row; on_chose(selected_cusor); on_form = false; repaint_main1 = repaint_main2; break; case 46: on_key_down(39); on_char(8); break; } repaint_f1 = repaint_f2; form_text_cusor_hiden = true; } function on_key_up(vkey){ switch(vkey){ case 0x10: hold_shift = false; shift_index = form_text_cusor; break; case 0x11: hold_ctrl = false; break; } } //======================================================Touch mod function on_mouse_move(x,y){ if (lbdn) { y_end = y; y_delta = (y_end - y_start); if (x < ww){ if (y_delta > wh/25) { on_mouse_wheel(1); repaint_f1 = repaint_f2; y_start = y_end; } if (y_delta < -wh/25) { on_mouse_wheel(-1); repaint_f1 = repaint_f2; y_start = y_end; }; } scroll = check_scroll(scroll); } if(m_x == x && m_y == y) return; mouse_in = true; if(y < heigh_row && x < ww - heigh_row) window.SetCursor(32512); else window.SetCursor(32512); if(y < heigh_row && mouse_l_hold_f){ bold_start = form_text_cusor; bold_end = get_cusor_index(x); if(bold_start > bold_end){ var tam = bold_start; bold_start = bold_end; bold_end = tam; } repaint_f1 = repaint_f2; } if(m_x > ww-heigh_row && m_y < heigh_row) //repaint_f1 = repaint_f2; m_x = x;m_y = y; var tam = Math.round((y - heigh_row*1.5)/heigh_row); if(tam < playlist_dr.length && tam >= 0){ repaint_main1 = repaint_main2; } if(hold_scroll){ scroll = Math.round((((y - heigh_row) * (playlist_dr.length * heigh_row ) / (wh - heigh_row)) - (wh - heigh_row)/2)/heigh_row-0.5)*heigh_row; } time_tooltip.Reset(); } function on_mouse_leave(){ m_x = x_y = 0; mouse_drag = mouse_hold = mouse_in = false; } //====================================================================APPLY & ADD TO PL function apply_playlist(playlist){ var pl_idx = check_playlist("Library view"); if(pl_idx == -1){ pl_idx = fb.PlaylistCount; fb.CreatePlaylist(pl_idx,"Library view"); }else{ fb.ActivePlaylist = pl_idx; fb.RunMainMenuCommand("Edit/Clear"); } fb.ActivePlaylist = pl_idx; var playlist_ = playlist.Clone(); //playlist_.OrderByFormat(fb.TitleFormat("$if([%album artist%],%album artist%,zzzz)|$if([%album%],[%date%]%album%,zzzz)|$if(%track number%,%track number%,zzzz)|$sub(5,%rating%)|%title%"),1); playlist_.OrderByFormat(fb.TitleFormat("%path%"),1); plman.InsertPlaylistItems(pl_idx,1,playlist_); fb.ActivePlaylist = pl_idx; plman.ExecutePlaylistDefaultAction(pl_idx,0); fb.RunMainMenuCommand("Edit/Remove Duplicates"); } function add_playlist(playlist){ //playlist.OrderByFormat(fb.TitleFormat("$if([%album artist%],%album artist%,zzzz)|$if([%album%],[%date%]%album%,zzzz)|$if(%track number%,%track number%,zzzz)|$sub(5,%rating%)|%title%"),1); playlist.OrderByFormat(fb.TitleFormat("%path%"),1); plman.InsertPlaylistItems(fb.ActivePlaylist,plman.PlaylistItemCount(fb.ActivePlaylist),playlist); fb.RunMainMenuCommand("Edit/Remove Duplicates"); } function on_mouse_mbtn_down(x,y,mask){ var tam = Math.round((y + scroll - heigh_row*1.5)/heigh_row); if(y > heigh_row && tam < playlist_dr.length && tam >= 0) check_item(playlist_dr[tam],x,y) && add_playlist(playlist_dr[tam].pl); } //======================================================= On Paint function on_paint(gr){ !window.IsTransparent && gr.FillSolidRect(0, 0, ww, wh, 0xff000000); gr.FillSolidRect(0, 0, ww, wh, alfa_fade_color);//-----> Alfa Fade (if dont need comment//) if(!repaint_main && !repaint_f) repaint_main = repaint_f = true; if(repaint_main){ repaint_main = false; var index = 0,j = 0,start_ = 0,end_ = 0,alpha = 0; var count_,head_,name_,width_,left_mg; var width_aaa = gr.CalcTextWidth("(+) ",g_font); start_ = Math.round(scroll_/heigh_row + 0.4); end_ = Math.round((scroll_ + wh)/heigh_row - 0.5); end_ = (playlist_dr.length < end_)?playlist_dr.length:end_; for(var i = start_;i < end_;i++){ alpha = (playlist_dr[i].alpha<<24)|0xffffff; count_ = (playlist_dr[i].pl.Count >1)?(" (" +playlist_dr[i].pl.Count + ")"):(""); head_ = playlist_dr[i].leaf?"• ":((playlist_dr[i].child.length < 1)?"[+] ":"[--] "); name_= head_ + playlist_dr[i].name + count_ + ""; width_ = gr.CalcTextWidth(name_,g_font) - (playlist_dr[i].leaf?0:width_aaa) + heigh_row * 0.2; playlist_dr[i].rg = width_ - (playlist_dr[i].leaf?heigh_row:0); playlist_dr[i].choose ?(playlist_dr[i].alpha += time_dl * 2) :((mouse_index != i) && (playlist_dr[i].alpha -= time_dl * 0.7)); playlist_dr[i].alpha = Math.max(0,Math.min(255,playlist_dr[i].alpha)); (playlist_dr[i].alpha % 255 !=0) && (repaint_main1 = repaint_main2); (playlist_dr[i].alpha > 0) && gr.FillSolidRect((heigh_row * playlist_dr[i].lv) + (playlist_dr[i].leaf?0:width_aaa) + slide_r,Math.floor((i + 1)* heigh_row - scroll_ + 1),width_,Math.floor(heigh_row*0.95),(choose_background_color & alpha)); playlist_dr[i].choose && gr.DrawRect((heigh_row * playlist_dr[i].lv) + (playlist_dr[i].leaf?0:width_aaa) + slide_r,Math.floor((i + 1)* heigh_row - scroll_ + 1),width_, Math.floor(heigh_row*0.95 - 1),1,0x30FFFFFF); left_mg = heigh_row * (playlist_dr[i].lv + 0.1); gr.GdiDrawText(name_, g_font, color_text,left_mg + slide_r,heigh_row * (i + 1.1)- scroll_-5, ww - left_mg, heigh_row, 0); } // Draw Qsearch gr.SetSmoothingMode(4); if(qsearch_t.Time < 500 && qsearch != ""){ var wid = gr.CalcTextWidth(qsearch,g_font_q) + 25; var hei = heigh_row * 1.5; gr.DrawRoundRect(ww/2 - wid/2, wh/2 - hei/2, wid, hei, 5, 5, heigh_row * 0.1, 0xaaffffff); gr.FillRoundRect(ww/2 - wid/2, wh/2 - hei/2, wid, hei, 5, 5, 0x77000000); gr.GdiDrawText(qsearch, g_font_q, 0xff000000,ww/2 - wid/2 + 2, wh/2 - hei/2 + heigh_row * 0.2 + 2, wid, hei, 0x05); gr.GdiDrawText(qsearch, g_font_q, color_text,ww/2 - wid/2, wh/2 - hei/2 + heigh_row * 0.2, wid, hei, 0x05); } //Draw Scoll Bar if(playlist_dr.length * heigh_row > wh - heigh_row){ var hei = playlist_dr.length * heigh_row; //gr.FillGradRect(ww-7,heigh_row,7,wh-heigh_row,0,0x60000000,0x60000000); gr.FillGradRect(ww-6,heigh_row + (scroll_*(wh-heigh_row)/hei),5,((wh-heigh_row)*(wh-heigh_row)/hei)-1,0,hold_scroll ? 0xa0aaaaaa:0xa0ffffff ,hold_scroll ? 0xa0aaaaaa:0xa0ffffff); } //Draw Blend if(img_blend_2) gr.GdiAlphaBlend(img_blend_2,0,wh * 39 / 40,ww,img_blend_2.Height,0,1,ww,img_blend_2.Height - 1,255); } if(repaint_f){ repaint_f = false; //!window.IsTransparent && gr.FillSolidRect(0, 0, ww, heigh_row, 0x80555555); //!window.IsTransparent && gr.DrawRect(0, 0, ww, heigh_row, 1,0x70ffffff); //refresh_char_index(gr); //bold_start = Math.max(bold_start,0); //bold_end = Math.max(bold_end,0); //form_text_cusor = Math.max(form_text_cusor,0); //bold_start = Math.min(bold_start,form_text.length); //bold_end = Math.min(bold_end,form_text.length); //form_text_cusor = Math.min(form_text_cusor,form_text.length); //gr.DrawLine(0,heigh_row/2,ww,heigh_row/2,heigh_row,on_form?0x60222222:0x60000000); //on_form && form_text_cusor_hiden && (bold_start == bold_end) && gr.DrawLine(char_index[form_text_cusor] + heigh_row/10,heigh_row/10,char_index[form_text_cusor] + heigh_row/10,heigh_row*0.9,1,color_text); //bold_end = (bold_end < form_text.length)?bold_end:form_text.length; //(bold_start != bold_end) && gr.DrawLine(char_index[bold_start] + heigh_row/10,heigh_row/2,char_index[bold_end] + heigh_row/10,heigh_row/2,heigh_row-3,choose_background_color); //gr.GdiDrawText(form_text, g_font, color_text, heigh_row/10, heigh_row/10-5, ww, heigh_row, 0); //(form_text == "") && gr.GdiDrawText("Search . . .", g_font3, RGB(105,105,105), heigh_row/10, heigh_row/10-5, ww, heigh_row, 0); //gr.DrawLine(ww-heigh_row*0.8,heigh_row*0.8,ww - heigh_row*0.2,heigh_row*0.2,heigh_row/10,(m_x > ww-heigh_row && m_y < heigh_row)?0xf0ffffff:RGB(105,105,105)); //gr.DrawLine(ww-heigh_row*0.8,heigh_row*0.2,ww - heigh_row*0.2,heigh_row*0.8,heigh_row/10,(m_x > ww-heigh_row && m_y < heigh_row)?0xf0ffffff:RGB(105,105,105)); } } //===============================================================ON TIMER function on_timer(g_time333){ if(!window.IsVisible) return; on_timer_(g_time333); } function on_timer_(g_time333){ var repaint_1 = false,repaint_2 = false; time_dl = time_s.Time; time_s.Reset(); if(research){ research = false; get_pl_tree(research_k,form_text); return; } var d = new Date(); if(d.getTime() - time222 < 15) return else time222 = d.getTime(); if(d.getTime() - time333 > time_delay_search && on_form && form_text_b != form_text){ time333 = d.getTime(); form_text_b = form_text; lib_search = form_text; get_pl_tree(); } mouse_index = -1; var tam = check_item_index(m_x,m_y); if(tam != -1){ if(qsearch == "") playlist_dr[tam].alpha = Math.min(playlist_dr[tam].alpha + 40,255); if(m_tam != tam){ mouse_hold && on_chose(tam); deactive_tooltip(); }else{ Tooltip && (time_tooltip_ += time_dl); } if(Tooltip && time_tooltip_ > 3000 && !tooltip_state && (heigh_row * (playlist_dr[tam].lv + 1) + playlist_dr[tam].rg) > ww && playlist_dr[tam].alpha > 250){ g_tooltip.Width = playlist_dr[tam].rg; g_tooltip.Height = heigh_row; active_tooltip(); g_tooltip.TrackPosition(heigh_row * (playlist_dr[tam].lv + 1), Math.floor((m_y+1) / heigh_row) * heigh_row - 1); g_tooltip.Text = " "; }else deactive_tooltip(); mouse_index = tam; m_tam = tam; } if(qsearch_t.Time > 1500 && qsearch != ""){ repaint_2 = true; qsearch = ""; } if(time_tooltip.Time > 7000){ deactive_tooltip(); } if(d.getTime() - time111 > 600 && on_form){ form_text_cusor_hiden = !form_text_cusor_hiden; time111 = d.getTime(); repaint_1 = true; } if(repaint_f1 == repaint_f2){ repaint_f2 = !repaint_f1; repaint_1 = true; } if(repaint_main1 == repaint_main2){ repaint_main2 = !repaint_main1; repaint_2 = true; } scroll = check_scroll(scroll); if(Math.abs(scroll - scroll_) > 0.5){ scroll___ += (scroll - scroll___) * (1-Math.pow(0.9,time_dl/4)); scroll__ += (scroll___ - scroll__) * (1-Math.pow(0.9,time_dl/4)); scroll_ += (scroll__ - scroll_) * (1-Math.pow(0.9,time_dl/4)); time_tooltip.Reset(); repaint_2 = true; } if(repaint_1 && repaint_2){ time_s.Reset(); repaint_main = true; repaint_f = true; window.Repaint(); }else if(repaint_1){ repaint_f = true; window.RepaintRect(0,0,ww,heigh_row,true); }else if(repaint_2){ repaint_main = true; time_s.Reset(); window.RepaintRect(0,heigh_row,ww,wh-heigh_row,true); } } function check_item_index(x,y){ var tam = Math.round((y + scroll_ - heigh_row*1.5)/heigh_row); if(playlist_dr.length > tam && tam >= 0 && x < ww -10 && y > heigh_row && check_item(playlist_dr[tam],x,y)) return tam; else return -1; } var notifi = true; function setfont(){ if(!utils.CheckFont(Font_name)){ notifi && fb.ShowPopupMessage("Stub image not found.\r\nGo to Properties to config Stub image path."); notifi = false; } g_font = gdi.Font(Font_name, font_size, 0); g_font2 = gdi.Font(Font_name, font_size, 1); g_font3 = gdi.Font(Font_name, font_size, 2); g_font_q = gdi.Font(Font_name, font_size*1.5, 2);// g_font_q = gdi.Font("Tahoma", font_size + 10, 2), g_font_marker = gdi.Font(Font_name, font_size, 1); } //===================================================Wheel step function on_mouse_wheel(step){ if(utils.IsKeyPressed(0x11)){ font_size += step; if(font_size > 60) font_size = 60; else if(font_size < 20) font_size = 20; window.SetProperty("font_size",font_size); setfont(); scroll = scroll_ = scroll__ = scroll___ = scroll/heigh_row; heigh_row = Math.floor(font_size*16/11); scroll = scroll_ = scroll__ = scroll___ = scroll * heigh_row; window.SetProperty("heigh_row",heigh_row); repaint_f1 = repaint_f2;repaint_main1 = repaint_main2; return; } repaint_main1 = repaint_main2; scroll -= step*heigh_row*1; scroll = check_scroll(scroll); } function check_scroll(scroll___){ scroll___ = Math.round(scroll___ / heigh_row ) * heigh_row; if(scroll___ > ((playlist_dr.length + 2 )* heigh_row - wh )) scroll___ = Math.round(((playlist_dr.length + 2 )* heigh_row - wh )/heigh_row - 0.5)*heigh_row; if(playlist_dr.length*heigh_row < wh - heigh_row) scroll___ = 0; if(scroll___ < 0) scroll___ = 0; return scroll___; } function on_mouse_rbtn_up(x, y){ var MF_SEPARATOR = 0x00000800; var MF_STRING = 0x00000000; var _menu = window.CreatePopupMenu(); var _menu1 = window.CreatePopupMenu(); var Context = fb.CreateContextMenuManager(); var con_ = false,time_111,idx; _menu1.AppendMenuItem(MF_STRING, 2, "Grouph by Path"); _menu1.AppendMenuItem(MF_STRING, 3, "Grouph by Artist - Album"); _menu1.AppendMenuItem(MF_STRING, 4, "Grouph by Album"); _menu1.AppendMenuItem(MF_STRING, 5, "Grouph by User"); _menu1.AppendMenuSeparator(); _menu1.AppendMenuItem(MF_STRING, 11, "Auto Exppant"); _menu1.AppendMenuItem(MF_STRING, 12, "Auto Collapse"); _menu1.AppendMenuItem(MF_STRING, 15, "Tooltip"); _menu1.AppendMenuSeparator(); _menu1.AppendMenuItem(MF_STRING, 9, "Reefresh Library"); _menu1.AppendMenuItem(MF_STRING, 13, "Configure Library Path"); show_scripts && _menu1.AppendMenuItem(MF_STRING, 1, "Show Configure Scripts"); _menu1.AppendMenuItem(MF_STRING, 100, "Show Properties"); _menu1.CheckMenuRadioItem(2, 5,grouph_by + 2); _menu1.CheckMenuItem(11,auto_exppant); _menu1.CheckMenuItem(12,auto_colapse); _menu1.CheckMenuItem(15,Tooltip); var tam = Math.round((y + scroll_ - heigh_row*1.5)/heigh_row); if(y > heigh_row && playlist_dr.length > tam && tam >= 0 && x < ww - heigh_row/2 && check_item(playlist_dr[tam],x,y)){ !playlist_dr[tam].choose && on_chose(tam); _menu.AppendMenuItem(MF_STRING, 21, "Send to Playing Playlist"); _menu.AppendMenuItem(MF_STRING, 22, "Add to Playing Playlist"); con_ = true; } else on_chose(-1); _menu1.AppendTo(_menu,MF_STRING, "Preferences"); if(con_){ _menu.AppendMenuSeparator(); Context.InitContext(choose_playlist); Context.BuildMenu(_menu, 30, -1); } idx = _menu.TrackPopupMenu(x,y); switch(idx) { case 1: window.ShowConfigure(); break; case 2:case 3:case 4:case 5: grouph_by = idx-2; window.SetProperty("Grouph by",grouph_by); get_library(2); get_pl_tree(); repaint_f1 = repaint_f2; repaint_main1 = repaint_main2; break; case 9: get_library(1); get_pl_tree(); repaint_f1 = repaint_f2; repaint_main1 = repaint_main2; break; case 11: auto_exppant = !auto_exppant; window.SetProperty("auto exppant",auto_exppant); get_pl_tree(); repaint_f1 = repaint_f2; repaint_main1 = repaint_main2; break; case 12: auto_colapse = !auto_colapse; window.SetProperty("auto colapse",auto_colapse); get_pl_tree(); repaint_f1 = repaint_f2; repaint_main1 = repaint_main2; break; case 13: var lib_filter = vbe.eval("InputBox(\"Example : \" + chr(10) + \"D:\\music\\;D:\\lossless\\\" + chr(10) + \"NULL to reset default\",\"Edit library Path\",\"" + library_path + "\")"); if(lib_filter == "NULL" || lib_filter == "null") library_path = "E:\\music\\lossless\\;E:\\music\\lossly\\320kps\\"; else if(lib_filter) library_path = lib_filter; library_path_ = library_path.split(";"); window.SetProperty("Library path",library_path); get_library(1); get_pl_tree(); repaint_f1 = repaint_f2; repaint_main1 = repaint_main2; break; case 15: Tooltip = !Tooltip; window.SetProperty("Tooltip",Tooltip); break; case 21: apply_playlist(choose_playlist); break; case 22: add_playlist(choose_playlist); break; case 100: window.ShowProperties(); break; default: con_ && Context.ExecuteByID(idx-30); break; } _menu.Dispose(); _menu1.Dispose(); Context.Dispose(); return true; } function active_tooltip(){ if(!tooltip_state){ tooltip_state = true; g_tooltip.Activate(); g_tooltip.TrackActivate = true; } } function deactive_tooltip(){ if(tooltip_state){ tooltip_state = false; g_tooltip.TrackActivate = false; g_tooltip.Deactivate(); time_tooltip_ = 0; time_tooltip.Reset(); } } function on_tooltip_custom_paint(gr){ var tam = check_item_index(m_x,m_y); var dr_str = playlist_dr[tam].name + (playlist_dr[tam].leaf?(""):(" (" + playlist_dr[tam].pl.Count + ")")); gr.GdiDrawText(dr_str, g_font, 0xaa333333,font_size * 0.2,heigh_row * 0.1,playlist_dr[tam].rg, heigh_row, 0x804); } function create_blend(){ ww = window.Width; wh = window.Height; try{ background = window.GetBackgroundImage(); x = Math.ceil(wh/40 * 39) - 1; w = background.Height - x; img1 = background.Clone(0,x ,ww,w); var tmp = gdi.CreateImage(ww,w); var gr = tmp.GetGraphics(); gr.FillGradRect(0,0,ww,wh/40,270,0xff000000,0xffffffff,1); gr.FillGradRect(0,wh/80,ww,wh/80,270,0xaa000000,0x00ffffff,1); tmp.ReleaseGraphics(gr); img1.ApplyMask(tmp); img_blend_2 = img1.CreateRawBitmap(); }catch(err){} } var a000001 = window.SetTimeout(function(){ get_library(); if(form_text == ""){ get_pl_tree(); repaint_f1 = repaint_f2; repaint_main1 = repaint_main2; } window.ClearTimeout(a000001); },500); function on_library_items_added(){ get_library(1); get_pl_tree(); repaint_f1 = repaint_f2; repaint_main1 = repaint_main2; } function on_library_items_removed(){ get_library(1); get_pl_tree(); repaint_f1 = repaint_f2; repaint_main1 = repaint_main2; } |
#1894 |
![]() Регистрация: 01.06.2013
Машина: SUBARU Impreza WRX
![]() seriousstas
Там в скрипте заморочка с индексами при отправке в плейлист... отсюда и трабл... как это править не понятно... Скрипт WilB-а посмотри плиз, как он отправляет правильно или тоже с косяками...
Готовые сборки foobar2000 для КарПС //--- FLAT ---\\ Сборки PotPlayer Полезные утилиты |
#1895 | ||
главный файл для CUE _________________________________ PS выяснил, что ошибка из-за параллельно установленного WSH 1.5.10 c WSH 1.6 - JS дружит , но foo_cuefilter не работает .. |
#1896 | |
![]() kaamoss
можешь глянуть видосы - по настройкам и т.д.(настройки показаны не все, но их большая часть) - добавление новой панели в сборку скрипты и некоторые ответы на твои вопросы ты сможешь найти в "Готовых сборках"... ссылка в подписи.
#1897 | |
![]() seriousstas
![]() необходимо для старта... Код:
REQUIREMENT JScript Panel 1.1.0+
#1898 | |
![]() http://pccar.ru/showpost.php?p=363301&postcount=1895 поставь рядом WSH 1.5.10 и вылезет .. с 1.6.0 - норм |
#1899 | |
![]() seriousstas
ага понял конфликтует с 1.5.10... ![]() Цитата:
------------------ Т.е. в этом варианте не используется прослойка в виде плейлиста как у вьетнамского товарища... схема такая библиотека ---> плейлист ---> скрипт (вьетнамский скипт) библиотека ---> скрипт (скрипт WilB)
#1900 | |
http://pccar.ru/showpost.php?p=363298&postcount=1893 С ней ведь никаких проблем вообще .. Ну зачем нам знаки вопроса и лишние файлы в "дереве" ? |
Здесь присутствуют: 91 (пользователей: 0 , гостей: 91) | |
