#1391 |
![]() Регистрация: 01.06.2013
Машина: SUBARU Impreza WRX
#1392 | |
![]() Регистрация: 12.11.2013
Машина: lexus rx300
#1393 |
![]() Регистрация: 03.05.2011
Машина: Toyota-Echo
![]() Верхнюю полосу в скрипте убрал удалив строчки
Код:
if(repaint_f){ repaint_f = false; !window.IsTransparent && gr.FillSolidRect(0, 0, ww, heigh_row, 0x80555555); // !window.IsTransparent && gr.DrawRect(0, 0, ww, heigh_row, 1,0x70ffffff); refresh_char_index(gr); bold_start = Math.max(bold_start,0); bold_end = Math.max(bold_end,0); form_text_cusor = Math.max(form_text_cusor,0); bold_start = Math.min(bold_start,form_text.length); bold_end = Math.min(bold_end,form_text.length); form_text_cusor = Math.min(form_text_cusor,form_text.length); gr.DrawLine(0,heigh_row/2,ww,heigh_row/2,heigh_row,on_form?0x60222222:0x60000000); on_form && form_text_cusor_hiden && (bold_start == bold_end) && gr.DrawLine(char_index[form_text_cusor] + heigh_row/10,heigh_row/10,char_index[form_text_cusor] + heigh_row/10,heigh_row*0.9,1,color_text); bold_end = (bold_end < form_text.length)?bold_end:form_text.length; (bold_start != bold_end) && gr.DrawLine(char_index[bold_start] + heigh_row/10,heigh_row/2,char_index[bold_end] + heigh_row/10,heigh_row/2,heigh_row-3,choose_background_color); gr.GdiDrawText(form_text, g_font, color_text, heigh_row/10, heigh_row/10-5, ww, heigh_row, 0); (form_text == "") && gr.GdiDrawText("Поиск ", g_font3, RGB(105,105,105), heigh_row/10, heigh_row/10-5, ww, heigh_row, 0); gr.DrawLine(ww-heigh_row*0.8,heigh_row*0.8,ww - heigh_row*0.2,heigh_row*0.2,heigh_row/10,(m_x > ww-heigh_row && m_y < heigh_row)?0xf0ffffff:RGB(105,105,105)); gr.DrawLine(ww-heigh_row*0.8,heigh_row*0.2,ww - heigh_row*0.2,heigh_row*0.8,heigh_row/10,(m_x > ww-heigh_row && m_y < heigh_row)?0xf0ffffff:RGB(105,105,105)); }
#1394 |
![]() vladj
Да это я знаю:-) Убрать графику не проблема, проблема как раз поднять список...вот это реальный геморой. У этого автора блин, полет мысли весьма интересный, seriousstas не даст соврать, у меня на то чтоб понять как он сортировку треков делает ушла примерно неделя... у него в скрипте нет ни описания ни сносок... Здесь походу как то завязано на список эта строка поиска, пока не получается вычислить те параметры которые отвечают за отрисовку верхней строки, чтоб ее исключить и поднять список на верх... Я уже часа 3-4 плотно сижу и пока ничего. ![]() Автора попросил помочь но думаю что помощи не будет.... http://thanhdat1710.deviantart.com/a...V1-0-376360761 Последний раз редактировалось duzzy; 09.05.2015 в 00:46. |
#1395 | |
Машина: lexus rx300
#1396 | |||
![]() Регистрация: 14.06.2013
![]() wladkom1953
Код:
$imagebutton(5,$sub(%hh%,85),80,80,%b0%,%b1%,PANELSHOW:WSH_DSP:0;PANELSHOW:vumeter:0;PANELSHOW:PS:0;PANELSHOW:art:0;PANELSHOW:select:0;PANELSHOW:search:1;REFRESH,) Два скрипта на AHK помагают управлять библиотекой . Работает так - верхняя кнопка зажимает CTRL на несколько секунд , это позволяет увеличить шрифт и выборочно выбирать несколько папок(или треков) зараз . Нижняя - отправляет выбранное в плейлист и одновременно отключает CTRL - довольно удобно : Последний раз редактировалось seriousstas; 16.05.2015 в 14:35. |
#1397 |
![]() Упаковал :
http://rghost.ru/8xGlq9yFt Напомню, что для корректной работы всех кнопок , должен быть активным хотя-бы один трек в плейлисте . Так работает foo_run |
#1398 |
![]() Регистрация: 27.09.2008
![]() Что то со звуком.....а именно тихий стал и из фубара не прибавляется.
#1399 | |
Машина: lexus rx300
#1400 |
![]() sirota - фубар не причем (я ничего не менял) - это скорей всего проделки микшера или настройки Asus-а покрутить (сбросить) надо ...
