Старый 07.05.2015, 12:37   #1
~aviator~
Машина: Honda Accord 2.0 DOHC
По умолчанию Материнка ITX-N29 nano-itx 12*12 см
Может кто уже юзал?
Старый 07.05.2015, 12:58   #2
~aviator~
Processor
Integrated Intel® J1900 Quad Core 22nm CPU 2.0GHz , Compatible with Intel® Bay Trail -I/M/D full series CPU. Chipset
Intel® Bay trail SOC Chip
Memory 1* SO DDRIII 1333/1066 MHZ,up to 8GB
DisplayIntegrated Intel® HD Graphics,with VGA /LVDS/ HDMI display output,LVDS support
dual channel 24bit,Support separate display, double display copy, dual display
expansion.Dial switch control LVDS resolution adjustment,(LVDS screen voltage
support 12V output, the default is 3.3V,before using LVDS , please know the
requirements of the rated working voltage first, then setting, to avoid burning the
ITX-N29 based on Intel® Bay Trial Architecture NANO-ITX
Network Function Integrated 1*RTL8111E Ethernet,support wake-on -LAN /PXE .( 2*RTL8111E Ethernet Optional )
Audio Integrated Realtek HD ALC662 for 6-Channel output,support
MIC & Line-out ,Speaker (recommend to use 3Ω2W speaker)
Expansion Slot:
1*Mini-PCIE, support WIFI、3G module,1*MSATA,support WIFI、
SSD(default) ,Support Intel agreement SSD.
Storage
1*SATA (support SATA ,SSD)
Front Panel I/O
1* MIC
1* SIM
1* COM CISCO standard
2* USB (1*USB2.0 ,1*USB3.0)
1* HDD LED(Green)
1* POWER switch
Rear I/O
1* Line-out
2* USB 2.0(Alternative to LAN2)
1* LAN
1* VGA
1* HDMI
1* 12V DC power input
Internal I/O
1* LVDS,support 24bit LCD(dual8) 2*15pin
1* JVGA1,same signal with DB15, 12pin
1* RS232 , 2*5pin 2.0
2* USB 2.0
1* PS/2 KB/Mouse 6Pin
1* FP1 Front panel buttons and LED indicator 2*5pin
1* AUDIO front panel audio port
1* amplifier interface 4pin
1* PWROUT HDD 4pin
1* ATX_12V 4PIN
1* LVDS INVERTER
GPIO
4-Way Input/Output GPIO
Cooler
1* CPUFAN 4pin
BIOS
32MB SMT Flash ROM
Watchdog
Support hardware reset function (L256, 0~255 seconds)
Power
DC_12V Single Power Input
Size , Environment
Motherboard Size : 120mm x 120mm
Operating Temp.:-10℃~60℃
Humidity:5%-95% ( relative humidity; non-condensing)
Storage Temp.: -20℃~70℃
Старый 07.05.2015, 13:35   #3
~aviator~
User manual
Старый 07.05.2015, 16:58   #4
vladget1
Машина: Хонда
vladget1 is on a distinguished road
а вот здесь http://www.pccar.ru/showthread.php?t...0%F2%E0&page=3 наверно то же самое но по мощнее
vladget1 вне форума   Ответить с цитированием
Старый 07.05.2015, 17:48   #5
~aviator~
оно то мощней но 120 баксов и 240 как то разница есть. так ка я еще на intel 510 cb;e, думаю при переходе и эта будет как самолет
Старый 07.05.2015, 19:24   #6
awtoap
Аватар для awtoap
Я бы на вашем месте забил уже на эти материнки...берите у китайцев боксы на интел атом типа Z3736F.
Старый 07.05.2015, 21:29   #7
~aviator~
И что в них хорошего?
Старый 07.05.2015, 22:55   #8
Vladget
там по ссылке были разные матери и на i-* и "пентимумы" и ниже вроде тоже были
Старый 07.05.2015, 23:12   #9
awtoap
Аватар для awtoap
Размеры и потребление. Да и питание через обычный DC-DC понижайку. Производительности хватает более чем. И главное - пассивное охлаждение. Правда у китов оно хромает...нужно самому влепить радиатор пожирнее.
Старый 07.05.2015, 23:25   #10
~aviator~
Ну по производительности хз, если писать видео в норм. Качестве то ляжет наверное
Часовой пояс GMT +4, время: 00:07.
