Старый 22.12.2013, 15:56   #181
tegelberg
tegelberg is on a distinguished road
[IMG][/IMG]
tegelberg вне форума   Ответить с цитированием
Старый 22.12.2013, 16:35   #182
zyxel812
Машина: e46
zyxel812 is a name known to allzyxel812 is a name known to allzyxel812 is a name known to allzyxel812 is a name known to allzyxel812 is a name known to allzyxel812 is a name known to all
Я конечно не знаток Ардуины, но по-моему при прошивке в командной строке нужно заменить праматр -c avr109 на -с avr910
zyxel812 вне форума   Ответить с цитированием
Старый 23.12.2013, 01:14   #183
tegelberg
Вот что получаится
% avrdude -v -p atmega32u4 -c avr910 -P COM3 -b 9600 -D -Uflash:w:TouchControlle
r.hex:i
avrdude.EXE: Version 5.10, compiled on Jan 19 2010 at 10:45:23
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\WinAVR-20100110\bin\avrdude.c
onf"
Using Port : COM3
Using Programmer : avr910
avr910_devcode (avrdude.conf) : none
Overriding Baud Rate : 9600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page
Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW
MaxW ReadBack
eeprom 65 10 8 0 no 1024 8 0 9000
9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500
4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000
9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000
9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000
9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000
9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0
0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0
0 0x00 0x00
Programmer Type : avr910
Description : Atmel Low Cost Serial Programmer
Found programmer: Id = ""; type = └
Software Version = D. ; Hardware Version = *.´
Programmer supports the following devices:
Device code: 0xffffff99 = (unknown)
Старый 23.12.2013, 13:20   #184
yojig
Регион: 29
Машина: Mazda3
yojig is on a distinguished road
как помнится надо начинать прошивать сразу, когда в системе бутлоадер определяется (у него другой ком-порт будет). драйвер на него надо тоже ставить. в мануале об этом написано, 5-10 сек после подключения.
yojig вне форума   Ответить с цитированием
Старый 23.12.2013, 15:31   #185
tegelberg
Вот что я уже выше писал у меня ничего непроисходит в течении 5-10 сек. если я его подсоидиняю он сразу получаит порт 3 и больше не меняитса
Старый 23.12.2013, 18:36   #186
ilia221165
Машина: ВАЗ 21043
ilia221165 is on a distinguished road
Сообщение от tegelberg Посмотреть сообщение
Возможно в этих платах нет загрузчика.
Я загружал .hex через MOSI MISO SCK (com-lpt)
ilia221165 вне форума   Ответить с цитированием
Старый 23.12.2013, 22:06   #187
yojig
Регион: 29
Машина: Mazda3
у меня такая же плата как на фотке с ебея. минут за 5 всё сделал
может на другом компе попробовать? или кабель усб сменить. мало ли)
Старый 23.12.2013, 23:13   #188
tegelberg
Да я первую точно такую же на этом компе с этим юсби прошил все получилось а это почему то вот так.
Старый 24.12.2013, 00:26   #189
zyxel812
Машина: e46
Если с загрузчиком не получается, тогда придется программировать через программатор. Вот доступное описание программатора на lpt порту: http://www.getchip.net/posts/delaem-...okontrollerov/
Вот, к стати, еще статья по программированию ардуиновских контроллеров: http://www.getchip.net/posts/104-pro...ka-bootloader/ посмотрите её, там вроде какая-то альтернативная программа для загрузки прошивки предлагается.
Старый 24.12.2013, 04:13   #190
tegelberg
А там ведь нет етого чипа
Atmega32u4
Здесь присутствуют: 32 (пользователей: 0 , гостей: 32)
Часовой пояс GMT +4, время: 05:16.
