Старый 18.10.2009, 16:25   #651
el66
Машина: 2005 Toyota Allion
el66 is on a distinguished road
А на другом компе работает!
Тип файла: zip log_2009-10-18_12-45-57.zip (1,016 байт, 649 просмотров)
el66 вне форума   Ответить с цитированием
Старый 19.10.2009, 20:43   #652
VVS_24
Машина: 2001 Toyota Ipsum S
VVS_24 is on a distinguished road
Вот нашел описание PIDов начиная с 0xB0 для тойoты
https://www.scantool.net/forum/index.php?topic=2847.0
VVS_24 вне форума   Ответить с цитированием
Старый 19.10.2009, 22:52   #653
KilleRMill
Регион: 74
Машина: Toyota Fielder NZ121G '04
KilleRMill is on a distinguished road
Сообщение от VVS_24 Посмотреть сообщение
Чтобы не потерялась инфа, продублирую тут:
EnhancedPowertrain Sensors Total 145 PIDS
J1979 MODE 01
Tested with ISO9141 on 2004 Toyota
68 6A F1 30 00 CS = Bitmapped for Active Input/Output
68 6A F1 01 A0 CS = Bitmapped for Sensor Pids (A1-BF)
68 6A F1 01 C0 CS = Bitmapped for Sensor Pids (C1-DF)
68 6A F1 01 E0 CS = Bitmapped for Sensor Pids (E1-FF)
EXAMPLE:
Request: 68 6A F1 01 A0 CS (Pids Support Bitmapped)
Receive: 48 6B 10 41 A0 B3 B4 B5 B6 CS
Refer to SAE J1979 For Byte Identification #
Example:
Request: 68 6A F1 01 B1 CS
Receive: Byte #3(No Headers) gives you the % state
Note: b1 = 00000001 = active
b4 = 00001000 = active
B1 - % = (BYTE3) - State
B2 - VOLTS = (BYTE3 * (5/255)) - Accelerator Position 1
B2 - VOLTS = (BYTE4 * (5/255)) -Accelerator Position 2
B2 - VOLTS = (BYTE5 * (6/255)) - Throttle Request Position
B2 - VOLTS = (BYTE5 * (6/255)) - Throttle Target
B2 - VOLTS = (BYTE5 * (5/255)) -Throttle Position 2
B2 - VOLTS = (BYTE7 * (5/255)) - Throttle Motor Opening Duty Ratio
B2 - % = (BYTE7) - Throttle Open Duty
B2 - % = (BYTE8) - Throttle Close Duty
B2 - VOLTS = (BYTE8 * (5/255)) - Throttle Motor Closing Duty Ratio
B3 - BIT is 1 = BYTE 3(b2) - Electro Magnetic Clutch
B3 - BIT is 1 = BYTE 3(b3) - ETCS Actuator Power
B3 - BIT IS 1 = BYTE3(b4) - Accelerator Idle Position
B3 - BIT IS 1 = BYTE 3(b5) - Throttle Idle Position
B3 - BIT IS 1 = BYTE 3(b5) - Throttle MOT
B3 - BIT is 1 = BYTE 3(b6) -Fail Safe Drive
B3 - BIT is 1 = BYTE 3(b7) - Fail Safe Drive (Main CPU)
B3 - VOLTS = (BYTE5 * (5/255)) - Throttle Fully Closed Learn Value (Initial)
B3 - DEG = (BYTE6 * (12.49/255)) - Accelerator Fully Learn Value
B3 - AMP = (BYTE7 * (19.9/255)) - Throttle MOT
B3 - AMP = (BYTE8 * (2.50/255)) - Electro Magnetic Clutch Current
B4 - C = (BYTE3 - 40) - Automatic Transmission Fluid Temp
B7 - VOLTS = (BYTE3 * 0.00498) -- Lean Sensor Bank 1 Sensor 1
B7 - % = (BYTE4 * 0.3886) - Bank 1 Sensor 1
B7 - BIT IS 1 = BYTE 5(b8) - Lean Control Bank 1 Sensor 1
B8 - VOLTS = (BYTE3 * 0.00498) - Lean Sensor Bank 1 Sensor 2
B8 - % = (BYTE4 * 0.3886) - Lean S FT Bank 1 Sensor 2
B8 - BIT IS 1 = BYTE 5(b8) - Lean Control Bank 1 Sensor 2
BB - BIT IS 1 = BYTE 4(b1) - Lock Up Soleniod
D0 - BIT IS 1 = BYTE 3(b1) - Status Of EVAP Auto Test
D0 - BIT IS 1 = BYTE 3(b2) - Status Of EVAP Auto Test 1
D0 - BIT IS 1 = BYTE 3(b3) - Status Of EVAP Auto Test 2
D5 - PSI = (BYTE3 * 0.817) - Fuel Tank Vapor Pressure
DA - DEG = (BYTE3 * 2.5) - Target of CAM Phaser
DA - DEG = (BYTE5 * 2.5) - CAM Phaser
DA - DEG = (BYTE7 * 2.5) - OVC Duty Ratio
E1 - # = (BYTE 3) - Number of Codes
E2 - RPM = (BYTE 3 * 6375/255)) - Engine Speed At Misfire
E2 - g-RPM = (BYTE 4 * (3.98/255)) - Load At Misfire
E3 - MPa = (BYTE 3 * (816/255)) - Fuel Pressure
E4 - mS = (BYTE 3 * (32.60/255)) - Injector Pulse Width
E5 - STEP = (BYTE 3) - Idle Air Control Step Position
E6 - % = (BYTE 3 * (99.4/255)) - Idle Air Control Duty Cycle
E7 - STEP = (BYTE 3) - EGR Step Position
E8 - BIT IS 1 = BYTE 3(b2) - Power Steering Oil Pressure Switch
E8 - BIT IS 1 = BYTE 3(b3) - Stop Light (Brake Switch 1)
E8 - BIT IS 1 = BYTE 3(b4) - Electric Load Switch
E8 - BIT IS 1 = BYTE 3(b5) - Park/Neutral Switch
E8 - BIT IS 1 = BYTE 3(b6) - A/C Signal Switch
E8 - BIT IS 1 = BYTE 3(b7) - Throttle Position Close Switch
E8 - BIT IS 1 = BYTE 3(b8) - Ignition Starter Switch
E8 - BIT IS 1 = BYTE 4(b2) - Fuel Cut From CTP
E8 - BIT IS 1 = BYTE 4(b1) - Fuel Cut From TAU Min
E8 - BIT IS 1 = BYTE 5(b1) - Power Steering Signal Shift
E8 - BIT IS 1 = BYTE 5(b6) - Stop Light (Brake Switch 2)
E8 - BIT IS 1 = BYTE 5(b7) - Engine Stop Signal
E9 - COUNT = (BYTE 3) - Misfire Cylinders #1
E9 - COUNT = (BYTE 4) - Misfire Cylinders #2
E9 - COUNT = (BYTE 5) - Misfire Cylinders #3
E9 - COUNT = (BYTE 6) - Misfire Cylinders #4
EA - COUNT = (BYTE 3) - Misfire Cylinders #5
EA - COUNT = (BYTE 4) - Misfire Cylinders #6
EA - COUNT = (BYTE 5) - Misfire Cylinders #7
EA - COUNT = (BYTE 6) - Misfire Cylinders #8
EB - COUNT = (BYTE 3 * 256) - Number of Ignition
EC - BIT IS 1 = BYTE 3(b1) - B1S2 Test Status
EC - BIT IS 1 = BYTE 3(b2) - B2S2 Test Status
EC - BIT IS 1 = BYTE 3(b3) - Misfire Test Status
EC - BIT IS 1 = BYTE 3(b4) - AS Test Status
EC - BIT IS 1 = BYTE 3(b5) - NSW Test Status
EC - BIT IS 1 = BYTE 3(b6) - SPD Test Status
EC - BIT IS 1 = BYTE 3(b7) - 40 Cycles
EC - BIT IS 1 = BYTE 3(b8) - Check Mode
ED - DEG = (BYTE 3 * (159/255)) - EGR Temperature
EE - COUNT = (BYTE 3) - E-ABV Step Position EGR Value Position
EF - BIT IS 1 = BYTE 3(b1) - VSV A/C Cut
EF - BIT IS 1 = BYTE 3(b2) - VSV Variable Intake
EF - BIT IS 1 = BYTE 3(b3) - VSV Fuel Pressure UP
EF - BIT IS 1 = BYTE 3(b4) - VSV EGR System
EF - BIT IS 1 = BYTE 3(b5) - VSV Intake Control
EF - BIT IS 1 = BYTE 3(b6) - VSV Fuel Pump Relay
EF - BIT IS 1 = BYTE 3(b7) - VSV Secondary Air
EF - BIT IS 1 = BYTE 3(b8) - VSV SCV
EF - BIT IS 1 = BYTE 4(b1) - VSV A/C Idle Up
EF - BIT IS 1 = BYTE 4(b2) - VSV Fuel Pump / Spd
EF - BIT IS 1 = BYTE 4(b3) - VSV Boost Pressure Control
EF - BIT IS 1 = BYTE 4(b3) - VSV Purge Cut
EF - BIT IS 1 = BYTE 4(b4) - VSV A/C Clutch Relay
EF - BIT IS 1 = BYTE 4(b5) - VSV EVAP Purge
EF - BIT IS 1 = BYTE 4(b6) - VSV Vapor Presure
EF - BIT IS 1 = BYTE 4(b7) - VSV VVT2 Control Bank 2
EF - BIT IS 1 = BYTE 4(b8) - VSV VVT2 Intake Control
EF - BIT IS 1 = BYTE 5(b1) - VSV Super Charger Control Relay
EF - BIT IS 1 = BYTE 5(b2) - VSV VVT Control Bank 1
EF - BIT IS 1 = BYTE 5(b4) - VSV Automatic Oil Supply
EF - BIT IS 1 = BYTE 5(b5) - VSV Air Bleed
EF - BIT IS 1 = BYTE 5(b6) - VSV Intake Air Control
EF - BIT IS 1 = BYTE 5(b7) - VSV Exhaust Gas Control
EF - BIT IS 1 = BYTE 5(b8) - VSV Exaust ByPass VC
EF - BIT IS 1 = BYTE 6(b1) - VSV Canister Pressure Control
EF - BIT IS 1 = BYTE 6(b2) - VSV Tank Pressure ByPass
EF - BIT IS 1 = BYTE 6(b3) - VSV VVTL Control Bank 1
EF - BIT IS 1 = BYTE 6(b4) - VSV VVTL Control Bank 2
EF - BIT IS 1 = BYTE 6(b5) - VSV AICV
EF - BIT IS 1 = BYTE 6(b6) - VSV Engine Cooling
EF - BIT IS 1 = BYTE 6(b7) - VSV Vent Value
EF - BIT IS 1 = BYTE 6(b8) - VSV Pump for EVAP System
F0 - % = IF BYTE 3 >127 THEN (BYTE 3 * (1.02/255)) - Total Fuel Trim Bank 1
F0 - % = IF BYTE 4 >127 THEN (BYTE 4 * (1.02/255)) - Total Fuel Trim Bank 2
F1 - mS = (BYTE 3 * (16702/255)) - O2 Rich-Lean Bank 1 Sensor 1
F1 - mS = (BYTE 4 * (16702/255)) - O2 Rich-Lean Bank 2 Sensor 1
F2 - mS = (BYTE 3 * (16702/255)) - O2 Rich-Lean Bank 1 Sensor 1
F2 - mS = (BYTE 4 * (16702/255)) - O2 Rich-Lean Bank 1 Sensor 2
F2 - mS = (BYTE 5 * (16702/255)) - O2 Rich-Lean Bank 2 Sensor 1
F2 - mS = (BYTE 6 * (16702/255)) - O2 Rich-Lean Bank 2 Sensor 2
F3 - COUNT = (BYTE 3) -Misfire All Cylinders
F4 - COUNT = (BYTE 3) - Engine Run Time
F6 - BIT IS 1 = BYTE 3(b1) - A/F1 Test Status
F6 - BIT IS 1 = BYTE 3(b2) - A/F2 Test Status
F8 - STATE = (BYTE 3) - Shift Position
F8 - BIT IS 1 = BYTE 3(b4) - Lockup Soleniod
F8 - BIT IS 1 = BYTE 3(b5) - O/D Cut Soleniod
F9 - BIT IS 1 = BYTE 3(b1) - Shift Position Switch in L
F9 - BIT IS 1 = BYTE 3(b2) - Shift Position Switch in 2ND
F9 - BIT IS 1 = BYTE 3(b3) - Shift Position Switch in R
F9 - BIT IS 1 = BYTE 3(b4) - Pattern Select Switch in PWR
F9 - BIT IS 1 = BYTE 3(b5) - O/D Cut From O/D Off Switch
F9 - BIT IS 1 = BYTE 3(b6) - Kick Down Switch
F9 - BIT IS 1 = BYTE 3(b7) - Stop Light (Break Switch 1)
F9 - BIT IS 1 = BYTE 3(b8) - O/D Cut From CCS
F9 - BIT IS 1 = BYTE 4(b1) - Shift Position Switch in 3RD
F9 - BIT IS 1 = BYTE 4(b2) - Shift Position Switch in 4th/Drive
F9 - BIT IS 1 = BYTE 4(b4) - Shift Position Switch in Snow
F9 - BIT IS 1 = BYTE 4(b5) - Shift Position Switch in Sports Mode
F9 - BIT IS 1 = BYTE 4(b6) - Shift Position Switch in Sports Shift Down
F9 - BIT IS 1 = BYTE 4(b7) - Shift Position Switch in Sports Shift Up
FA - MPH - (BYTE 3 * (158/255)) - AT Speed ATF
FB - BIT IS 1 = BYTE 3(b1) - Shift Soleniod SLN
FB - BIT IS 1 = BYTE 3(b2) - Shift Soleniod SLU
FB - BIT IS 1 = BYTE 3(b3) - Shift Soleniod SLT
FB - BIT IS 1 = BYTE 3(b4) - Shift Soleniod SLD
FB - BIT IS 1 = BYTE 3(b5) - Shift Soleniod SLC
FB - BIT IS 1 = BYTE 3(b6) - Shift Soleniod SLS
FB - BIT IS 1 = BYTE 3(b7) - Shift Soleniod DSU
FC - RPM = (BYTE 3 * (12750/255)) - Direct Clutch RPM (NC0 or NC2)
FD - RPM = (BYTE 3 * (12750/255)) - Direct Clutch RPM (NC2)
FE - RPM = (BYTE 3 * (12750/255)) - Direct Clutch RPM (NC)
KilleRMill вне форума   Ответить с цитированием
Старый 21.10.2009, 20:39   #654
el66
Спасибо!
Жалко, что здесь не все. Надо будет сверить со своими PIDами.
Старый 22.10.2009, 06:57   #655
VVS_24
Я думаю надо найти стандарт SAE J1979. Возможно он прояснит ситуацию. Я пока не смог найти его в бесплатном виде.
Старый 22.10.2009, 17:48   #656
Nik0lay
Машина: 2001 Toyota Caldina
Nik0lay is on a distinguished road
Ну вот и я наконец доделал устройство с USB, в итоге имеем: FT232 компьютером определился без проблем, а вот Atmega светодиодами мигает как положено, а на связь выходить не хочет. Для наглядности вот мой вариант платы может какую ошибку я допустил.
Nik0lay вне форума   Ответить с цитированием
Старый 22.10.2009, 22:35   #657
persh
Машина: DHT YRV T-R
persh is on a distinguished road
Всё же заново спаял я Вариант на Сом-порту, разобрался почему не хотел он стартовать, на схеме с COM мама контакты идут в другом порядке нежеле на разьёме который я купил, и земли не было, но не суть..
Вот что пишет при подключении к Авто.. кстати авто Daihatsu.. она же тойотина Дочка..
Вот что это за протокол такой? Тойотин?
persh вне форума   Ответить с цитированием
Старый 22.10.2009, 23:01   #658
olegkali
Регион: 11
olegkali is on a distinguished road
Сообщение от persh Посмотреть сообщение
А ты при этом зажигание включил? Лучше вообще машину завести.
Я тоже спаял сканер по COM порту. Все работает, только хочется время работы форсунок посмотреть, а ни одна из поверенных мною программ не показывает.
ID:	13484   Нажмите на изображение для увеличения
ID:	13485   Нажмите на изображение для увеличения
ID:	13486   Нажмите на изображение для увеличения
ID:	13487   Нажмите на изображение для увеличения
ID:	13489   Нажмите на изображение для увеличения
ID:	13490   Нажмите на изображение для увеличения
olegkali вне форума   Ответить с цитированием
Старый 22.10.2009, 23:16   #659
persh
Машина: DHT YRV T-R
Конечно же при включённом зажигании пробовал и двиг заводил и чего только не делал.. Elm на принтскрине видно, Центрифуг: подключено и всё, все показания NA..
Меня тупо протокол смущает.. т.к. J1850 используют почти 80% американцев.. как на Праворукой НедоТоЙте он оказался.. ? И кстати у меня показывает прошивка 1.2а, на скринах выше 1.2b, я чёт пропустил? или я старую какую залил? ))
Старый 22.10.2009, 23:50   #660
olegkali
Регион: 11
Насчет прошивки ничего сказать не могу. MiD_34 мне прислал её месте с микрухой.
Машина у меня праворукая, Toyota Picnic, сингапурская.
obd ii, toyota
Часовой пояс GMT +4, время: 05:18.
